Old 09-09-2010, 08:58 PM   #1
fred.r
Member#: 204474
2002 Almost STi Wagn
RAW
Default EDM vs. JDM Bugeye Headlights.
Got a question for you guys.
Just sold my STi and going back into a Bugeye wagon.
First thing I wanna do is swap out the stock headlights for either the JDM or EDM. I want HID, but done correctly and safely.
Out of the two options (read them before answering), which is better and why:
EDM with HID conversion. (if this option, what HID kit should I go with)
or
JDM with LHD cutoff.
Assume I'm doing all the work here, so I either have to track down a LHD cutoff and bake with the JDM, or install an expensive HID kit in an already expensive set of EDM lights.
What are your thoughts? I have little to no experience with headlights.
fred.r is offline   Reply With Quote
Old 09-09-2010, 11:23 PM   #2
subaru3169
Member#: 55252
* pullup bar *
i don't remember if edms have hid projectors, i think they're halogen projectors.. if you wanted to just slap those lights on as they are, i think that'd be fine and much less of a hassle
jdms though, i think there's one version that uses hid projectors.. you can save those hids if you get a set that comes with them but swap the projectors to lhd and it'd be kosher
subaru3169 is offline   Reply With Quote
Old 09-09-2010, 11:43 PM   #3
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
None of the EDM lights came with HID.
If you get the EDM lights and want proper HID optics, you will have do a retrofit with tsx or s2000 projectors. If you get a set of JDM HID lights, the easiest way to convert it to LHD is to buy a new cutoff plate. That will require baking and opening the light, unbolting the projector, and then unbolting the cutoff plate. The ebay ballasts and D2S bulb kits are tempting due to their cost, but I'd stick with OEM.
illmatic is offline   Reply With Quote
Old 09-10-2010, 03:40 AM   #4
jdmSpecC760
Member#: 151598
04 Flared STi
IG: @dallas_dunn
yeah if you where going to swap out the cutoff doing a retro is not that much more work i did mine with TSX projectors with 4300k with color mod to the lens
crappy cell pics but so you can seee
jdmSpecC760 is offline   Reply With Quote
Old 09-11-2010, 04:54 AM   #5
fastwrx25
Member#: 126441
03 bugeye
I would just like to say the light output of the jdm halogen lights w/ rebased h1 hid kit is pretty crappy, and I'm not even talking about the rhd lighting. The lights look cool but useable light is horrid.
afterawhile I got sick of it, having such pretty lights that don't do anything when driving highspeeds or in the mountains so I did the tsx projector swap....and now
light output 100 times better. wide, clear, even, oem looking lights.
love them, one of my favorite mods. Makes for safer driving also.
fastwrx25 is offline   Reply With Quote
Old 09-11-2010, 11:12 AM   #6
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I am runing the JDM black crome HID's with LHD cutoffs and OEM HID bulbs and balists. They work great and look great too.
AFBeefcake is offline   Reply With Quote
Old 09-12-2010, 05:33 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
maybe to YOU....but.....maybe NOT to the rest of us
Old 09-12-2010, 05:56 PM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
edm with hid as I understand have holes where you wont have light. Or it's a lot less light because the projector was designed for halogen bulbs. hid bulbs are longer and have a different shape. It might fit with a conversion but not provide very good lighting.
Jdm hid is nice. Yet it's not nearly as bright as other cars. Yet it's ok. The cut off is needed otherwise you will blind the guy in front of you on the drivers side. There is a write up of this on scooby mods.
Personal choice. Swap the projectors and get tsx projectors. I did this on the jdm hid. It's not nearly as hard as it sounds. It might take 4hrs per headlight. You can have it done but it's pricey. You can spend $800 I think to have it done. I spent $120 on the projectors and some dremal work. I also have the leveling harness. Still working to finish mine only because of time to work on the inner clip on the passenger side. Since the plastic is softer then usdm headlights. Also the lens are the same in case you need to know.
Hope that helps
Old 09-12-2010, 07:14 PM   #9
illmatic
Member#: 3536
If you get JDM HIDs this is the easiest way to make it LHD. The shields are bolt on. If I had known these were available before my TSX retrofit, I would chose these due to simplicity.
LHD cutoff plate on leftside
http://cgi.ebay.com/ebaymotors/JDM-W...item1c11545dbf
Old 09-13-2010, 05:11 PM   #10
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Those are the ones that where used in my head lights.
Old 09-13-2010, 06:52 PM   #11
tmeultraman
Member#: 49610
he uses the lhd cutoffs why would that bother anyone?
tmeultraman is offline   Reply With Quote
WTT/WTB EDM/JDM Bugeye Headlights 2Slow4You Private 'Wanted' Classifieds 3 09-16-2009 01:24 PM
**wtb: Jdm Bugeye Headlights..edm As Well** min88 Private 'Wanted' Classifieds 0 09-04-2009 07:20 PM
*WTB: EDM or JDM BUGEYE HEADLIGHTS* min88 Private 'Wanted' Classifieds 0 09-04-2009 02:21 AM
EDM projectors, Stock BUGEYE headlights WReXd Exterior/Styling 4 08-16-2006 02:46 PM
EDM projectors, Stock BUGEYE headlights WReXd SCIC Private Classifieds 5 08-16-2006 02:45 PM
