Old 09-12-2010, 07:51 PM   #1
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Default Need HeLp: Defi egt gauge erratically bounces
Ok so I have three defi gauges all powered from the radio power. Two of the gauges work fine but my egt gauge doesnt. It reads egt temps fine but for example when i turn on the head lights the needle will flicker for a split second kind of like I have a ground issue but why would this come up now after working fine for like 2 years? I HAVE pulled the motor and reinstalled it but the intake mani grounds are back on and the bolts are tight.
ANY IDEAS fellas. Thanks
stretchedk7 is offline   Reply With Quote
Old 09-12-2010, 08:04 PM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
ideas...........
Old 09-16-2010, 05:15 PM   #3
Enlefo
Member#: 235627
07 STI
You can always run power from the battery into your dash... there is a nice little rubber grommet just waiting to be used above the gas pedal. Also, not having other stuff on your radios power will make it sound cleaner. You can also ground out to one of the bolts going into the tranny casing since it's right there.
Enlefo is offline   Reply With Quote
Old 09-16-2010, 11:05 PM   #4
razrielle
Member#: 205698
Could just be the guage going bad.
@ Enlefo... Why in the world would you power your gauges using the battery? He could tap a fuse from the block thats right under the dash
razrielle is offline   Reply With Quote
Old 10-07-2010, 11:47 AM   #5
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
thanks fellas. I believe that vibrations were effecting it that or my battery being low on charge?? Idk but it seems to be better. And i didnt really consider the sound quality of stereo but good point but yeah the power from the stereo has been running them for quite some time. Seems to work fine.
Defi EGT Gauge $100 - 52mm Defi Imperial Link Meter Series mcdrama Interior/Dressup/Audio & Security 3 05-26-2008 04:46 PM
quick defi egt gauge install question Otaku64 Electrical & Lighting 4 05-20-2007 09:23 PM
New Defi EGT Gauge And Defi Pod WRXout Private 'For Sale' Classifieds 10 06-11-2005 04:38 PM
Defi EGT Gauge probe AaronC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-24-2003 10:21 AM
DEFI EGT Gauge Gone Wacky! Justbordn22 Electrical & Lighting 25 04-12-2003 12:47 PM
