Old 09-11-2010, 06:30 PM   #1
ansetou
Member#: 136402
Default After New Battery Idle Speed Goes Very Low
So my dad's 06 impreza wagon has been having problem such that it runs fine but every morning he'll need a jump to get it started. I measured the voltage and got the following results:
off: 12.9 v
idle: 12.5 v
2000 RPM: 13.9 v
Therefore, I draw the conclusion it's the battery that needs to be replaced. However, after i got a brand new deka ultimate group 35 battery and installed it, the idle suddenly goes to almost nothing. The car starts w/ trouble but it'll start. I suspected the battery and brought it back to the store and they showed me everything is w/ a battery meter. And what puzzles me more is I put his old battery back on and now it also has the exact same very low idle (near 0 and car shakes) speed problem.
any idea? did I accidentally screw up something? did I need to reset something? please help. thanks.
ansetou is offline   Reply With Quote
Old 09-12-2010, 02:43 PM   #2
Twigster
Member#: 225057
09 WRX STI
WR Blue
I believe this is a normal issue whenever you replace a battery on a newer vehicle nowadays. Same thing happened to me when I replaced the batt on my wife's camry. The ECU needs time to re-learn the engine settings when it is reset and it will eventually resolve itself after a few minutes/miles of driving. I just drove it around the block a few times and now everything is fine. Darn cars are too smart for there own good!
Twigster is offline   Reply With Quote
Old 09-12-2010, 04:18 PM   #3
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
^^^^^^yup, what he said.
If all you did was replace the battery then it might just be that the ECU is re-learning. The ECU has been resetted so just give a drive for a bit and see ir the problem continues.
I'd say go for at least 100 miles of normal driving.
Just make sure your air filter has been maintained recently just so your ECU doesn't have to compensate for a dirty filter. Maybe even clean your air flow sensor with MAF cleaner.
Henry H is offline   Reply With Quote
Idle Speed Target Tables Question cshepherd Open Source Reflashes 7 09-12-2010 05:39 PM
CEL with flashing cruise after new battery install mslstixx Electrical & Lighting 7 08-31-2009 08:55 PM
Help 03 WRX wont start after new battery! newgensti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-20-2009 01:58 AM
Replaced my battery after 84000 miles, idles very low now... captaind Service & Maintenance 2 07-30-2008 09:05 AM
Car runs like crap after new battery Ryan314 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-22-2007 03:58 PM
