Old 09-12-2010, 12:20 PM   #1
19gda
Member#: 211135
2007 EDM WRX
Orange
Default Head n block
Hi,
I am doing a hybrid setup but I was influenced by eq. Tuning to machine the 207 head to match the 255 block. Hoever, I bought the hybrid piston from je. Should I install them? Will it lower my compression further? Runing sti gasket. Is it a good idea to run hybrid je piston on machined head ? Thx
19gda is offline   Reply With Quote
Old 09-12-2010, 04:58 PM   #2
19gda
Member#: 211135
2007 EDM WRX
Orange
bump for builder
Old 09-22-2010, 07:12 PM   #3
ScoobyBoobie
Member#: 236131
IIRC, JE stock size bumps the CR up a hair. STI stock CR i believe is 8.2:1. The JEs will bring it up to 8.27. With WRX heads and 1.5mm HG you should be in the stock WRX CR if not just a little over.
ScoobyBoobie is offline   Reply With Quote
wrx heads/sti block, current wrx heads ej20g 4banger4dr Built Motor Discussion 6 11-14-2009 03:55 PM
Hybrid setup build parts - EJ20 Block & Heads, EJ25 Block, 02 WRX Tranny parts... WRenXhaven Engine/Power/Exhaust 18 07-11-2009 10:46 AM
Sti Harness Wrx Heads Wrx Blocks Sti Heads Junior2JZ Engine/Power/Exhaust 6 01-17-2007 12:13 PM
WRX Turbo Heads & Block Saleen99_00 Private 'For Sale' Classifieds 0 03-08-2004 09:13 AM
o-ringing: heads vs. block? racerwad Normally Aspirated with bolt-on Forced Induction Powertrain 12 04-18-2002 05:55 PM
