Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-16-2011, 03:17 PM   #51
N/A_Scoobs
Member#: 255985
2008 Impreza N/A
dark grey metallic
N/A_Scoobs is offline   Reply With Quote
Old 01-27-2011, 04:49 PM   #52
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
to install a short shifter is easy as hell me and a friend did one in like a few mins just gotta follow directions
thegonz is offline   Reply With Quote
Old 01-28-2011, 07:01 PM   #53
gt-[r]
Member#: 185430
2008 Impreza
Originally Posted by Ogden View Post
For suspension parts, search on the WRX. The only non-compatible part in the WRX suspension system is the front sway bar. Everything else (rear sway, coils, struts, etc) will bolt right up.
You will have better luck searching for WRX parts and then checking compatibility. Suspension, brakes, and most of the car will be mostly the same. Engine is different, obviously, and some few parts here and there, like the front sway bar and the lower chassis bare, will not work on the 2.5i.
so would installing an oem wrx sway bar (front or rear) improve much over whatever the 2.5i currently has?
what about endlinks?
or would you recommend going for after market performance sways?
gt-[r] is offline   Reply With Quote
Old 01-28-2011, 07:31 PM   #54
ejhayes76
Member#: 267923
2011 Impreza 2.5i
Considering the 2.5i doesn't even have a rear sway bar, I recommend it.
I'm waiting for the Rallitek front/rear sway bar kit to get back in stock. I plan to add that and probably their front endlinks too.
On the cheap, you could add a used WRX rear bar (and the mounting hardware) pretty reasonably. I'm sure that would help things out too.
Note: The WRX front bars don't fit the 2.5i
ejhayes76 is offline   Reply With Quote
Old 01-29-2011, 06:52 PM   #55
Dayglow
Member#: 211395
0000 4wfp Flintstone
Mobile made of stone+wood
I've got a 2010 Impreza premium 5-door, will it have the same fitment issues? I want to get front/rear sways and strut braces soon but am finding conflicting info on fitment from other years/models. I ultimately want to add more suspension and brake bits so any links or input would be appreciated.
Dayglow is offline   Reply With Quote
Old 01-30-2011, 04:55 PM   #56
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
the front does fit with minor modifications
Old 01-30-2011, 11:33 PM   #57
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Suspension wise, the differences between our cars and WRXs are struts and springs and the WRX has a rear sway bar. The front sways for the WRX do not bolt right up. The exhaust for the turbo is routed differently and the front sway bars for the turbo cars do not bolt-up to the non-turbo cars without some issues. As Gonz notes, you can modify your exhaust a bit ang get the to work if you want a really big sway bar, but Rallitek makes a 22mm front bar for the NA cars and that's a pretty nice improvement over stock. Beyond the front sway, anything you can do to a WRX, you can do to your car.
Nothing much previous to 08 will bolt up to your car. Anything post 08 is likely to work. As the 08 cars moved to the 05-09 Legacy platform, some of the Legacy parts from those years may work, but the rear suspension was supposedly new for 08, so there isn't likely to be much there that is compatible.
For brakes, unless you are doing some crazy driving, some nice pads, stainless brake lines, and maybe a master cylinder brace are all you really need for DD. You could move up to Legacy GT front brakes if you really want bigger brakes and don't want to go with a BBK of some sort.
Ogden is offline   Reply With Quote
Old 01-30-2011, 11:36 PM   #58
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
I had an OEM WRX bar on my car for a while with Rallitek endlinks and it was a tremendous improvement over stock.
I've since moved up to Rallitek's set up for the NA Imprezas (front and rear) and I'm even happier, but if you want to keep costs down a used WRX bar is great bang for the buck. You should be able to find one for < $100, with endlinks.
Old 04-09-2011, 05:52 PM   #59
WANNABESTI
Member#: 279369
Originally Posted by thegonz View Post
i put a 22mm wrx sway on my 2.5i just took some small modification to fit
Can you please enlighten me with what mods you did. I put a 22mm Perrin WRX sway bar on my 2.5i and now the exhaust is bumpin up against it Grrr... I'm not sure what to do, so I'd appreciate any advice you can give.
WANNABESTI is offline   Reply With Quote
Old 04-09-2011, 09:12 PM   #60
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
If you don't want to modify the exhaust, you could sell your 22mm Perrin bar and get the 22mm Rallitek bar that is made for the NA cars.
Old 04-11-2011, 06:29 PM   #61
subi2.5i
Member#: 236778
08 Impreza
Hey I'm picking my swp '11 hatch up Wednesday. Im doing Red RA flaps, sport grille, hellas, paint tail lights red(can't stand Chrome) fog lamps, set of OZprodrives then from there work on suspension mods. Picking up '10 WRX interior tomorrow for it. Hope I gave u some ideas have fun
subi2.5i is offline   Reply With Quote
Old 04-23-2011, 10:21 AM   #62
Jokers9921
Member#: 280706
2011 Impreza Hatch
Dark Grey
Hey im in the process of getting a new 2011 Impreza Hatchback. Does anyone know what company's make exhaust systems for this car?
Jokers9921 is offline   Reply With Quote
Old 04-24-2011, 05:52 PM   #63
Neff 11 2.5i
Member#: 277410
11' 2.5i Wagon
From what I've read, any CBE from 08+ will fix. I'm hunting one for my hatch as we speak. Seem like so many people get new ones on their WRX's that we may be able to find something locally for CHEAP!
Neff 11 2.5i is offline   Reply With Quote
Old 04-24-2011, 06:04 PM   #64
Neff 11 2.5i
Member#: 277410
11' 2.5i Wagon
I also plan to get some OE WRX suspension from a 09' or 10', I hear that the 08' stuff is pretty squishy.The other option,which seems to look better every day, is putting in Koni Sport inserts and WRX springs onto the stock 11' 2.5i struts assembly.
Anybody wanna donate me your 09' or 10' WRX Struts and Springs????
Old 04-25-2011, 12:48 PM   #65
ejhayes76
Member#: 267923
2011 Impreza 2.5i
Have you done, or looked into, adding anti-sway bars? The 2.5i's don't have a rear sway bar. Adding a rear bar, and upgrading the front, are probably the best bang for your dollar suspension work on these cars. The WRX struts and springs are only marginally more firm than the 2.5i's.
Old 04-26-2011, 02:37 AM   #66
Neff 11 2.5i
Member#: 277410
11' 2.5i Wagon
It's really looking like some Koni inserts/shocks, Perrin rear sway any day now, and eventually pretty f'n flush 18x8's in matte black . That's all I need, but crap, what's "need" really have have to do with this??
Old 04-26-2011, 10:24 AM   #67
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Do the rear sway bar first. It's pretty cheap and makes a big difference. Maximizes bang for the buck. I would put the rear sway in the "need" category.
Exhaust: Read the exhaust sticky in the NA Forum. Tons of good information. You may still go against what the thread suggests, many people do on a quest for the right sound, but at least you will be informed.
Old 04-26-2011, 10:28 AM   #68
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Read the suspension stickies too in the suspension forum. It's ridiculously easy to make your car ride and handle like crap while trying to drop it on a set of big rims. Again, your car, do what you want, but at least if you read you'll get advice on the best way to do it and you'll know what you are getting yourself into.
Old 10-12-2013, 12:32 PM   #69
spikcdr
Member#: 370758
Default please help
Hey guys I have a 2.5i Subaru impreza its a 2009 4 door sadan. I was wondering if I can change my front bumper because its cracked and is a 4 year old car. I found another bumper same year its from a impreza but sti so will it work for my factory car can I swipe bumpers or something. Mine is damaged and the grill is cracked so ill be replacing that with mesh wire cover. So will this sti 2009 impreza bumper work? I'd show u a pic but I don't know how to insert one.
spikcdr is offline   Reply With Quote
Old 10-14-2013, 03:15 AM   #70
Devindwdw
Member#: 370793
And you just have a normal impreza?
Devindwdw is offline   Reply With Quote
Old 10-19-2013, 04:44 PM   #71
Brenner082.5i
Member#: 371383
Does anyone know any company's that sale exterior and performance parts for the 08 2.5i I'm looking to do basic mods, headers, intake, exhaust and lowering it about 1.5inchs please let me know thank you
Brenner082.5i is offline   Reply With Quote
Old 10-21-2013, 10:08 AM   #72
Welder_19
Member#: 371522
Any suggestions on an intake system for my bone stock '11 WRX Hatch?
Welder_19 is offline   Reply With Quote
Old 10-22-2013, 12:28 PM   #73
ejhayes76
Member#: 267923
2011 Impreza 2.5i
None. Don't bother.
Old 05-02-2014, 10:32 AM   #74
spikcdr
Member#: 370758
Default WRX body kits
Hi there I have a 2009 2.5i subaru impreza factory. I had my car for 5 years and it has 81000 miles on it. This winter my front bumper got damaged and I need a new one. But I have been thinking of a sti style but they are to big but someone said a 2009 wrx body kit will work my problem is how do I know it's the right kit. Can some one help me I love my car I don't need a new exhaust or engineering but since my front bumper got mangled I figure give my car new flare. Plus what size rims should I get 16 inch or 17.
Old 05-02-2014, 10:47 AM   #75
spikcdr
Member#: 370758
I found a body kit but will it work I have the link so please because It looks like my car and I really need a new bumper and rimms lol. http://www.duraflexbodykits.com/2008...-p-555478.html
This is the Link
my 2007 subaru impreza 2.5i akbibeau Member's Car Gallery 17 01-12-2015 11:04 PM
My new 2008 Subaru Impreza 2.5i 5-door deltableh Member's Car Gallery 60 06-01-2012 02:35 PM
FS 2008 Subaru Impreza 2.5i 5-door $15,400 What I owe still!!!!!!!! sower23 Private Vehicle 'For Sale' Classifieds 9 01-14-2010 03:49 PM
New to Subaru - Impreza 2.5i mountainman Newbies & FAQs 1 03-17-2009 11:37 PM
