Old 09-11-2010, 09:27 AM   #1
huzidada
Member#: 241360
2002 JDM V7 STI
Default V7 EJ207 Rebuild
Hi. You might have heard about my engine troubles from my spun bearing thread. I felt the info was too confusing there. I have PM'd the mods to delete it.
Well here are pictures of all the damage. The crank needs to be replaced, as well as one of the conrods. My main concern right now are the pistons and the walls. I have already rebored to 92.5mm from my first build, and am worried a hone wont be enough for the scorch marks, and I might have to go 93mm. Also there seems to be lots of carbon deposits on the piston tops. BAD FUEL ? (95 RON) or too rich a tune? Also note the engine was built by Subaru, and you can see the S#@T quality build.
huzidada is offline   Reply With Quote
Old 09-11-2010, 09:30 AM   #2
huzidada
Member#: 241360
2002 JDM V7 STI
Old 09-25-2010, 06:00 PM   #3
huzidada
Member#: 241360
2002 JDM V7 STI
Guys, besides a tune, and bolt-ons like exhaust, intake, fuel pump, I want to keep this car standard(turbo etc). It must be a fun daily driver. Wit that in mind do you think I should rebuild the motor or just replace with a low milage OEM motor? Im scared of the build, and feel a OEM motor will rev to the 8K mark smoother and better built then the built motor. Maybe just upgrade oil pump.
Old 09-25-2010, 08:40 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
If you have the funds there is nothing wrong with a low mileage stocker
seanathanq83 is offline   Reply With Quote
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Starting my EJ207 rebuild, pics and questions Hyper Built Motor Discussion 9 03-12-2009 10:53 AM
FS: v7 EJ207 motor, L to v7 STi merged harness, EWG exhaust package. DoctorNick Engine/Power/Exhaust 1 04-09-2008 02:58 PM
Warehouse Clearance - JDM STI V7 EJ207, JDM STI V7 Hybrid, JDM EJ205 AVCS!! Gruppe-S Engine/Power/Exhaust 24 01-09-2007 10:07 PM
v7 ej207 with pe1820. cronic Subaru Conversions 10 09-20-2003 04:58 PM
Message Board Statistics All times are GMT -4. The time now is 11:32 AM.
