Old 09-12-2010, 01:45 PM   #1
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Default Camshaft degreeing on built heads (non AVCS)
Hey guys, I have been building a EJ22T block with 2.0L heads, +1mm valves, Kelford drag cams etc etc.
I have had my pistons made to have the same deck height as a stock ej20 to be able to use the same thickness HG. I have assembled the long block and wanted to double check my valve to piston clearance and I quickly found out that my intake valves are hitting the pistons. I spoke to my builder and he had mentioned that we can cut the valve reliefs in the pistons a little bit larger or have the Cams degreed to the proper cam card specs which may give us the clearance we need. He highly recommends this route and says there are a few ways in making some small changes to the cam degree without buying adjustable cam gears.
I have spend countless hours trying to find the procedures on degreeing our cams but have had no luck for the boxer engine. For the money invested in peoples built heads I know there has to be someone who could chime in on how to get the most out of this investment.
There have been many older post of members requesting this information as well and i think this should be incorporated in the FAQ.
cribbie is offline   Reply With Quote
Old 09-12-2010, 05:38 PM   #2
cribbie
Member#: 184505
2003 WRX
Sonic yellow
Here are a few pictures of my issue:
Old 09-12-2010, 05:42 PM   #3
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
wow those valve reliefs are tiny I would just have the machinist flycut the relief deeper and wider and be done with it.Its not going to take much maybe .060-.080.
john 1badSTI is offline   Reply With Quote
Degreeing a camshaft - how to measure valve position. 2milehi Built Motor Discussion 7 08-13-2011 09:22 PM
Looking for Spec book (1999 EJ25 DOHC) Roadrace1999 Newbies & FAQs 0 06-17-2006 05:43 AM
WTB - EJ25 (Phase 1 - DOHC) Crank or Shortblock MY99 2.5GT MAIC Private Classifieds 1 06-12-2006 04:02 PM
What is the upper limit HP for the stock (phase 1 2.5 DOHC) connecting rods? not8player Built Motor Discussion 6 05-09-2006 01:07 PM
What model had the Last Phase-I (2.5L DOHC) engine? KC Normally Aspirated Powertrain 5 01-08-2003 11:22 PM
