Old 09-12-2010, 01:55 PM   #1
bogey1
Member#: 183009
2004 Fozzy XT
Storm Trooper White
Default 02 EJ205 to EJ207 ecm/ecu change
So, what is involved in doing this change over? Do you need to completely redo the wiring with the JDM wiring, or can you use the existing USDM wiring with a little modification?
I am asking because Im in the process of doing a motor and weighing the cost of an EJ207 and just using the block and heads, or doing the whole change over. Thanks in advance,
Shawn
bogey1 is offline   Reply With Quote
Old 09-12-2010, 03:08 PM   #2
19gda
Member#: 211135
2007 EDM WRX
Orange
Ej207 has AVCS ..
also ,the rom file btw them can't be interchanged .
if u have time to source out the difference in the wiring , then I think it could work .
at least , you need to figure out the AVCS first...
thanks.
19gda is offline   Reply With Quote
Old 09-12-2010, 03:55 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
you keep your wiring and add 8 wires of AVCS
IA performance sells the kit
might need to twist few things around
search in conversions
Hyper is online now   Reply With Quote
Old 09-12-2010, 05:25 PM   #4
bogey1
Member#: 183009
2004 Fozzy XT
Storm Trooper White
Cool, thanks
-shawn
Old 09-12-2010, 05:58 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
DS1 has a write on the how to
Old 09-13-2010, 02:27 AM   #6
bogey1
Member#: 183009
2004 Fozzy XT
Storm Trooper White
found quite a few good threads on the topic. Looks like fairly simple change over.
Old 09-13-2010, 10:18 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
what he said!! it is a very simple wiring swap but can't remember the exact ins-outs
search it and you will find some OLD stuff on it.
convert ej205 to ej207? 16gsuby Built Motor Discussion 18 05-20-2008 12:38 PM
FS: New UTEC Delta for sale.. 02-05 WRX EJ205 & EJ207 74KILLER Engine/Power/Exhaust 2 01-18-2008 06:51 AM
02 usdm ej205 to early ej207 swap questions dukeduster Subaru Conversions 4 11-20-2007 02:04 PM
Ej205 to jdm Ej207 swap question. Wrx1234 Subaru Conversions 19 03-19-2007 12:37 AM
Speed (MPH) difference in EJ205 and EJ207 MK19_ Newbies & FAQs 21 06-18-2004 12:36 AM
