Old 09-12-2010, 09:12 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
Default Where is the Idle Air Control Valve/Sensor on my Brighton?
Here is my intake manifold on my brighton. I dont know what sensor is my Idle Air Control. I have looked at Factory Service Manual and they dont verify which one it is. I have a horrible idle problem and my CEL says it is the idle air control. Here is a picture of my intake manifold.
emsmap is offline   Reply With Quote
Old 09-12-2010, 10:46 PM   #2
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi OTS Stage 2
the black cylinder thingy on the top of the throttle body is your iac
grafton is offline   Reply With Quote
Old 09-12-2010, 10:51 PM   #3
emsmap
Member#: 159334
02 WRX, 99RS, 96L
Thank you!! I will take that apart and clean it. Hoping it will fix my problem
Old 09-15-2010, 01:50 AM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
I thought that the iac was built into the manifold on the ej18. The thing sticking up on the back of the passenger side runner with the spring on it? I have a 93 L with the ej18 but am not sure about the iac.
geronimo81 is offline   Reply With Quote
Old 09-15-2010, 07:56 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Nope.....it's on the TB, as stated before. Additionally, the IAC on that TB actuates the main throttle plate. It's not a bypass type IACV like most others.
Jay
Old 09-15-2010, 12:46 PM   #6
Inane Cathode
Member#: 257508
What kind of problems are you having? Looking at how much corrosion is on everything first thing i'd do is make sure you dont have voltage drops across the grounds due to all the oxidation.
Inane Cathode is offline   Reply With Quote
Where is the idle air control valve? Tattoo! Service & Maintenance 3 10-29-2009 11:10 PM
What's the part number? Idle Air Control Valve Gasket nicholam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-29-2008 01:36 PM
Just did head gaskets and the Idle air control valve is causing trouble, I t dvinke1 Normally Aspirated Powertrain 3 10-30-2007 02:52 PM
Just did head gaskets and the Idle air control valve is causing trouble, I think dvinke1 Service & Maintenance 0 10-30-2007 12:15 PM
P0508 and the Idle Air Control Valve Chigliakus Service & Maintenance 11 01-30-2007 09:28 PM
