Old 09-12-2010, 11:51 PM   #1
Saintsp
Member#: 249258
Default Question bout fuel system
i know there are people doing one intake walbro feeding a single 044 straight without any surge tank.Is it possible to do 1 intake walbro feeding 2 044 pumps direct without any surge tank in between?
Saintsp is offline   Reply With Quote
Old 09-13-2010, 11:19 PM   #2
Saintsp
Member#: 249258
Any opinion?
Old 09-14-2010, 10:41 AM   #3
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
I don"t think the wally would keep up. As in a surge tank the return line from injector gets put into the surgetank to help keep full. So the 44's use that return line as feed, in your situation, return lines goes to tank which will keep you from using as volume for 44's so i think you would run into starvation issues.
02WRX2.5 is offline   Reply With Quote
Old 09-15-2010, 01:51 AM   #4
Saintsp
Member#: 249258
what bout single 044?
Old 10-18-2010, 06:52 PM   #5
Jspike
Member#: 149575
94? GD
Just add a Surge tank
Jspike is offline   Reply With Quote
Old 10-18-2010, 11:46 PM   #6
Saintsp
Member#: 249258
Used to have a surge tank just that can't stand the smell so removed it.Now is one wally feeding one 044.Just worried that it might not be able to keep up
Old 10-19-2010, 12:28 AM   #7
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I have a hunch that the smell was from the lines you used, not from the surge tank itself.
Fuel smell is a pretty common complaint of people who use the wrong lines.
Old 10-19-2010, 06:54 AM   #8
Saintsp
Member#: 249258
Well the smell 's gone.Now just waiting for a tune.Just wondering if the fuel pump will be enough to support my hp range.Running a BW s300 atm
Old 10-19-2010, 06:45 PM   #9
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Your limiting factor is total fuel flow of the pumps in series
the Walbro 255 flow @ 0 psi is ~ 290 Lph
the Bosch 044 flow @ 65psi line pressure (~ 45psi base pressure + 20psi manifold pressure) is ~290 Lph
* At that manifold pressure (65psi) the Walbro supplies enough flow
* However when the line pressure of the 044 is 45psi it will flow ~307Lph so "theoretically" it will be starved of flow from 45psi to about 63psi
These are all numbers, and in the real world you may be OK. But there's a reason why machinery/car parts are designed and numbers are calculated.
So your setup is borderline so it may work without an issue or "theoretically" the Bosch pump may experience cavitation and undergo early impeller wear- but i doubt that would cause its demise .
engineerx is offline   Reply With Quote
90k Mile Maintenance + Question bout Fuel Filter Marc5000 Service & Maintenance 26 06-15-2007 03:14 AM
Fuel system upgrade question Matty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-26-2003 12:05 AM
Fuel system questions BOY Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-06-2002 03:49 PM
quick fuel system question smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-12-2002 08:32 PM
Fuel System upgrade question... Matty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-13-2002 05:33 PM
