Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-09-2010, 11:22 PM   #1
homemade
Member#: 235937
88 supra
Default need the specs on 04 rotors
i need to know how many millimeters the sti rotors are. i assume 04 to 07 are the same size minus the lug pattern.
i need 30mm rotors.
homemade is offline   Reply With Quote
Old 09-09-2010, 11:37 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Google. It took me 20 seconds.
326mm x 30mm
car_cursed is offline   Reply With Quote
Old 09-09-2010, 11:47 PM   #3
homemade
Member#: 235937
88 supra
dude i tried. with no luck.
Old 09-09-2010, 11:49 PM   #4
homemade
Member#: 235937
88 supra
can anybody tell me what the
two numbers stand for.
326---- diamter or rotor?
30mm---- size of contact patch for pads.????
Old 09-10-2010, 12:03 AM   #5
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
326---- diamter or rotor?this is the diameter
30mm---- size of contact patch for pads.???? thickness of the rotor
nd it was the first Google search result
Old 09-10-2010, 12:11 AM   #6
homemade
Member#: 235937
88 supra
haha. im so glad your online tonight car_cursed. please dont be annoyed by me.
Old 09-10-2010, 12:15 AM   #7
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
haha. He wouldn't listen to me when I told him the smaller number was the thickness.
EsubaruJ is offline   Reply With Quote
Old 09-10-2010, 12:18 AM   #8
homemade
Member#: 235937
88 supra
so to get down to the real question, would a diameter difference of 25mm (sti being 25mm bigger than calipers came stock with) be a drastic and debilitating upgrade.
caliper rated for 297 rotors and rotors being 326. doable or no.
Old 09-10-2010, 11:23 AM   #9
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
what are you planning? i bigger rotor has may advantages, more torque, more heat soak and greater surface area. Are you looking for a brake upgrade? if you don't want to "brake" the bank with a full Brembo set up you can get the 2005 legacy Gt brake caliper and rotors for pretty cheap. They are a 2 piece floating caliper like stock brakes but have a 316 mm front and a 290 mm vented rear.
aclver1 is offline   Reply With Quote
Old 09-10-2010, 05:50 PM   #10
homemade
Member#: 235937
88 supra
well im doing a homemade custom jobby job. 300z calipers and i am trying to see if i have to go with 300z rotors (which i would have to have redrilled to 5x100) or the 04 sti rotors or wrx rotors or what.
Old 09-11-2010, 09:54 PM   #11
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Won't work unless you fab new brackets. Just try to find some sti take offs. I bought mine 3 years ago for $500.
Old 09-11-2010, 10:07 PM   #12
homemade
Member#: 235937
88 supra
i am fabbing brackets.
Old 09-11-2010, 10:31 PM   #13
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Then you could use whatever diameter rotor you want.
Old 09-12-2010, 10:33 AM   #14
homemade
Member#: 235937
88 supra
ok but what about the contact patch of the brake pads to the rotor. that has to be affected somewhat.
Old 09-12-2010, 10:41 AM   #15
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Not as long as you do it right.
Old 09-12-2010, 05:22 PM   #16
homemade
Member#: 235937
88 supra
as the rotor gets bigger and bigger you get less and less contact with the brake pad to the face of the rotor. even if you did do it right.
i think im going to go with the legacy GT ones. they are pretty close.
Old 09-12-2010, 09:54 PM   #17
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
You don't lose contact patch if the brackets you make set the caliber in the same spot as the oem ones.
Old 09-12-2010, 10:37 PM   #18
homemade
Member#: 235937
88 supra
the ears on these calipers are different.
plus most one calipers have a cut out that fits a certain size. you would have to see maybe ill just post pics.
ill take mine off and post pics tomorrow or something.
What are the specs on the late 90's wrc car engine? bmw50021 Pre-2002 Factory Turbo Powertrain 10 12-22-2008 08:16 PM
Installed d-specs on 04 sti...now questions kenlee Brakes, Steering & Suspension 7 12-22-2008 12:41 AM
What are the specs on the VF34? BMS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-20-2005 08:16 PM
I was checking the specs on the end line for the rotary girder . . . Protege Menace Off-Topic 1 04-20-2004 08:40 PM
anyone got the specs on the ej20 NA? mcu81 Normally Aspirated Powertrain 4 06-30-2002 05:05 AM
