Old 09-10-2010, 12:55 PM   #1
RaineMan
Member#: 256727
2007 2.5I Wagon
Default 2.5i Stock Exhaust Diameter?
Hey all.
Wondering about the size of the stock 2.5i exhaust. Can someone post measurements? I'm looking to get a little more sound out of the car and replace my plain (and slightly rusty) stock muffler. don't really feel like shelling out mega bucks for a full cat-back. Was gonna order a muffler and tips online then go down to a local shop and have them welded up... just need to know what the inlet size should be.
Thanks!
RaineMan is offline   Reply With Quote
Old 09-10-2010, 01:34 PM   #2
chuds
Member#: 245141
07 2.5i
cgm
Not sure of exact diameter. If your buying a muffler and having them weld it they 'should' be able to make just about anything work. Muffler inlet 2.25 or 2.5 is good.
I put a wrx (2.5'' pipe) stromung axel back on my 2.5i with no issue. Flanges will match up perfect. I got mine used here for a fraction of the price. Check local classifieds section here for a great deal on an axel back.
Still might have to torch off the old bolts, mine were beyond rusty and a new gasket.
chuds is offline   Reply With Quote
Old 09-10-2010, 01:37 PM   #3
iRazor
Member#: 257035
2008 wrx
kool-aid red
my muffler place said i have 1.75 on my 10' impreza sedan. im looking to replace mine as well but im not sure if the wrx catback i was looking at would bolt up directly to my headers
iRazor is offline   Reply With Quote
Old 09-10-2010, 01:57 PM   #4
GEE-OTTO
Member#: 201277
2009 Legacy GT
on my 08 2.5i Legacy i have a 2.25" mid pipe with 1 7/8" splits to each muffler
GEE-OTTO is online now   Reply With Quote
Old 09-10-2010, 01:58 PM   #5
RaineMan
Member#: 256727
2007 2.5I Wagon
True... however restriction is still in the back of my mind. If the stock exhaust is smaller than 2" I may lean more towards buying a full cat-back.
For you guys with dual mufflers I'd say the mid-pipe diameter is what I'm after... since the pipes would be smaller after the split b/c they only have to carry 2 cylinders worth of exhaust.
Old 09-10-2010, 03:53 PM   #6
GEE-OTTO
Member#: 201277
2009 Legacy GT
You have a Ej253 there are no restrictions in the exhaust! The mid pipe on a 08+ Impreza Sedan is 2.25 inches more than enough to flow the output of the heads. I would go no larger than 2.5 I would stick to 2.25 esp if you have a stock motor
Old 09-10-2010, 04:20 PM   #7
RaineMan
Member#: 256727
2007 2.5I Wagon
I've got an 07... single exhaust.
But yes, if it is really 2.25" I will be replacing the muffler and that is it. I was hoping it didn't have some pea-shooter 1.5" system on it. It looks like 2" or 2.25" to me... was just seeking confirmation from someone before I start buying parts.
Old 09-12-2010, 09:45 PM   #8
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
I have my whole stock exhaust off the car... it's 2.25" Just measured with my digital caliper.
Sir-Knight is offline   Reply With Quote
Old 09-14-2010, 01:31 AM   #9
bmobs06
Member#: 252783
depends, are you measuring outer diameter or inner? i'm pretty sure the inner is 1 7/8ths or something. i measured mine when i did the full sti catback but cant find the pictures. the sti is a 2 1/2 outer diameter but a 2 1/4 inner.
bmobs06 is offline   Reply With Quote
Old 05-10-2012, 01:19 AM   #10
grungeman
Member#: 317538
07 Subaru impreza
satin white pearl
I am also looking to put a muffler on my 07 impreza would a new one make a ok sound?
grungeman is offline   Reply With Quote
Old 05-10-2012, 11:40 PM   #11
f4umt
Member#: 283246
06 OutbackSport SE
id is 1 7/8ths i switch mine to a complete sti cat back, wasn't hard.
f4umt is offline   Reply With Quote
Old 05-10-2012, 11:51 PM   #12
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Like everyone is saying 2.25inch
I went with a magnaflow 2.5 inch straight through muffler and love it, in my opinion it's equivalent in sound to the spt(I do have uel headers on so that will make a decent change it how its going to sound on your car) the magnaflow only set me back $70 with a tip and new hangers when all was said and done
alt14 is offline   Reply With Quote
Old 05-17-2013, 11:24 PM   #13
cmarco98
Member#: 356626
2007 Impreza 2.5i
Default 07 impreza 2.5i sedan
Soooooo what's the actual pipe inside size for the 07 2.5i and what size to go to for catback? Cause I seen different answers on the thread. And best axle back for my car? What size muffler inlet and outlet? Sorry for alot of q's but please and thanks!
cmarco98 is offline   Reply With Quote
Old 05-18-2013, 11:39 AM   #14
subbyxinxdistress
Member#: 351304
2006 impreza 2.5i
steel gray metalic
it is actually a 2" pipe. i just did the wrx modded header install and the 2.25 piping i bought literally slid over my stock piping. so i had to cut a slit and hammer in the gap.
subbyxinxdistress is offline   Reply With Quote
2008 2.5i wagon FSB diameter? Don Grafmyer Brakes, Steering & Suspension 3 03-19-2010 05:53 PM
07 2.5i Stock exhaust Spliffnugz Engine/Power/Exhaust 0 10-16-2009 02:13 PM
Fs: 07' Impreza 2.5i Stock Exhaust Spliffnugz Engine/Power/Exhaust 0 10-07-2009 12:33 AM
WTB: 06-07 subaru impreza 2.5i stock exhaust manifold Vizzionz Private 'Wanted' Classifieds 8 07-27-2008 03:14 AM
Stock exhaust diameter 98 2.5rs Rockstar25 Newbies & FAQs 0 08-08-2005 06:11 PM
