Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 09-12-2010, 07:48 PM   #1
craftyvtec
Member#: 97944
2004 M3
Default Rod bearing clearance with calico CT-1 Dry Film Coating STi
I am building my motor and I wanted some opinions on my bearing clearance. Motor should be around 400whp and will see road course time. I have calico CT-1 coated ACL rod bearings on stock rods with stock crank polished and checked. Here are my clearances. The first number is current clearance with coating. The second group of numbers is what the final clearance will be after coating wears off.
.0008 .0013-.0014
.0009 .0014-.0015
.0009 .0014-.0015
.0010 .0015-.0016
So let me know if I should proceed with assembly or make changes. Interested in what you guys think. I seems a little tight however I am not sure with the coating if that's ok.
craftyvtec is offline   Reply With Quote
Old 09-12-2010, 08:02 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
you might check with calico on what they expect to wear off,I have used calico's brgs and the motors I took apart after they ran for a year showed very little of the coating worn off.I think as long as you use a good assembly lube that is thick and sticky it should reduce how much initial wear that happens during priming and initial start up. good luck
john 1badSTI is offline   Reply With Quote
Old 09-13-2010, 11:16 PM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
I run the same bearings and the wear is minimal. Here are some pictures of my main bearings after 10,000 miles. About 2,000 track miles.
alcoolaid is offline   Reply With Quote
Old 09-13-2010, 11:23 PM   #4
craftyvtec
Member#: 97944
2004 M3
Thanks for the pics, how about the rod bearing clearance, I think it might be too tight for track use.
Old 09-14-2010, 12:07 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the coating is meant to be there in the case that your crank meets the bearing, thus keep standard clearances. In this case you'll only wear the coating IF you drop pressure, detonation, etc.
Run normal clearances for the given aspiration of the engine. Been using Calico coated ACL's in builds for 4 years...the only bearings I use/sell
Old 09-14-2010, 03:51 AM   #6
alcoolaid
Member#: 134949
'07 SWP STi
I used the calico coated acl HX bearings to get my 0.0019-0.0020 rod bearing clearances. I don't think you can get 0.0015-0.0020 on the standard H size unless you open up the big rod ends but then you'll lose some bearing crush.
Old 09-14-2010, 09:04 PM   #7
craftyvtec
Member#: 97944
2004 M3
Yea I don't want to open up the big ends. I am looking for a set of the HX's now and I will just sell the standard H bearings.
Max clearance on main/ rod bearings evoeater1 Newbies & FAQs 7 05-29-2011 12:58 AM
Road clearance with Greddy Gracer Lip for 06-07 STi STi_4_life Interior & Exterior Modification 2 03-25-2009 03:35 PM
Just Another Rod Bearing Clearance Question All_talk Built Motor Discussion 5 03-19-2009 12:33 PM
If I spun a rod bearing on hybrid setup - buy upgraded rod bearings? MarylandEcstasy Built Motor Discussion 4 05-20-2007 12:54 PM
FS SPT intake with heat shield 1 week old MINT STI WRX wrb2006sti Engine/Power/Exhaust 2 05-03-2007 03:14 PM
