Old 09-12-2010, 05:47 PM   #1
afcivileng
Member#: 108494
2005 WRX STi
Crystal Gray
Default Engine Missfire after clutch install
I have a 99 Rs I just replaced the clutch with a lightened flywheel. Now I am getting all kinds of missfire codes, intermittently on various cylinders. I replaced my timing belt and spark plugs while i got the clutch redone. I have heard that a light weight flywheel can cause this. Could it be anything else? can I change the timing to make it work?
Thanks
Chuck
afcivileng is offline   Reply With Quote
Old 09-12-2010, 11:21 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
make sure your valve lash is correct, this can also cause misfires. And search, search, search.
grinding sound and engine drag after clutch installl DemiSlayer Transmission (AT/MT) & Driveline 4 06-29-2007 08:12 PM
missfires after clutch and flywheel install DemiSlayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-08-2007 12:27 PM
CLutch issue after clutch install jawwadh Mid West Subaru Owners Club Forum -- MWSOC 16 06-05-2006 01:07 PM
P0136 CEL after Clutch install 02GatorWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-09-2002 12:08 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-11-2001 11:35 PM
