Old 09-12-2010, 07:14 PM   #1
oracle
Member#: 256787
2003 Impreza RS
Question Are these factory tail lights setup?
Hi,
While cleaning trunk I noticed that all slots in the tail lamps are in use, I thought the center? ones were for rear fog lights. Looking closely I don't think the factory ever used yellow and red electrical tape.
I don't know what is the standard tail light setup but I took pictures so you can compare.
Any comments?
Thanks
Parking lights on (just took picture of the left lamp but both work the same way):
Parking lights + Brakes on (left and rear):
oracle is offline   Reply With Quote
Old 09-13-2010, 08:11 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
yes,, pretty sure mine operates the same way.
ProdriveDreams is offline   Reply With Quote
Old 09-13-2010, 06:57 PM   #3
tbadhesha
Member#: 66198
2004 STi
Java black
Coming from the UK, i'm pretty sure the innermost bulb is used for the rear fog lights which is the case for Euro spec models.
Tag
tbadhesha is offline   Reply With Quote
Old 09-13-2010, 08:03 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Subaru has used such colored tape.
There was a picture posted by a chap in Iceland that shows the foglamps as the outers, the parking lamps as the centers, and the brakes as the inners. This is because the law states that the fog-lamp cannot be next to a stop-lamp. Even here in the U.S. there are some states that specifically allow for the use of a rear fog-lamp and the law is also the same. Thus having a rear fog-lamp in the center would be incorrect since it would be next to a stop-lamp.
Since we are here in the U.S., the lamps are typically wired as outer: park/brake; center: park only; inner: brake only. The center socket typically has a third wire that is not attached to anything. This would be the "high-side" for the brakes.
Oh, and to answer your original question: yes, that is the factory USDM set-up.
Old 09-13-2010, 10:28 PM   #5
oracle
Member#: 256787
2003 Impreza RS
Awesome, thanks for your comments!
I checked the users manual and it matches exactly how the tail lights are setup so yes, it confirms your comments that is factory correct.
Thanks
Are these factory welds? qhatherly Interior & Exterior Modification 11 08-04-2007 11:29 PM
Hmm.... can't find a pic of WRB tail light setup Scoobz1234 Interior & Exterior Modification 10 06-04-2006 05:30 AM
FS - 95 Legacy factory tail lights $20 shipped Trin_Starr Legacy Forum 2 05-24-2006 02:12 PM
How about these GC8 tail lights? Ikonosin Interior & Exterior Modification 10 07-31-2002 11:04 AM
