Old 09-10-2010, 11:30 PM   #1
Camlee98
Member#: 66911
1998 Forester
Default JDM swap runs like crap HELP!
JDM 2.5 DOHC swap with a running USDM of the same.(Had oil leaks)
Used the intake and exaust mani, sensors, and accesories from the USDM.
Replaced Timing componets, Timing belt, spark plugs, wires, oil seperator plate and major seals all new.
Mech. was a subie tech for 15 plus years that opened his own shop.
Did the swap started it up and it runs like crap.
He checked the compression and it's 205 across the board. From what I've heard this is normal for a JDM engine.
Would love to hear from anyone who's done this swap and anyone else who has thoughts or suggestions on what the heck is going on.
Anyone know if the timing marks are the same for the JDM vs. the USDM?
Thanks for the help in advance!
Camlee98 is offline   Reply With Quote
Old 09-11-2010, 09:48 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Can you be more specific on "runs like crap"? Will it idle? If it won't idle on its own, will it run if you give it gas?
Old 09-11-2010, 02:18 PM   #3
JoshP
Member#: 94350
You swapped out an engine because of oil leaks?
JoshP is offline   Reply With Quote
Old 09-11-2010, 02:30 PM   #4
dr3w
Member#: 222318
1993 RHD GC8
I swap out my engine every oil change.
dr3w is offline   Reply With Quote
Old 09-11-2010, 02:47 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
If it has good compression, the problem is likely not with the longblock you bought. Something could be wrong with existing parts from old engine or installation problems.
You need to define crap. What is the exact issue?
Old 09-11-2010, 02:48 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
I've owned cars where that is almost the truth.
Old 09-11-2010, 03:14 PM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
MAF, O2, something like that, one part, crap operation if bad.
Old 09-11-2010, 10:05 PM   #8
Camlee98
Member#: 66911
1998 Forester
I'm not going to get into the changing the engine because of oil leaks it's a long story.
I haven't heard it run but he said it runs rough and as if it had a bad valve yet compression is good so no bad valves. He did tell me today that he never swapped the cam and crank postition sensors.(these are still jdm) Any idea if that would cause this? He feels that it shouldn't. He also said he doesn't get and codes but he does get a flashing check engine light?
Old 09-12-2010, 02:11 AM   #9
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
pull the code? and fix the issue. Seems to me like crank/cams sensors.
kewlboxer2 is offline   Reply With Quote
Old 09-12-2010, 10:21 AM   #10
Inane Cathode
Member#: 257508
Flashing check engine light is bad juju, something major enough to roast a cat out of the car. Have your mechanic pull the codes.
Inane Cathode is offline   Reply With Quote
Old 09-12-2010, 10:51 AM   #11
Camlee98
Member#: 66911
1998 Forester
I can only assume that he knows that the flashing check light is a code. I'm not sure why he didn't mention what that code was if he even looked it up? I'm gonna have to go tomorrow and mabey get some video to post up. Will just swapping the cam and crank sensors rule them out or is a bigger job then that?
This whole project has been BAD JUJU! I'm at the point now that if it doesn't get resolved I'm just gonna eat the cost of the engine and get one from a local yard and be done with it!
Old 09-12-2010, 01:18 PM   #12
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
If he pulls the code it will point him in the direction of where to go.
I think i read on here that the JDM cam and crank sensors are different then USDM. not 100% sure on that.
Old 09-12-2010, 02:30 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Swapping out the crank and cam sensors would seem to be a logical place to start, just to rule them out. I don't imagine they're the cause, either, but it should only take a matter of minutes to swap them.
The flashing CEL indicates a misfire, which I'm sure your 15-year Subaru mechanic knows. (Right?) That makes me wonder if maybe the trigger pattern on the driver side intake cam (the one that has the cam sensor) or the trigger pattern on the crank sprocket are different than the USDM ones. I didn't swap either of those when I did my JDM engine swap, but that doesn't mean that there aren't some JDM engines with different trigger patterns.
Old 09-12-2010, 02:34 PM   #14
AlaskanProtege
Member#: 217112
1998 GC8 modified
black and orange
Yea the computer will tell you where to look, if it the sensors the code most likely will be p0300 for random miss fires. (flashing light represents miss fires) if it's a valve issue you would have a individual cylinder code (ex p0301 cyl1 missfire) but it still could be something else. With out pulling codes and talking to the computer it's just guessing.
Possible causes for rough running after engine swap:
Bent pin on electrical connector
Faulting sensors/sensor compatibility(even trigger wheel pattern)
Faulty knock sensor-personal experience
Intake leak or Leaking intake gasket
Poor grounds
(un-proper spark plug gap or "dropped"/ damaged plugs) I've gotten bad ones out the box! WTF.... napa!
But it could be anything really. Remember it's just nuts and bolts...and Bad juju is for chevys haha
I hope you figure it out and let us know how it goes!
AlaskanProtege is offline   Reply With Quote
Old 09-13-2010, 12:08 PM   #15
Camlee98
Member#: 66911
1998 Forester
I spoke with the mech. this morning. He's gonna swap out the cam and crank sensors today and try it. If that doesn't do it he'll then swap the crank sprocket and so on. I hope this does it! Thanks for all the input!
Old 09-13-2010, 06:48 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
He screwed up the timing when he did the timing belt. What you are describing to me sounds like it's off a tooth.
Old 09-13-2010, 08:59 PM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
I would have him swap the cam gears and crank gear and then retime it. Assuming the code is not specifically for cam or crank sensor failure (which will also flash the CEL light), the flashing CEL is most likely misfiring due to incorrect timing.
Jay
Old 09-13-2010, 09:33 PM   #18
Camlee98
Member#: 66911
1998 Forester
That's the plan Jay. I figure we can start with the least expensive item. (The sensors) I know my sensors are good bought new last year. Then if that doesn't work he's swapping cam and crank gears. I'll know tomorrow if it was a success!
Old 09-14-2010, 06:49 AM   #19
Storm
Member#: 5218
96L Most Over-
Developed Beater
Food for thought, one wrong twist when removing an otherwise good cam/crank sensor will break it inside.
He can visually compare the crank timing gear (counting the reluctors) and likely checked the reluctor layout on the camgear, but it never hurts to double/triple check, especially when problems arise from an otherwise straight forward swap.
Jay
Old 09-14-2010, 01:32 PM   #20
RaineMan
Member#: 256727
2007 2.5I Wagon
Your steering wheel is on the wrong side and the engine knows it. You confused the crap out of the poor thing.
RaineMan is offline   Reply With Quote
Old 09-14-2010, 02:46 PM   #21
basel_520
Member#: 257798
I might have only owned my subaru a couple of months and never drove it. Ive done a few engine swaps on MR2s and supras. If someone came up to me and said my MR2 runs crap. I would tell him, check your MAF, check your Timing and check your coils (distributor). first pull codes. sometimes most handheld OBD readers wont read those JDM ECUs but the dealerships OBD reader can. call them for a quick CEL code check.
basel_520 is offline   Reply With Quote
Old 09-15-2010, 01:16 PM   #22
Camlee98
Member#: 66911
1998 Forester
Spoke with him today he swapped the sensors last night and as expected had no luck. He's gonna pull the usdm cam and crank gears and see if the triggers match up. I hope they don't that would give me a little hope that swapping them will solve the issue.
Old 09-15-2010, 05:52 PM   #23
Matt Monson
Member#: 832
99 2.5RS, '85 911
Do you have a picture of the motor. I can tell you just by looking at it.
Old 09-15-2010, 06:21 PM   #24
Camlee98
Member#: 66911
1998 Forester
Matt No I don't and his shop is about 30 mins from home. Have you had a JDM engine with a different trigger pattern?
Old 09-16-2010, 04:02 PM   #25
Camlee98
Member#: 66911
1998 Forester
Well he pulled the crank and cam gears from the old engine and matched them up to the new engine. They do match up so this is not the cause. He's going to do a leak down test and another compression test tonight to see if he missed anything the first time. He and myself are out of ideas. If anyone has anything else or would like to talk with him PM me and I'll give you his number. He's open to speaking with someone who has swapped these engines in the past. I'm at the point where I need to either have my old engine rebuilt, buy another used engine, or find out what's causing this issue. It's gonna be a shame to have to scrap a $1000 dollar engine but I'm not sure I have a choice anymore!
Swapped O2 sensor on 04 STi...car runs like crap wo^tron Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 03-25-2010 10:11 PM
2.5RS running like crap---help bbaxj Normally Aspirated Powertrain 7 11-02-2008 01:20 AM
My EJ22T is running like crap...HELP? Kawikid20o2 Pre-2002 Factory Turbo Powertrain 22 03-25-2007 05:33 PM
my car is running like crap HELP! Texy32 Texas Impreza Club Forum -- TXIC 28 01-21-2007 11:14 PM
swap started running like crap... Homemade WRX Subaru Conversions 11 11-10-2005 09:30 PM
