Old 09-11-2010, 03:10 AM   #1
supranite90
Member#: 240847
2004 WRX
Default hybrid motor problems?
I've been in the tuning scene for a bit, but being this is my first Subaru I have a question I would like answered, no matter how complicated the answer may be. So my question is, what would be the main problem/thing to look out for when building a hybrid motor? This is with an 04 wrx and the shortblock i will be using is coming out of a 2.5 Legecy...
supranite90 is offline   Reply With Quote
Old 09-11-2010, 04:32 PM   #2
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
1st off how much power are you looking to make & what is your budget?
I am not an engine builder, but I have been running a hybrid for over 2 years. I would have to say the biggest issues are compression, clearences (piston/wall), oiling, and knock/detonation.
For compression you will need a thicker headgasket or better yet contact Equillibrium Tuning for their services. For clearance you will need the right pistons, personally I have custom spec CPs. Oiling issues can be helped both with the right clearances and a good oil pan and pickup (06+ Sti pan and killerB pickup). Lastly, knock/detonation should not be an issue if you have a really good tune and run the right compression.
csmithwrx'05 is offline   Reply With Quote
Old 09-12-2010, 02:43 AM   #3
supranite90
Member#: 240847
2004 WRX
well i'm gunna be only pushing maybe 18 - 20 psi on the tdo4 if it (the turbo) can handle it. i'm not looking for big power atm just something reliable because its my daily and I'm having a hard(ish) time finding a EJ205. Plus the labor/parts is gunna run me about the same amount anyways i decided to go hybrid. Will i need to swap out the pistons or should i worry more about the compression?
My 2.5 hybrid motor wont start! Help codered Factory 2.0L Turbo Powertrain 86 09-09-2005 05:51 PM
My 2.5 hybrid motor wont start! Help ebeck Subaru Conversions 3 06-05-2005 07:51 PM
hybrid motor? scoobyimpreza Subaru Conversions 1 04-25-2005 12:29 PM
Parts needed for 2.5/wrx hybrid motor?? Why cant I find it... Davenow Subaru Conversions 7 04-15-2005 03:38 PM
Would anyone interested in buying a 257/205 hybrid motor? TexRex2002 Texas Impreza Club Forum -- TXIC 2 04-11-2005 08:28 AM
Message Board Statistics All times are GMT -4. The time now is 10:00 PM.
