Old 09-12-2010, 09:54 AM   #1
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
Default 2.5 with JDM Legacy N/A heads
This is my first Subaru build and its going allot better then past hybrid builds I have done with VWs. I have no HP goals I just want it to run.
This start I have a rebuild STi block from Outfront Motorsports. I have been working with Jeremy there and he is an AWESOME guy that knows his stuff.
I’m using 2003 JDM N/A Legacy RS25 PHASE II heads, the ports on these heads are huge compared to my 06 heads but it does bump compression up to 9.5:1 but my math sucks.
I'm using 07 Sti cams with the sensor keyway extended to match the cam sensor hole in the JDM heads.
Parts list.
257 Sti blockhttp://www.outfrontmotorsports.com/
OEM 2007 Crank
OEM Rods
Mahle 8.1:1 forged pistons
ARP studs
11mm oil pump
Custom SS AVCS lines were needed.
Deatsch 1300 CC Injectors flow chart says 1380cc
Walbro 255
P&L Motorsports big maf housing
2002 JDM Legacy RS25 PHASEII heads
07 Sti cams with sensor notch extended.
SBR GT-11 BB 52lb turbo
Synapse 40mm EWG
SPT 3" cat back
Invidia 3" catless V2 DP.
Intercooler
Air to water Type 14 IC from http://www.usrallyteam.com/
24x7x2 heat exchange
10" ice tank.
Meziere WP136S pump
Koyo STi Radiator
Samco hose kit
165deg thermostat
Flex-a-lite #420 fan
Group N Motor mounts and pitch mount
Group N Trans mount.
Trans parts will be here next week the 5speed lasted 5 weeks and 3500 miles.
2008 STi 6MT
SPT shifterlinkage
R160 rear
Excedy Twin disc
WRX automatic shaft
Still need to order DCCDPro and VSSPro.
PoZeR is offline   Reply With Quote
Old 09-15-2010, 04:13 AM   #2
Overboosting04
Member#: 202417
Wrx Stock EJ207
[email protected]
sweet build man cant wait to see it done
Overboosting04 is offline   Reply With Quote
Old 06-05-2011, 04:09 PM   #3
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
Old 06-05-2011, 04:14 PM   #4
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
At this point I blew the stock 5speed and I ordered the 6MT but I can say it’s a blast to drive.
I have it hitting 20psi and bleeding to 18psi, AF is 7.5, I haven’t touched timing or AVCS and this is on E85.
I don’t like the virtual dynos very much because you really never know how accurate they are but it does put a smile on my face. When I get the trans in I will be making an appointment with P&L to get JR to tune it correctly and post a real dyno.
Interesting car - Factory phase two 2.5 with DOHC heads and phase 2 4eat SUS! ciper Normally Aspirated Powertrain 13 11-17-2009 07:22 PM
n/a 2.5 with 2.2 heads sollersatv Newbies & FAQs 2 01-03-2009 10:09 PM
1997 Dohc 2.5 with 1997 2.2 Heads? narib2001 Normally Aspirated Powertrain 3 01-23-2007 01:01 AM
2.5 with Ver8 heads with green dynoed to day scooby-stu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-10-2006 12:07 PM
2.5 with JDM v8 heads LIQUIDSK8S Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 11-07-2005 11:07 PM
