Old 06-23-2002, 11:40 PM   #1
jeffg
Member#: 2958
2001 6.0?RS
Default AC removal q's
I am interested in removing the AC compressor and condensor from my 2001 RS. I am wondering if there will be any ECU problems with this. I know that the defroster wants to kick on the AC in order to dry the air, so there must be some sort of switch.
Has anyone done this?
J
jeffg is offline   Reply With Quote
Old 06-24-2002, 12:27 AM   #2
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
i have been wondering about that. but i came to the conlcusion that the actuall weight/ friction on the engine, when it is off, of course, is so minimal that it is not worth the trouble.
to answer your question: it shouldn't be a problem with the ECU just take the unit out, all the hoses, and the pulley, replace the belts with resized ones. and don't use your defrost mode!!
rupteur7000 is offline   Reply With Quote
Old 06-24-2002, 02:08 AM   #3
jeffg
Member#: 2958
2001 6.0?RS
I actually removed the AC belt and tensioner and noticed a very small improvement in acceleration. Almost like 1/4 of a crank pulley
Anyone know about the ECU reaction to AC removal?
J
Old 06-24-2002, 08:33 AM   #4
bender
Member#: 1839
I don't think that the weight savings would be that much. it's probably the same as taking out your spare and jack
bender is offline   Reply With Quote
Old 06-24-2002, 11:08 AM   #5
jeffg
Member#: 2958
2001 6.0?RS
The reason I am taking it out, is not really a weight one. Though the compressor is pretty heavy. Seriously, though, other than suggestions about why to take it out or not, does anyone know about actually doing it?
J
Old 06-24-2002, 12:57 PM   #6
Julian
Member#: 1182
MY00 RS
BRP
If you remove the system, the ECU won't throw a CE light or anything. Other than having no A/C, I wouldn't imagine there'd be any issues with removing it.
Julian is offline   Reply With Quote
Old 06-24-2002, 01:15 PM   #7
NGNIOUS
Member#: 11771
Blue w/LimoTints + Rotas
Default How?
Does anyone know how to remove it (like what should be taken out) or threads or links on how. I am looking into doing this but don't want to screw anything up.
:monkey:
NGNIOUS is offline   Reply With Quote
Old 06-24-2002, 01:20 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
removing a/c=biggest waste of time...sorry but i don't like to sweat or have my windows fogged up when i drive. A/C doesn't steal horse power and the total system wegiht is prolly around 40-50 lbs max....to me there are other place to lighten the car before this.
just my $.02
Old 06-24-2002, 01:21 PM   #9
Tim Smith
Member#: 19147
2002 Impreza RS
Alpine White
The A/C system from my '92 escort weighted in at 85 lbs. That is counting the parts of the dash that was used to route the air (not including the heater ones though), the conpressor, condensor, exchanger, lines, hoses, switchs, mounting materials, belt, pulley, wiring and a little body work that was beefed up at the fire wall. Quite a bit of weight and coupled with the reduced drag on the engine, I noticed a HUGE differance.
The spare and jack only weighted about 37.
Tim Smith is offline   Reply With Quote
Old 06-24-2002, 01:42 PM   #10
jeffg
Member#: 2958
2001 6.0?RS
At what point did anyone say they were removing it for weight savings? In the 2 years I have used my car, I have never once used the AC. The defrost in a concern, but I can deal with that.
Thank for the replies about ECU concerns.
J
PS: Just out of curiosity where would you remove weight from first?
Old 06-25-2002, 11:10 AM   #11
Julian
Member#: 1182
MY00 RS
BRP
Bang for the buck, remove the compressor and associated hoses, wiring, belt first. Easiest to accomplish.
Old 06-25-2002, 11:46 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
J
mount the battery in the passenger side of the trunk...that'll even out the weight distribution. Personally if i wanted to get rid of weight, i'd get seats(stock subaru seats seem to have pretty beefy supports)...then i'd get a nice driveshaft, then a nice set of wheels.
Jeremy
Old 06-26-2002, 04:01 AM   #13
Bimmer
Member#: 4116
2002 Impreza TS
Default Re: AC removal q's
J
This isn't my mod, but somebody else posted how to disable the automatic A/C with defrost function, there's a switch to disable (or a wire to cut) behind the HVAC controls in the dash. I think it was in a thread called "we need an electronics forum"
Anyways, they didn't report any problems after doing so...
IMHO, removing the A/C for a race car makes sense, but if this thing is supposed to remain streetable (and maybe eventually resaleable) I don't see the point...
If you wanted a Caterham 7 or something like that, then you should've bought one...
Ben
Bimmer is offline   Reply With Quote
Old 06-26-2002, 12:11 PM   #14
jeffg
Member#: 2958
2001 6.0?RS
Well resale value be damned anyway.
In order to fit the spinny thing I want to put in there, something has to go. Power Steering, dont think so. Alternator, prolly not. I guess it has to be AC. Not that I have even turned it on in the 2 years since I bought this car.
If it comes time to sell the car somehow, and I need to put it back in, it all just bolts up, easy as pie.
J
Old 06-26-2002, 12:49 PM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Default Re: Re: AC removal q's
Ben
that only applies to 2002+ impreza...the older ones has a user selsectable switch for the defroster. I just don't believe you need to remove the A/C in any car.
jeremy
Old 06-27-2002, 11:30 AM   #16
Tangmere
Member#: 572
Jeff,
I'm in the process of doing this on my STS-classed Impreza. Removing the AC from the car will save you 75lbs and thats a lot of weight off the front end. Combine that with moving the battery to the trunk and thats another 30lbs. Go to a gas station to have them evacuate the freon. Better for the environment. You will feel the difference in handling even if you're not doing it to save weight. You also might need to get the car aligned again. And whose (brand?) blower are you getting?
Mark
Tangmere is offline   Reply With Quote
Old 06-27-2002, 01:41 PM   #17
jeffg
Member#: 2958
2001 6.0?RS
I have access to a Rotax unit, but I think I am going to try for an Eaton M62. We will have to see what I can get to work.
J
Old 06-27-2002, 01:44 PM   #18
Giova
Member#: 1663
2000 Impreza RS
BRP
Giova is offline   Reply With Quote
Old 06-27-2002, 01:46 PM   #19
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
spare condensors=good things
Old 06-27-2002, 04:23 PM   #20
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Remove the "brick" from under the engine.
Jack up the car using a floor jack and the jacking plate on the frame cross member below the engine. Put jack stands in place. Lower the jack. Go to the plate that you just jacked the car up with. Remove the 4 bolts. Remove the plate. Below the plate is the "brick". Take it out, set it on your garage floor and put the plate back in. Amaze your friends by showing them the brick and asking them what it's for. I haven't yet weighed it, but estimate it to be about 5#.
There's reportedly another brick in/near the glove box. I have not yet found it.
As to moving the battery....my driver side weighs 1352#. Passenger side weighs 1350#. This was weighed at NHIS with 1/4 tank of gas and nobody in the car. Moving the batt would offset my weight some, but the added wiring will add weight.
jack
Old 06-27-2002, 04:44 PM   #21
jeffg
Member#: 2958
2001 6.0?RS
Since this is turning into a weight redeuction thread, here are the lightening mods that I have done already.
UoR crank pulley
Lightweight "racing" front and rear bumper beams
Brink removal - crossmember and glove box
90 visit membership to local gym - thought of this one while I was eating a Big Mac and taking the brink out of my glove box.
Old 06-28-2002, 03:57 PM   #22
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Jeff!
Where exactly is the glovebox brick??? I found out about the 2 bricks when I hosted a garage day...but nobody actually knew where it was.
jack
Old 06-28-2002, 04:14 PM   #23
jeffg
Member#: 2958
2001 6.0?RS
I assume you are talking about the brick in the glove box. If you sit in the passanger side of your car, open the glove box.
On the lid you will see several phillips head screws I think there are 6? Take out all the phillips screws in the lid. Make sure you rest the lid on your knees as you do this, so that you dont break it. After all the screws are out the dask cover piece will come off and you will see the metal plate. It is heavy and will just fall out. Watch your toes.
J
Old 06-28-2002, 06:05 PM   #24
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why are there bricks all over the place on the car? They must serve some function, I dont see subaru spending extra money on a useless item.
Old 06-28-2002, 08:36 PM   #25
obyone
Member#: 16523
Default Re: Re: Re: AC removal q's
jeremy
No offense or anything but I plan on removing the A/C on my Toyota. (when I get it fixed that is) It's just dead weight for that car anyways. No use in paying $700 for a new compressor and dryer when the car is only worth 8.
obyone is offline   Reply With Quote
AC removal newsubie05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-10-2008 12:29 PM
AC Removal/ Delete ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-14-2008 08:50 AM
removing AC, pulley question Blase M Normally Aspirated Powertrain 2 04-03-2006 11:03 PM
ac removal? scoobydrew06 General Community 2 03-30-2004 07:11 PM
auto AC removal mod? asianboy101 Electrical & Lighting 1 02-01-2004 07:10 AM
