Old 09-12-2010, 04:01 PM   #1
lemmonsqueeze
Member#: 244382
Default license plate scratching paint
not sure if this is the right section, but here goes:
Anyone who has their license plates mounted with just screws might want to adjust the mounting method.
I only had two screws in the rear plate, and it rattled around a lot. It has worn through the paint.
I have since used washers to keep the plate away from the car, and two more screws to make it more secure.
also on the front:
anyone else have this problem? I haven't seen any posts about this yet.
lemmonsqueeze is offline   Reply With Quote
Old 09-12-2010, 04:06 PM   #2
speakerpimp
Member#: 241673
2011 WRX
Spark Silver
Yes I recently discovered I'm experiencing the same thing
speakerpimp is offline   Reply With Quote
Old 09-12-2010, 05:11 PM   #3
d0ugch0i
Member#: 198861
2004 WRX
get a plate frame? its almost inevitable to avoid those scratches you'll have to learn to just live with it. its hidden anyways.
d0ugch0i is offline   Reply With Quote
Old 09-12-2010, 05:46 PM   #4
Frank_Zuccarini
Member#: 88939
2011 WRX STi Hatch
World Rally Blue
I put a glob of 'Shoo Goo' on the four back corners of the plate, and let it dry before mountng. It seems to stabilize things (no rocking or vibrating) and prevent scratching/rubbing.
Frank
Frank_Zuccarini is offline   Reply With Quote
Old 09-12-2010, 05:51 PM   #5
Subr-man
Member#: 169211
into a gearhead."
Goin' Back Old Skool
^ This except i cut little rubber pads that go on the bottom of dining room in half and they were the perfect contour of the plate corners, and they are self adhesive.
Subr-man is offline   Reply With Quote
Old 09-12-2010, 06:25 PM   #6
vms150
Member#: 172917
2004 WRX
I don't want to sound like an a-hole, but who cares? It's under the place all the time anyway and it's not going to cause rust issue because the bumpers are plastic.
vms150 is offline   Reply With Quote
Old 09-12-2010, 09:34 PM   #7
lemmonsqueeze
Member#: 244382
I just wish I would have known when I bought my car since it's so easily avoidable. Plus the one on the back of the newer generation is metal
painting license plate area on the rear?? Unrealgtx Interior & Exterior Modification 30 07-07-2009 12:59 PM
Carbign Craft Dry Carbon Rear License Plate Backing plate Haven Exterior/Styling 13 10-19-2007 09:52 PM
Front License plate mini-plate? Nixlimited Interior & Exterior Modification 5 07-02-2007 07:20 PM
front license plate delete plate suBerSam Interior & Exterior Modification 10 01-12-2007 07:48 PM
