Old 09-12-2010, 11:33 AM   #1
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Default Inside windshield issue, un-removable residue?
Hi all,
My GF recently got a new car and the windshield has something on it, it looks like it may have come up through the VENTS.. like maybe the heater core went??
Whatever it is, it won't come off with solvent's.. It's looks vapor like, almost like a glass shower door that never comes completely clean.
You can REALLY see it at night, it distorts the light..
Any thoughts??
Old 09-12-2010, 11:44 AM   #2
06_Scooby
Member#: 213103
2006 WRX TR
I think i know what your talking about. My car as well as my gf's car has the same problem... the only thing that i found that helps is just to get a dry micro fiber towel, or any towel and scrub hard w/ no cleaners... when i did it, it removed most of that junk.
Also, it might help to do it on a cold morning, when there's a little condensation on the inside glass.
06_Scooby is offline   Reply With Quote
Old 09-12-2010, 12:36 PM   #3
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....off-gassing of the plastics/materials in the interior. My new Challenger is one of the worst I have encountered as far as the rear glass is concerned. The residue is quite stubborn and I'm still wrestling with it to be quite honest. .....it doesn't help that the angle and location makes it difficult to clean regardless. Some cars are simply worse than others IME. As for the other windows, it simply takes quite a bit of scrubbing/effort with a towel as mentioned. The initial residue may need something else though to cut through. In most cases an APC or solvents have worked for me. Unfortunately, you're somewhat limited as to what you can try since it's on the interior of the glass. ....and the last thing you want to do is make a mess. If I run across something in my quest for a solution to my rear window woes, I will definitely let you know.
Kean is offline   Reply With Quote
Old 09-13-2010, 05:12 PM   #4
subyrail
Member#: 257700
thats all I use also
subyrail is offline   Reply With Quote
Old 09-13-2010, 05:26 PM   #5
RaineMan
Member#: 256727
2007 2.5I Wagon
Use a damp chamois. That is the only thing I've found effective for removing the "haze" without streaking.
RaineMan is offline   Reply With Quote
Old 09-14-2010, 01:14 AM   #6
tedward88
Member#: 235474
2008 Legacy GT
if the above doesn't work, and any cleaning you do doesn't work, the glass may have a defect, I've read a thread about a windshield that had defects that have..."stuff" in the glass so it doesn't look crystal clear which the OP eventually got the windshield changed
tedward88 is offline   Reply With Quote
Old 10-20-2010, 04:49 PM   #7
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Thanks guys, still no luck though..
Old 10-20-2010, 04:57 PM   #8
twilightx
Member#: 245305
2007 Impreza 2.5i
Newport Blue Pearl
I have the same thing...even when you hit it with Stoners Invisible Glass the stuff comes back a week or two later. I just keep cleaning it hoping it'll diminish with time.
twilightx is offline   Reply With Quote
Old 10-20-2010, 07:42 PM   #9
classicaddict
Member#: 220619
04 wrx wagon
use this. it is a chore trust me. my car has some sort of hard water stains i couldnt even get off with a razor blade on the inside. this metal polish states on the back that it polishes glass too. you have to put some ass in to it and it will leave a horrific oily stain. let it dry for about 15min or so and thus begins the 3 to 4 attempts of cleaning the glass with invisible glass (or the kick ass glass cleaner that subaru makes that i steal from work, it is also a chrome polish!)
classicaddict is offline   Reply With Quote
Old 10-20-2010, 08:08 PM   #10
2:43AM
Member#: 190273
05 WRX evoIII-16G
Tell me about it. The residue that haunts. Personally, I think Stoner's is part of the problem, however. I know the stuff is equivalent to walking on water in this community, but I never remember this problem on any of my old cars using Windex. Curses to tint!
2:43AM is offline   Reply With Quote
Old 10-21-2010, 12:30 AM   #11
SuperQueen
Member#: 259187
engine coolant coming through the vents? Thats a B.
SuperQueen is offline   Reply With Quote
Old 10-21-2010, 11:12 AM   #12
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Right on, have it, will try..
Someone else on another forum mentioned something like this.. hmmm.. No issues with the heat, that I know of, or coolant level..
Old 10-21-2010, 11:58 AM   #13
Kean
Member#: 25187
'08 Foz Prem TGM
....I highly doubt that's it. It is far more likely that it's the plasticizers in the materials/components of the car that is causing it as I mentioned before. IME, sometimes the initial film/residue can be a little more resilient and difficult to remove (always leaving streaks, blotches, etc. no mater how hard you clean). Once you get the surface of the glass clean though, I have found that it is easier to maintain and the off-gassing eventually diminishes to the point where it is no longer such an issue.
I hope the metal polish works for you. I would suggest throwing a towel over the dashboard though when working on the windscreen. ....you don't want the polish or applicator to accidentally contact it and possibly stain the surface/finish.
Old 10-21-2010, 01:18 PM   #14
nobletea
Member#: 169623
2008 2.5i 5d 100k+
Dark Grey Metallic
I had to clean mine several times the first few months, but it came off without too much trouble for me. I also figured it was plastics, and it eventually went away.
I've read that a dealer will clean it for you, if you dare.
nobletea is offline   Reply With Quote
Old 10-23-2010, 12:03 AM   #15
ormandj
Member#: 250931
2011 5-door STi
Careful about vinyl shine/etc, the sun will cause it to coat the inside of your windshield. Used to happen to me all the time when I used armor all (I know...) - now I just clean the vinyl and use a very light coat of vinyl protection.
ormandj is offline   Reply With Quote
Old 10-24-2010, 08:30 PM   #16
omgwrx
Member#: 137561
BLUE!
vinegar will work..
im not joking at all .. use some white vinegar .. yes i know it smells like crap .. it will streak a little but just kind of use a dry paper towel and "buff" off the residue .. .. least it has worked for me every time .. idk how it works on tint i haven't tried it i wouldn't either .. but really give it a shot its like what 2bucks
omgwrx is offline   Reply With Quote
Old 10-25-2010, 05:47 PM   #17
classicaddict
Member#: 220619
04 wrx wagon
Originally Posted by omgwrx View Post
vinegar will work..
vinegar and even the fumes will eat away the tints adhesive. i would not use that same with ammonia.
Old 10-26-2010, 02:16 AM   #18
Inspectorlee
Member#: 92725
2004 WRX
I was about to suggest using one of those Mr. Clean Magic Erasers, but I'm not sure how safe that is on glass. I'm gonna try a spot test this week just to find out.
Inspectorlee is offline   Reply With Quote
Old 10-26-2010, 08:54 AM   #19
Teehsee
Member#: 229300
2011 obp wrx hatch
08 dgm fxt
Use a vinegar solution, maybe 1 part vinegar, 2 parts water. I used it occassionally for this problem. Obviously wipe everything down as much as you can afterwards and make sure its dry. Follow with a cleaner of your choice. I never had a problem with it eating my tint with this method.
Also, you may want to try an old clay bar those things work wonders for several issues.
Teehsee is offline   Reply With Quote
Old 10-26-2010, 09:14 AM   #20
highjumpharry
Member#: 166834
02 WRX
I have this problem too. Ill try a couple of these solutions to see if they help. I would not try the magic eraser though. It works by creating microabrasions not good for glass.
highjumpharry is offline   Reply With Quote
Old 10-26-2010, 05:36 PM   #21
classicaddict
Member#: 220619
04 wrx wagon
i found that out lol. used it on my headlights! but the cleanup guy at work did a quick polish and wax and now they look even better than before! so definatly dont use a magic eraser on paint! it may be ok on glass since its so hard, try a tiny spot first.
Old 10-27-2010, 05:41 AM   #22
ChrisinCA
Member#: 262077
Im taking delivery on-new WRX and was wondering if this interior window haze is something i should expect or a "10%" thing..?
Any thoughts on things I could maybe do to keep it from happening..? Ill be parking nightly in my garage -- maybe keep the windows rolled down to let any possible vapors let off by the new plastics roll out of the car rather than get bottled up 8-10 hours a night..?
Thoughts..? Expectation setting..?
ChrisinCA is offline   Reply With Quote
Old 10-27-2010, 10:36 AM   #23
Kean
Member#: 25187
'08 Foz Prem TGM
YMMV, but IME this has been an issue with every new car I have purchased in recent years. Yes, you can try leaving the window(s) rolled down to see if that might help but expect that you will begin to notice the haze likely every 1-3 weeks (depending on your tolerance level). As time goes by however, the degree of haze diminishes as does the need to clean it off. In most cases I have noticed a fairly dramatic drop-off in the fist 3 or so months and then a slow regression until it finally becomes almost a non-issue. Either way, you’re going to have this problem in almost any new car you buy these days (to some degree or another).
Old 11-20-2013, 06:10 AM   #24
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Hey guys, reviving the dead... again.
I've just had a new windscreen installed, which may be a coincidence, as I also live in the tropics and we've just had our first rains of the summer, but I have the dreaded film.
I've not had a go at it yet, aside from using windex and some special windscreen wipes (see: not that special), but I was just wondering what people have used to remove the film from "off-gassing" or "vinyl fog"?
This is not a new car, although I am pretty liberal with the protectants and whatnot (love my car).
I recently bought a new diving mask for snorkelling and the guy who I bought it from recommended using white toothpaste, the gritty type, specifically NOT the gel...
And scrubbing the hell out of the glass on the mask with it.
I thought that was rather obscure, but several divers have since confirmed it, with some even recommending using n actual toothbrush to scrub it in with.
Perhaps this could work on my windscreen? Food for thought, anyway.
Other suggestions I've heard include acetone and even steel wool in a very fine grade.
This one seems to cause the biggest arguments, despite glass being physically harder than steel. I've spoken to a few detailers who say throw a towel over the dash and use acetone and 0000 steel wool and then windex or something to clean it...
Sounds like a bit of a mission, what are people's experiences?
What works best / easiest?
my0six is offline   Reply With Quote
Old 11-20-2013, 01:34 PM   #25
NismoSkylineGTR
Member#: 94622
I have the problem on my rear windshield doesn't come off u can only rub real hard and hide it until next cleaning
NismoSkylineGTR is offline   Reply With Quote
Tint Removal Residue??? Bluestreak2006 Car Care & Detailing 15 02-19-2008 09:11 AM
Heated Windshield issue DatboyB General Community 3 01-15-2006 02:45 AM
Inside Windshield Cleaning Problems hwy61 Interior & Exterior Modification 27 09-29-2005 02:08 PM
'02 WRX Windshield Issue Quarters Service & Maintenance 9 09-27-2004 09:08 PM
Inside Windshield Banner? RichinAZ Interior & Exterior Modification 3 02-08-2002 08:48 PM
