Old 09-18-2010, 09:13 PM   #26
00LGTP
Member#: 172618
1995 EJ253/D25 GC
371hp/355tq 1.5xtr 93oct
Originally Posted by 00LGTP View Post
you already have the manifold i am putting on.
here is the fuel rail/line kit i was talking about earlier.
http://cgi.ebay.com/ebaymotors/High-...mZ280562461348
anyone have an opinion?
FPR- maybe get another one, but the rails and lines are rails and lines.
the 08 WRX injectors(blue) and 2.5i (yellow) are the same, i just need to know if the distance from the center of the injector bore to the other. might work, fabbing a bracket for the rail would be easy.
00LGTP is offline   Reply With Quote
Old 09-19-2010, 07:22 PM   #27
00LGTP
Member#: 172618
1995 EJ253/D25 GC
someone must have some information or opinion. TTT
Old 09-19-2010, 10:12 PM   #28
Storm
Member#: 5218
96L Most Over-
Developed Beater
The bore spacing is the same on all EJ's, so the injectors will line up fine. You may need to fab a bracket to hold the rail down.....yes.
I see the makings of an ITB setup in that pic......
Jay
Old 09-20-2010, 07:26 AM   #29
00LGTP
Member#: 172618
1995 EJ253/D25 GC
Jay
good to know! thanks
of the ITB thing, i took that pic from searching. not mine
maybe ill order that fuel rail kit off ebay some time this week.
Old 09-27-2010, 04:46 PM   #30
00LGTP
Member#: 172618
1995 EJ253/D25 GC
quick update
getting one of the EGR ports bored out to fit my stock MAP sensor
i installed the 07 coil pack/wires on my 00 RS to make sure everything works as it should before i do the major swap. the best part.... literally plug and play!
Old 10-05-2010, 06:33 PM   #31
00LGTP
Member#: 172618
1995 EJ253/D25 GC
Old 10-05-2010, 08:08 PM   #32
Back Road Runner
Member#: 60082
2004 Forester STI
i think he means the stock intake tubing cant flow enough to see gain.
its not all about the volume of air, the runner lengths are long and P&P from the factory.
The intake, pre throttle body, is fine for flow. It doesn't limit the car in any way. You can remove all of it and have just the throttle body itself, and there will be zero gains in power up top. The intake piping simply is not restrictive.
What is restrictive is the head/cam. Subaru designs the intake system to flow the same throughout. This means the throttle body, intake manifold, heads, and cams are all geared to flow the same amount and have the same velocity. This of course makes the system share the same restriction. If you increase intake manifold flow, you need to also increase the flow through the heads. This means porting. The cams will also have their own design limitations and are geared for the stock hardware. The exhaust manifold will be designed for stock flow too.
Effectively you want to scale up everything from the start of the intake piping to the end of the exhaust tail pipe. Uneven sizing and restrictions anywhere can limit overall gains.
Is that bracket for the MAP? The runner will exhibit sizable pressure variations in the runner. I question if the MAP reading will be decent enough to be useful. It really should be reading from the center of the plenum area like it is on the older manifold. I'm not sure how ell the ECU will like what it measures from a runner.
Old 10-05-2010, 08:17 PM   #33
00LGTP
Member#: 172618
1995 EJ253/D25 GC
i have every else supporting mod.
Im tnice17 on RS25 and we met up at the ECS meet, now i think you remember me and my car.
yes its for the map. i didnt want to risk welding on the cast aluminium and after talking to a few of my instructors they said it should be good enough for an accurate reading.
some GM MAP sensors are mounted on the firewall and has a small hose going from the intake manifold to the sensor. so i think my location will be ok. well we will find out!
im going to use the 07 injectors with a modified 00/07 rail and RPR
Old 10-05-2010, 10:06 PM   #34
Storm
Member#: 5218
96L Most Over-
Developed Beater
One of the holes in the location of that bracket has a passage that leads to the plenum center, and would be a suitable source for the MAP signal. I believe it's the bottom hole, not the top one as that bracket is using.....
Jay
Old 10-05-2010, 10:40 PM   #35
Back Road Runner
Member#: 60082
2004 Forester STI
I assume you're not talking to be about the ECS meet. I'm nowhere near CT.
I know some stand alone ECUs with a built-in MAP will run a hose to a vacuum line. I'm not really sure how accurate it needs to be over time. It may just work off averages. Like Storm mentioned, it might be a specific hole and not just any.
I am curious. Why did you opt for the cast intake instead of the plastic one?
Old 10-05-2010, 11:53 PM   #36
00LGTP
Member#: 172618
1995 EJ253/D25 GC
yea the one in CT. sorry didnt look at your location, similar user names.
anyway, i have 2k cams, P&P IM/TB heads, flat faced valves,EL exhaust, CAI.
i made 168/157 at the ESC meet. stock ECU.
i was looking all over for the plastic one, but air temp can only get you so far on a NA car. runner length and tuning air flow is were its at for power making.
Old 11-09-2010, 12:00 AM   #37
00LGTP
Member#: 172618
1995 EJ253/D25 GC
Jay
the top hole does go into the plenum. the bottom one goes to that threaded hole for the EGR.
hope to have this done in the next few weeks.
Old 11-09-2010, 01:05 AM   #38
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
This project intrigues me very much.
Interested to see how it works out.
T Wrex--OH is offline   Reply With Quote
Old 11-09-2010, 06:30 PM   #39
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
00LGTP - Are you anywhere near a shop with an AWD dyno? Is the car still running with the stock IM while you work out the details of the '05+ IM? I would be willing to fund some dyno comparison testing, just because I get off on this sort of thing.
I wanted to put one of these '05+ IMs on my engine, but it would've required extensive modifying since the bolt pattern and runner spacing isn't the same on the N/A DOHC and SOHC engines.
Pat Olsen
Old 11-10-2010, 10:23 PM   #40
00LGTP
Member#: 172618
1995 EJ253/D25 GC
Pat Olsen
i am near ECS in CT. i DD the car now, i drive it back and forth from PA to CT for school
these cars are easy to work, we can just swap it onto your engine. its the least i can do if yours willing to fund the dyno. it is greatly appreciated!
i need to hurry up than, winter time is coming and once a few flakes fall its going in the garage.
Old 11-11-2010, 08:02 AM   #41
GC8WSI
Member#: 92857
2000 Swapped GC8 RS
BRP
Good luck dewd!
GC8WSI is offline   Reply With Quote
Old 11-11-2010, 01:33 PM   #42
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Trust me, it's not that easy, otherwise I would've done it. The bolt pattern for SOHC and N/A DOHC is different where the intake bolts to the heads, so that's the first problem. Even more difficult to overcome is that the distance from the intake ports on one head to the intake ports on the other head is different. In other words, the intake manifolds are different lengths. I remember a picture that showed the difference, but I can't find that now. Anyway, you would basically have to cut off the ends of the intake manifold so you could shorten the runners and then weld it all back together.
If you can get the project done and schedule the time at ECS, then you can just have them call me and I'll put it on my CC.
Old 11-11-2010, 05:01 PM   #43
00LGTP
Member#: 172618
1995 EJ253/D25 GC
ah i didnt look to the left to see your type of car.
your giving me motivation to get this done, and its going to be a beautiful weekend too!
i should have the last part i need tomorrow. getting it back from the machine shop.
its a 1/4" plate of aluminum as a block off plate for the IACV and my crazy idea to make this work.
whats your opinion on the evap purge solenoid and the air assist solenoid for my car?
i was going to plumb the hoses to a vac line on the intake manifold, just as long as i can do i think i might be ok.
i will post up more pics tomorrow. again, thank you for this opportunity!
Old 11-14-2010, 10:59 PM   #44
00LGTP
Member#: 172618
1995 EJ253/D25 GC
just need to extend 2 wires and im done.
all ready to bolt up to a ej251
Old 11-14-2010, 11:23 PM   #45
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Interesting how extreme the runner length difference is.
Old 11-14-2010, 11:23 PM   #46
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
So what are you doing with the camera??? Get those wires done and slap that thing in!
BAN SUVS is offline   Reply With Quote
Old 11-14-2010, 11:28 PM   #47
00LGTP
Member#: 172618
1995 EJ253/D25 GC
im trying not to temp my self to electrical tape the wires together. i dont have the supplies ATM
Old 11-14-2010, 11:57 PM   #48
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Fair enough.
Old 11-14-2010, 11:58 PM   #49
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
I'm definetely liking this thread better than the one you just made on RS25, ha ha. Really wanna know if there's gains to be had here.
Old 11-15-2010, 12:01 AM   #50
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
What happened over there? FalconRS get his panties in a twist?
Wanted - 04/05 wrx project car bossautosports Private 'Wanted' Classifieds 0 01-27-2010 05:54 PM
05 sti project, soon on 18x9.5 rota grids stilv Member's Car Gallery 88 09-25-2009 04:04 PM
05 sti project car.. only 25k miles! michsti Private Vehicle 'For Sale' Classifieds 1 07-13-2009 03:06 PM
Reverse Intake Manifold Project dunk Mid Atlantic Impreza Club -- MAIC 78 01-01-2009 11:36 AM
SoCal: 02-05 manifold, TGV's, injectors, throttle body, engine harness, turbo inlet MannyMohawk#5 Engine/Power/Exhaust 26 01-29-2008 11:25 PM
