Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2015
Old 09-10-2010, 12:40 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Checking valve sraightness - ghetto way
Say you bought some used valves and want to make sure they are straight before install. What do you guys think of doing this:
Straight valve (video)
Bent Valve (video)
Bad Noodle is online now   Reply With Quote
Old 09-10-2010, 12:56 PM   #2
Member#: 241311
95L V6WRXSTI type R
hahahahah i would have never thought of that
Imprzaboy89 is offline   Reply With Quote
Old 09-10-2010, 12:56 PM   #3
Member#: 125304
Try to find a guy that reloads cartridges he use a tool to check the runout of brass cases. Two small veeblocks will also work. A drill has too much wobble. A suby valve can be bent only a small amount and it will seat by bending the stem. It will show good leakdown and compression but will be noisey in the seating sequence and sound like the clearances are wrong. It might be better to just take the valves to a shop and pay them to check them. You can buy the tool but if you aren'y going to be doing this a lot the shop will be the cheapest way. My son's sti had all eight intakes bent and it still ran good with good leakdown and compression. Some were only bent as little as .015 but you could see where they kissed the edges of the eyebrows after close observation. He had a little extra valve train noise at 3500 was the only real symptom.
Valve concentricity gauge
charliew is offline   Reply With Quote
Old 09-11-2010, 10:04 AM   #4
Member#: 107290
Nothing wrong with what u r doing, i use a makita cordless drill (flat bottom) so it sits sturdy and put the valve head close to something......anything! When it turns it shows the valve head movement like it's in a lathe.
bertune is offline   Reply With Quote
Old 09-11-2010, 12:29 PM   #5
Member#: 173241
2002 s256 twinscroll
now with one more gear
at the shop i go to they do it the same way just use a drill press
seanathanq83 is offline   Reply With Quote
Check out my ghetto xm/hu/cell phone install workin4audi Car Audio, Video & Security 6 07-12-2004 11:15 AM
Check out the Ghetto Rice here KingsX8 Mid West Subaru Owners Club Forum -- MWSOC 32 05-31-2004 06:34 PM
Check out my ghetto paint job! I painted the car in my garage yesterday... Sean Interior & Exterior Modification 26 09-07-2002 11:27 PM
Fuel Canister Check valve thingy Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-17-2001 09:06 PM
Check valve location for MAP on MY99. SKiDaZZLe Technical Forum Archive 0 07-06-2000 09:17 AM
