Old 04-27-2011, 10:25 PM   #276
fan boy
Member#: 241243
Originally Posted by bmw50021 View Post
check that the injectors are firing with a simple led & resistor on their connectors, or noid light, or oscilloscope. check fuel pressure with a gauge. also check that your fuel lines are connected properly. if you have the supply and return switched around, it won't work. check for spark as well. if you are using wrx/sti coilpacks with internal ignitors, the led trick will work for that as well. there are 3 wires, 12v, gnd, and signal from the ecu. pretty sure signal varies between 0-5 volts.
ok well i have 2 grounds on the coilpack connector, 3 if you count the trigger with the key on!!?
and the front cylinders have fuel on the plugs now...the rear plugs are dry...the heavy red wire to the injector plug is ground.
edit: there were 6-7 codes---all for the TVG circuits---and a fuel temp sensor imput low---
fan boy is offline   Reply With Quote
Old 04-29-2011, 12:45 AM   #277
fan boy
Member#: 241243
new fuel lines mocked up. Final install will be more neat and bolted down.
Old 04-29-2011, 12:50 AM   #278
fan boy
Member#: 241243
1/2" steel rod/muffler bracket heated and bent into place.
Old 04-30-2011, 02:21 PM   #279
Mad Ra88it
Member#: 113563
98 Unicorn
Coming together rather nicely. I admire your passion to stick with it and keep pushing forward!
Mad Ra88it is offline   Reply With Quote
Old 05-05-2011, 12:46 PM   #280
fan boy
Member#: 241243
thanks!
ok so i now have power at all 4 coils, but only one coil is firing---i am looking for the ecu pins for the coil signals so i can check the wires for continuity...it is frustrating at best, but i think once i get spark, she's going to fire up.
Old 05-05-2011, 12:56 PM   #281
Keif
Member#: 107302
Do you have a flex pipe before that bracket in front of the muffler?
Keif is offline   Reply With Quote
Old 05-05-2011, 12:59 PM   #282
fan boy
Member#: 241243
no flex pipes in the exhaust--
Old 05-05-2011, 01:24 PM   #283
Keif
Member#: 107302
Wont there be a problem with that being a solid mount?
Old 05-05-2011, 10:16 PM   #284
fan boy
Member#: 241243
nahhh if it needs to flex, the cat back attaches with spring bolts to a donut style gasket---
Old 05-06-2011, 12:00 AM   #285
GuamSTI
Member#: 210071
04 STI
Wow, nice
GuamSTI is offline   Reply With Quote
Old 05-06-2011, 02:39 PM   #286
fan boy
Member#: 241243
update:
so everything was plugged in to my knowledge---and i'm only getting one coil firing---(main relay is triggered/no power to coil trigger wires) turn main relay off and i have power to the triggers ---does this mean the ecu is broke since only one is working even tho they all get power??
Old 05-06-2011, 03:22 PM   #287
Keif
Member#: 107302
Maybe the coils are dead?
Old 05-06-2011, 03:47 PM   #288
fan boy
Member#: 241243
i tried the 3 coils that weren't firing on the working plug, and they fired.
Old 05-09-2011, 12:28 AM   #289
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
are you running a complete swap, as in did the motor and ecu come together?
Ben
Old 05-09-2011, 10:22 AM   #290
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I don't think I would trust that to provide enough flexibility in an exhaust system.
Old 05-09-2011, 11:03 AM   #291
Keif
Member#: 107302
It seems pretty risky to me too. I'm not so sure it would allow any flex once its torqued down.
Old 05-09-2011, 11:39 AM   #292
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Subscribed, this is crazy and I love it.
LIQUIDSK8S is offline   Reply With Quote
Old 05-09-2011, 10:01 PM   #293
fan boy
Member#: 241243
the motor mounts are solid---if anything breaks i'd like to see it.
Old 05-09-2011, 10:04 PM   #294
fan boy
Member#: 241243
Ben
no the motor was blown into pieces and pulled of the donor car when i got it---the ecu was still installed in the car, so i never saw it running---
Old 05-10-2011, 12:02 AM   #295
fan boy
Member#: 241243
back half is all welded up---did a lot of grinding on it....she is getting smooth! here's a picture of it all degreased and coated with zinc...
edit---am going to start taking pictures with a point and shoot---i banged the lens and noticed the pictures are coming out blurry---
Old 05-10-2011, 01:19 AM   #296
THA KERNALLL
Member#: 227271
2006 STi
Can't wait to see this out on the streets! Subscribed!
THA KERNALLL is offline   Reply With Quote
Old 05-11-2011, 09:43 AM   #297
fan boy
Member#: 241243
AFTER:
Old 05-11-2011, 12:55 PM   #298
DarkPhoenix
Member#: 272511
1997 Legacy Outback
Ruby Mica Metallic
Looking good bro. Nice to see that it is progressing! Can't wait for the final product!
DarkPhoenix is offline   Reply With Quote
Old 05-15-2011, 11:19 AM   #299
Pooge
Member#: 282418
Love it. I've had a couple hardbodies and it's a timeless design. You have some impressive work here, keep it up
Doug
Pooge is offline   Reply With Quote
Old 05-15-2011, 01:09 PM   #300
kheff46
Member#: 66739
2002 WRX wagon
i have been lurking, and i had to say i eagerly await your completion. or seeing it driveable, since projects are never done!
P.S. those summit fuel cells suck! they deteriorate rapidly, but for the price i didn't pass it up. i now regret it afterwards. i also removed the foam after a bit of use. it seems to hold the gas more than help with anti-slosh imo.
--keith
kheff46 is offline   Reply With Quote
School me on the Nissan Hardbody pickup truck. plunk10 Off-Topic 50 12-12-2015 12:01 PM
03 WRX drivetrain ---> 97 OBS fourstrokephysics Subaru Conversions 5 09-06-2012 12:30 PM
FS : MI: 96 Brighton with 02 WRX Drivetrain Swap eatadolfin Private Vehicle 'For Sale' Classifieds 9 09-22-2010 10:12 AM
FS: AZ - 1993 Nissan Hardbody, bagged with fully built backhalf and suicide door v8eaterWRX SWIC Private Classifieds 14 05-15-2010 03:23 AM
