Old 01-21-2011, 03:16 PM   #151
fan boy
Member#: 241243
OK guys, i'm looking to clean up the stock harness a bit, so i need some help connector identification style---any ideas?? FYI-they are all interior pieces...i will update this post as i find out whats what. thank you!
1.
"located under the dash, mounts near the OBDII connector, but doesn't connect to anything. I have no idea what it's purpose is, but it doesn't have to be connected to anything."-DrKicker
2.
these plugs are located right near the clutch/brake switch connectors
greens-"not much help but i know the green plugs have to be connected when i flash a map with my access port"-todeswalzer.
"The greens connected activate a test/ systems diag. mode. AFAIK normally un- connected."-02redwagone.
white-
black-
gray-
blue-
3.
--white- keyless entry modual
gray-?
brown-?
fan boy is offline   Reply With Quote
Old 01-21-2011, 04:05 PM   #152
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
and the plug in first picture is under my dash right next to the obdii plug and its never been connected to anything
todeswalzer is offline   Reply With Quote
Old 01-21-2011, 04:07 PM   #153
DrKicker
Member#: 23071
2003 WRX
The top one mounts on the bottom cover near the OBD2 connector, but doesn't connect to anything. I have no idea what it's purpose is, but it doesn't have to be connected to anything.
DrKicker is offline   Reply With Quote
Old 01-21-2011, 04:07 PM   #154
fullerton
Member#: 122030
the gray one makes me thing it connects to the throttle pedal... i know TiC had a thread on how to install their fancy pedals, maybe you can find some good under dash picts there.
fullerton is offline   Reply With Quote
Old 01-21-2011, 04:13 PM   #155
fullerton
Member#: 122030
well, it's black, but this thread may help with the picts. gotta dig through it though.
it's on I Wanna Down Pipe Land:
http://www.iwsti.com/forums/gr-inter...dals-08-a.html
Old 01-21-2011, 07:31 PM   #156
ben_art
Member#: 172635
2003 WRX Wagon
the big grey #1 is where you plug in an obdII code reader?
ben_art is offline   Reply With Quote
Old 01-22-2011, 05:23 AM   #157
02redwagone
Member#: 87067
02 Old but tasty
SRP
02redwagone is offline   Reply With Quote
Old 01-26-2011, 08:46 PM   #158
fan boy
Member#: 241243
wires are getting there--no more air bags or rear door harnesses---
what is this sensor/bracket here??-/\
Old 01-26-2011, 09:27 PM   #159
fan boy
Member#: 241243
removing the rubber from the stock motor mounts--
Old 02-01-2011, 09:15 PM   #160
Zerogravity
Member#: 151638
2005 WRX Wagon
WOW this project is f_cking AWESOME!!! You sir have talent and skills! Good Luck can't wait to see it complete.
Zerogravity is offline   Reply With Quote
Old 02-02-2011, 04:23 PM   #161
DarkPhoenix
Member#: 272511
1997 Legacy Outback
Ruby Mica Metallic
This is what owning and loving Subarus is about. Taking what you know works, and mating it with something else that works.
This has to be one of the craziest builds I have ever seen, aside from the guy who put his Honda EG body on a WRX drivetrain.
DarkPhoenix is offline   Reply With Quote
Old 02-02-2011, 07:49 PM   #162
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
...or Girodisc's Celaru (Basically Celica body on STI drivetrain)
Nice Truck!
Can't wait to see it finished...
BeBop86 is offline   Reply With Quote
Old 02-02-2011, 09:50 PM   #163
crollins
Member#: 202202
2011 Clubman S
green
Very cool, looks like your work is top notch.
crollins is offline   Reply With Quote
Old 02-03-2011, 12:23 AM   #164
Impezsed
Member#: 246781
02 WRX
Default Sick!
Subscribed
Impezsed is offline   Reply With Quote
Old 02-03-2011, 08:21 PM   #165
Mad Ra88it
Member#: 113563
98 Unicorn
Damn! I love it...still.
I was going to offer up my harness that was already converted to run in a Mazda B2000 pickup truck. It's been stripped and everything. Only needs the motor harness that I think you already have. But the hard work has been done.
PM me if you'd like. It's tagged and labeled for everything.
Mad Ra88it is offline   Reply With Quote
Old 02-04-2011, 10:18 AM   #166
Ryguy32789
Member#: 214559
2005 WRX
closeup of the sensor/bracket? Is it a momentary switch? It looks a little bit like the clutch interlock switch or a pedal activated switch.
Ryguy32789 is offline   Reply With Quote
Old 02-04-2011, 12:45 PM   #167
ZapBrannigan
Member#: 251356
I whole-heartedly approve.
ZapBrannigan is offline   Reply With Quote
Old 02-06-2011, 01:51 AM   #168
fan boy
Member#: 241243
(Girodisc's Celaru , Honda EG body on a WRX) --thanks for posting... bookmarked for a later read.
honestly, this project has become an itchy challenge.....When i bought the suby, it was a basket case---a lot of parts in boxes---It's annoying trying to put something together that you don't know what it's supposed to look like..
Old 02-06-2011, 02:13 AM   #169
fan boy
Member#: 241243
here's a picture---
Old 02-06-2011, 02:21 AM   #170
fan boy
Member#: 241243
added the oil fill tube today, and filled up the crank case mounted the rear braided brake lines to the frame, and got the rest of the brake parts in---i'm going to forget about hooking up abs for now, i can always add it in later---
like christmas
hooked up the juice clutch linkage-
ok, now the starter trigger wire, that goes under the positive battery cable---where does it come from? it looks like its missing from my wiring harness---can someone point me where it might have gotten cut?
Old 02-06-2011, 07:42 AM   #171
Einimas
Member#: 176111
Make more close up shots of your harness.
Einimas is offline   Reply With Quote
Old 02-07-2011, 09:55 AM   #172
HeK
Member#: 102144
1999 Impreza RS2.5
Silverthorn Metallic
Originally Posted by fan boy View Post
here's a picture---
It's an ABS sensor, an accelerometer.
The bracket is marked as per which direction faces the front of the car.
HeK is offline   Reply With Quote
Old 02-07-2011, 10:25 AM   #173
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 02-07-2011, 11:52 AM   #174
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Old 02-08-2011, 08:27 AM   #175
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
This is my favorite thread!!!
sackytar is offline   Reply With Quote
School me on the Nissan Hardbody pickup truck. plunk10 Off-Topic 50 12-12-2015 12:01 PM
03 WRX drivetrain ---> 97 OBS fourstrokephysics Subaru Conversions 5 09-06-2012 12:30 PM
FS : MI: 96 Brighton with 02 WRX Drivetrain Swap eatadolfin Private Vehicle 'For Sale' Classifieds 9 09-22-2010 10:12 AM
FS: AZ - 1993 Nissan Hardbody, bagged with fully built backhalf and suicide door v8eaterWRX SWIC Private Classifieds 14 05-15-2010 03:23 AM
