#1 |
Member#: 172618
Vehicle:2000 RS BRP |
i am currently in the process of putting a 07 2.5i IM on my 2.5rs.
im pretty sure i have everything i need planned out, just need to get parts and physically do it. i have found very little info about people doing this, which is why i wanted to see what info you guys have obtained. any info will be helpful, im open to all suggestions.
#2 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
The only difficulty is in mounting the throttle since you have a cable throttle and the 05+ IM is for DBW. There's some brackets and things you'll have to have custom fabbed at a machine shop to allow the cable throttle to function.
#3 |
Member#: 192709
W. Canada
Vehicle:2007 2.5iSE Wagon CG 2001 2.5RS Coupe RBP |
and fab some sort of port for the Idle air to flow through. My best idea right now is to hog out the hole in the TB, tap an AN Pipe-flare fitting in and do the same somewhere on the intake manifold.
#4 |
Member#: 71092
Isn't the entire idle-air apparatus integrated into the throttle body?
#5 |
Member#: 172618
i compared gaskets and came to the conclusion that my stock RS TB will bolt up, but that stupid IACV passage has to be in the way.
i have a TB spacer, so i block it off on the manifold side, drill a hole/install fitting, run a hose from that fitting to the IM plenum. done! cable will be easy, small bracket. the map sensor! im going to port out on of the EGR holes, only need about a 1/8" all the way around, polish it up nice and pray i did a good job and that O ring will seal. i can always use sensor save gasket sealer. bolting it up will be no harder of bolting on another plate to the stock EGR threads and drilling holes with bolts for the map. you guys know it will work! if you guys get a chance, let me know what you think about this for the fuel system. http://www.rs25.com/forums/f13/t1427...-his-hose.html |
#6 |
Member#: 41986
NWIC
Vehicle:'06 STI/'85 Brat |
Nice! Thanks for putting this out there for everyone.
Aside from zzyzxx running one in the 300hp NA car, does anyone have any info on the gains that can be achieved by swapping to the newer manifold? Jacob |
#7 | |
Member#: 172618
more brains on the job is a good thing. |
#8 |
Member#: 41986
NWIC
#9 |
Member#: 172618
ill post pics and explain how i did things but i cant be bothered by a flowbench.
dont get me wrong i would love too, but im a full time college student and (Automotive Technology and Management) i have limited time. |
#10 | |
Member#: 41986
NWIC
Jacob |
#11 | |
Member#: 172618
butt dyno for now, real dyno when the chance pops up in the future. |
#12 | |
Member#: 41986
NWIC
Jacob |
#13 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Contact 42 Autosports. They've done it and came to the conclusion that the stock intake tract can't provide enough air to make it an all out winner. There are more details, but you should contact them to get the whole story.
Jay |
#14 |
Member#: 172618
^^ send them an email, waiting for a reply.
does anyone know if stock 2.5i injectors will work with a WRX/STI aftermarket fuel rail? gotta spend a certain amount on a FPR, so might as well do it while i have it apart and do a fuel rail/FPR combo. ebay sells come kits with lines and everything i need. normally i wouldnt mess with ebay stuff but machined aluminum is machined aluminum. |
#15 |
Member#: 256727
RMIC
Vehicle:2007 2.5I Wagon Silver |
#16 |
Member#: 172618
#17 | |
Member#: 256727
RMIC
What about the heads? Can they handle more air than the stock intake can provide as well? Generally that's where you hit a wall when it comes to NA engines... if the heads flow less CFM than the IM or intake tubes then modifying the intake won't do you any good anyways. |
#18 |
Member#: 5218
Exactly.....the torquebox made for pre-05 cars has a small inlet and the CAI they developed for those cars ended up not being a good match for that manifold. The torquebox made for that unit was better, but still short of what they had prior to bolting it on. IIRC, the best gains came from a 4" cone filter (from a GTR) taped directly onto the TB.
The smaller volume of the 05 torquebox works well enough, but the inlet to it needs opened up substantially to let it work. Jay |
#19 |
Member#: 256727
RMIC
So I take it the intake was redesigned for 06+? Just trying to figure out where my car fits in this.
#20 | |
Member#: 172618
here is the fuel rail/line kit i was talking about earlier. http://cgi.ebay.com/ebaymotors/High-...mZ280562461348 |
#21 |
Member#: 71092
#22 |
Member#: 256727
RMIC
#23 |
Member#: 71092
Yup45
#24 |
Member#: 256727
RMIC
Ok... cool. Beginning to get an idea of what I've got under the hood now.
Thanks! |
#25 |
Member#: 71092
Summary:
2002-2004=not much change 2005=big changes compared to 04 2006-2007=tiny changes compared to 05 |
| Thread Tools | |
| Display Modes | |
| Wanted - 04/05 wrx project car | bossautosports | Private 'Wanted' Classifieds | 0 | 01-27-2010 05:54 PM |
| 05 sti project, soon on 18x9.5 rota grids | stilv | Member's Car Gallery | 88 | 09-25-2009 04:04 PM |
| 05 sti project car.. only 25k miles! | michsti | Private Vehicle 'For Sale' Classifieds | 1 | 07-13-2009 03:06 PM |
| Reverse Intake Manifold Project | dunk | Mid Atlantic Impreza Club -- MAIC | 78 | 01-01-2009 11:36 AM |
| SoCal: 02-05 manifold, TGV's, injectors, throttle body, engine harness, turbo inlet | MannyMohawk#5 | Engine/Power/Exhaust | 26 | 01-29-2008 11:25 PM |
