Old 06-24-2002, 03:56 AM   #1
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default Inside cabin windshield fog...
This might be a little off-topic, but it's in regards to my WRX..
When I turn my car off and if I have the A/C blower knob set all the way to the right, the window defogger, i'll come out to my car in the morning and have this nice pretty good sized fog spot on the INSIDE of my front windshield.
How is this happening? Evaporating through the air vents and causing it to dew up on the window? It's just like the dew on the outside of your car in the morning, but on the inside of the car, it's driving me nuts.. leaves a nasty dirty spot where the water is on the windshield.. anybody else experiencing this?
Jay
Diversion is offline   Reply With Quote
Old 06-24-2002, 05:39 AM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Default check your manual
It sounds like condensation on the AC cooling core, is evaporating when you park and re-condensing on the cool windows.
You might want to check what vent setting you have been using, there is a caution in the manual about using the recirculation setting and window fogging.
If you use the outside air setting it is not so likely to fog. Not sure if that will eliminate the issue or not. I've seen a similar thing happen in cold damp weather from defrosters when you first turn them on. Not a real problem but can be irritating.
Larry
You might be able to get rid of it by shutting the AC off a couple blocks before you park the car so the condensation inside the AC ducts has a chance to clear before you park the car.
hotrod is offline   Reply With Quote
Old 06-24-2002, 07:29 AM   #3
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
You're right it only happens when I have it on re-circ... thanks!
Jay
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 10:28 PM
08+ wrxsti steering sound inside cabin silverwrxnor Brakes, Steering & Suspension 0 06-28-2009 03:04 PM
Cleaning inside of windshield? Hazdaz Interior & Exterior Modification 8 06-24-2002 06:53 PM
cleaning inside of windshield and rear window elemental Interior & Exterior Modification 1 08-03-2001 06:58 PM
