Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 09-13-2010, 09:46 AM   #1
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
Default top lbs on sti turbo
hey im new to the game , i have a bugeye with a hybrid setup and some upgrades, ( pistons , fuel , injectors ect) my question is I have a sti turbo and whould like to know how much lbs can it hold with my setup without going wrong? i have a mbc and have it at 21 now.
dasleepa02 is offline   Reply With Quote
Old 09-13-2010, 09:55 AM   #2
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
35psi papa.
wrxwhat is offline   Reply With Quote
Old 09-13-2010, 09:58 AM   #3
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
Originally Posted by wrxwhat View Post
35psi papa.
really???
Old 09-13-2010, 10:55 AM   #4
xsblack
Member#: 26530
2004 Sti
JBP
Sti turbos lose efficiency quickly after 20psi, by 25psi your blowing very hot air and not gaining much from the added boost. If you want more power your going to have think about upgrading to a larger turbo
ps. dont crank up the boost with a proper tune!
xsblack is offline   Reply With Quote
Old 09-13-2010, 02:20 PM   #5
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Originally Posted by dasleepa02 View Post
really???
no, Lol
Old 09-13-2010, 07:35 PM   #6
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
no, Lol
thanks for the great info! ass....
Old 09-13-2010, 08:02 PM   #7
Badler
Member#: 133597
35psi papa.
really???
Sure, if you want too.
Badler is offline   Reply With Quote
Old 09-13-2010, 08:16 PM   #8
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Have you done anything to combat the compression issue ie combustion chamber shaping, low compression pistons, thicker headgasket [cringe]?
If not, you are prone to knock, especially with higher boost. I could only get about 17 lbs of 'safe' boost and minimal timing. Eventually my motor cracked a ringland... Just some food for thought.
paintbing is offline   Reply With Quote
Old 09-13-2010, 08:20 PM   #9
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
^^^ this ^^^
I would honestly go get it checked out. It may not be safe as it sits. More boost is definitely a BAD decision on that setup.
CKxx is offline   Reply With Quote
Old 09-13-2010, 08:45 PM   #10
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
only the person who tunes your car can answer this question. you do have it tuned for 21 psi dont you...
AWDWRXLOVER is offline   Reply With Quote
Old 09-13-2010, 09:10 PM   #11
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I have run up to 25psi on a VF39. From 20psi to 25psi I only get like 5whp but I gain a ton of torque.
Old 09-13-2010, 09:14 PM   #12
meccjoo
Member#: 97522
really? so crank up the boost without a proper tune?
meccjoo is offline   Reply With Quote
Old 09-13-2010, 09:40 PM   #13
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
i do have pistons and a tune. but the guy that had the car before had it tuned at 18lbs
Old 09-13-2010, 10:09 PM   #14
XxSikSTIxX
Member#: 227300
2006 WRX STi
PTE 6262 E85
lol blew my vf39 at 17lbs on the dyno
XxSikSTIxX is offline   Reply With Quote
Old 09-13-2010, 10:30 PM   #15
AWDWRXLOVER
Member#: 50267
02 built hybrid
so you think its ok just to turn it up to 21
Old 09-14-2010, 01:58 PM   #16
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
i have no idea, i just wanted to get some more power. i should just get a big 16g?
Old 09-14-2010, 03:15 PM   #17
BenGSX
Member#: 210061
Not trying to be an a$$ - but first you should get a tuner.. You can't just go willy nilly turning up the boost.. Or slapping on a larger turbo.
First you need to figure out how this "hybrid" was built.. Then your tuner needs to actually tune the car for a higher level of boost.. Right now you have no idea if you are running out of fuel.. Running too much timing.. etc etc etc..
In the past few years Ive seen a few project cars that I've had my hands on blown up by stupid kids that bought them. It was explained to them that they CANNOT turn up the boost without proper understanding / tuning.. One time a kid went straight to a gas station (after buying the car), filled it up, cranked the boost controller all the way up (profec b) and popped the motor 1 block later. The other was a fully built 2.3 stroker 4g63 setup for single digits.. 18 grand in that motor alone.. Had a 16g in it for break-in and 660cc injectors.. Stupid kid who bought that car strapped a 35r on it without touching injectors or tune and popped the motor..
DON'T BE THAT GUY!!!
* Edit! This is what was in the motor that the second kid above blew... The motor was built pretty much as strong as you can build a 4g63.. And he popped it by slapping on a bigger turbo without a tune (and injectors..)..
BenGSX is offline   Reply With Quote
Old 09-14-2010, 09:05 PM   #18
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
thanks for the info guy. like i said im new to suby. i had hondas before so things are a little different. well i guess ill have to call up mike
Old 09-14-2010, 09:59 PM   #19
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
I kept cranking my boost controller up at Etown till I just pulled off the WG tube completely and let the turbo go for all it was worth! It would hit 24psi and taper off big time at higher RPM.
People say you can't do that because it just blows hot air but I have a FMIC and the more PSI it made the faster I went. Wound up doing a 12.5@109 untuned but I also have a EJ207 so I wasn't worried about hurting things like a USDM engine.
Find out what your Hybrid is and then have it tuned but your tuner will be the one to set your standards I would say
2002WRXSTi is offline   Reply With Quote
Old 09-15-2010, 02:40 AM   #20
CKxx
Member#: 33458
93 RX7+09 Forester
*Cue 'Billy Madison' wrong answer speech*
Old 09-15-2010, 04:06 AM   #21
jutes85
Member#: 127232
E92 M3
98' Foz
Idiot. Thanks for posting the wrong info.
jutes85 is offline   Reply With Quote
Old 09-15-2010, 12:57 PM   #22
xsblack
Member#: 26530
2004 Sti
JBP
Correction: Don't crank up the boost without a proper tune.
OP: Take your time and figure out what your goals are for the car. More power is possible from the set up you have, but it is more involved then just turning up the boost. Start with a full mod list and realistic future HP goals and the knowledgeable people here will point you in the right direction
Old 09-15-2010, 01:01 PM   #23
dasleepa02
Member#: 251868
02 WRX - Hybrid
Wrb
thanks man i appreciate the help.
Old 09-15-2010, 01:21 PM   #24
Prevent
Member#: 149114
this..
at 23psi i was at 285whp and 344wtq
over stock on the same dyno thats 65whp and 114wtq increase
Prevent is offline   Reply With Quote
Old 09-15-2010, 05:48 PM   #25
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Check the last chart in this post (or any other "Stage 2" type setup in PPB). Ignore the actual HP / torque numbers, this is a dyno they use correction factors on. Just look at the boost curve, more specifically, boost pressure at peak power:
http://forums.nasioc.com/forums/show....php?t=2055539
Note that the boost at the power peak is like ~16 lbs. That's because it can't flow enough to run higher boost at peak power. Doesn't matter if you run 18, 20, 25 psi, your peak power will be at some lower boost pressure.
What you gain with more boost is a torque mountain, which is nice, but not worth popping your motor for.
Concillian is offline   Reply With Quote
LOOKING TO BUY VF39 STI Turbo Or other bigger turbos and Bigger than STock Top Mount alieus RMIC Private Classifieds 2 08-03-2007 03:17 AM
Stock Sti Turbo / Spearco Top Mount WRX/STI nortparkSTI Private 'For Sale' Classifieds 6 07-20-2006 12:44 PM
276 whp and 302 ft lbs on stock turbo... HalfBaked Proven Power Bragging 40 10-12-2005 06:15 PM
top speed on sti ra 5speed? fookster Transmission (AT/MT) & Driveline 1 12-30-2004 11:27 AM
17psi on stock turbo and Big top mount? brian1wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-15-2002 12:59 PM
