Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 09-13-2010, 03:52 PM   #1
subaruwrxparts.com
Vendor Sales Rating: (24)
Member#: 26010
2006 STi
Default AEM UEGO | DEFI | STRI | SPT and more!
AEM UEGO Wideband gauges in stock!
AEM's Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED vneedle" that changes colors as AFR changes from rich to lean. The unit's 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
SPT Boost Gauge 08+ WRX/STi
Displays engine vacuum in Hg and boost in PSI. Bright red illumination matches the vehicle instrument panel lighting and goes dark when the engine is turned off. Kit includes mounting cup and bracket.
Advance BF Series
Key features:
  • More accuracy through the glass and precise graduations
  • Peak value and warning value during driving are stored
  • Driving data can be stored and replayed up to 3 minutes
  • Smooth and instantaneous response with stepper motor
Advance CR Series
Key Features:
  • Illumination change be changed at night (2 colors)
  • Self-diagnosis turns on a light when the system detects and issue
  • Additional guages are easy to install
Racer Series
Key Features:
  • Does not require Defi-Control unit
__________________
[COLOR=Black]
[B]AIM:[/B] SubaruWRXparts
[B]Email: [/B]
[B]PH:[/B] 603.778.0300
[COLOR=Red][B][[/B][/COLOR]
[B][COLOR=Red]][/COLOR][/B] [/COLOR][COLOR=Red][B][[/B][/COLOR][COLOR=Navy]
[/COLOR][COLOR=Black][B][COLOR=Red]][/COLOR][/B][/COLOR][COLOR=Red][B] [[/B][/COLOR][COLOR=Navy]
[/COLOR][COLOR=Black][B][COLOR=Red]] [[/COLOR][/B][COLOR=Indigo]
[/COLOR][/COLOR][COLOR=Black][B][COLOR=Red]]
subaruwrxparts.com is offline   Reply With Quote
Old 09-13-2010, 04:21 PM   #2
subaruwrxparts.com
Member#: 26010
2006 STi
Defi Advance Control Unit
Key Features:
  • Can control up to 7 Defi-Link Meter ADVANCE CR & BF Gauges (any combination)
  • Gauges can be controlled from distance with the included switch unit
  • Peak value and warning value during driving are stored and replayed up to 3 minutes
Defi-Link Meter ADVANCE ZD
Key Features:
  • OLED display is high-brightness and high-definition made
  • Time of 0-100km/h(60MPH) and 0-200km/h(100MPH) can be measured
  • Display pattern can be selected from 4 display modes. (Maximum 6 items can be displayed all together on one GAUGE display.)
  • Mounting angles are more flexible than conventional products
Defi 3 60mm Gauge pod
Keep your 60mm gauges organized with this center dash gauge pod. This pod comes unpainted so you can custom paint it the color you want! Fits 02-07 WRX and Sti
__________________
[COLOR=Black]
[B]Email: [/B]
Old 09-13-2010, 04:35 PM   #3
subaruwrxparts.com
Member#: 26010
2006 STi
STRI DSD-SLM II Gagues
Available in 52mm or 60mm with Smoked Amber or White lens
Boost
Boost 3 Bar
EGT
Water Temp
Fuel Pressure
Oil Pressure
Oil Temp
Tachometer
Volt
DSD (digital stepper drive) is Controlled and operated by an Advance Digital Microprocessor, and is Stepper Motor Driven (PM Type Gearless). Micro Stepping Movement creates high resolution and accurate readings. Super high torque maintains the pointer accurately in toughest racing environments and prevents pointer from overshooting at high-speed movements. Fast response eliminates reading lag with real time display. DSD gauges are gearless resulting in noiseless operation and durability.
*Note: Unlike conventional gear type stepper motors which are noisy and respond in slower reaction speed, DSD stepper motors have been test proven in the toughest vibration environments which is a general characteristic of race tuned vehicles.
Features:
  • Open / Closing Ceremony in sequences
  • 270 Degree Sweep Wide viewing angle for higher resolution reading
  • Warning Setting - User Preset User preset warning values, alarm by LED
  • Peak Recall On demand, view highest value achieved
  • Automatic Self Calibration - Each DSD meter is equipped with self calibration function that resets the pointer position after each installation. Or can be manually activated by shutting off the constant power source.
  • Short-Circuit Auto Detect if the sensor wire is incorrectly connected or the signal extension wire cut, the meter will detect the error and alarms the driver. (Backlighting will go off / pointer flashing)
  • Dimmer (DSD-SLM II Only) Reduce backlighting brightness for night time driving.
  • Extreme Accuracy Racing Spec Sensors All DSD are equipped with racing spec sensors for accurate reading.
  • Gorgeous Titanium Color Finish Casing
STRI Full Auto Turbo Timer
Stri Auto Timer is one of the smallest timers on the market. The unique multi angle joystick control button allows easy operation. Stri Auto Timer smartly utilizes the factory O2 sensor to display theoretical air fuel ratio. Additional features such as voltage display and user preset low voltage warning. A manual timer mode is also built in for users to preset a desire after idling time. Handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
Ultra Slim Design
Controller Dimension: 76 x 36 x 14 mm
Comes in Flat Black or Gunmetal
ATI Center Dash Pod 52mm-60mm 02-07 WRX/STi
ATi clock pods feature a punch out design that allows you to increase the diameter to accommodate 52mm or 60mm gauges in the same pod, this means you can mix and match 52mm and 60mm gauges. There are optional face plates to customize you pods look. This gauge pod is painted by ATi to match the interior. Gauges face the center they do not face the driver.
ATI Center Dash Gauge Pod Faceplate for 02-07 WRX/STi
Customize your ATi gauge pod with these optional face plates available in Blue, Chrome, & Carbon Fiber. These face plates are to be used with the ATi Triple Gauge Hood only. They mount very easily to the gauge hood utilizing 4 small tabs that snap into place.
Comes in Blue, Carbon Fiber or Chrome
ATI ezPod Center Dash Gauge Pod 60mm 08+ WRX/STi
This ezPod is on the passenger side of the dash and is angled towards the driver. It holds 3 60mm gauges and is color and texture treated to match the interior. It uses double sided tape to secure into place.
ATI 52mm or 60mm Gauge Column 02-07 WRX/STi
This gauge pod comes in a black plastic finish only. This Pod allows rotational and tilt positioning for any viewing angle. This is a direct swap and does include the bottom section replacing the plastic on top of you steering column. Fancy pod, that is well worth the extra money. (Warning may slightly cover some stock gauges). __________________
__________________
[COLOR=Black]
[B]Email: [/B]
Old 09-18-2010, 08:41 AM   #4
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 09-20-2010, 03:46 PM   #5
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 09-22-2010, 09:43 AM   #6
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 09-27-2010, 10:03 AM   #7
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 10-04-2010, 10:59 AM   #8
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 10-11-2010, 03:23 PM   #9
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 10-18-2010, 01:35 PM   #10
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 10-29-2010, 04:11 PM   #11
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 11-02-2010, 09:43 AM   #12
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 11-05-2010, 03:07 PM   #13
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 11-11-2010, 02:51 PM   #14
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 11-23-2010, 10:31 AM   #15
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 11-30-2010, 10:51 AM   #16
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 12-07-2010, 12:22 PM   #17
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 12-17-2010, 11:14 AM   #18
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 12-23-2010, 09:15 AM   #19
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 12-28-2010, 04:34 PM   #20
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 01-07-2011, 03:01 PM   #21
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 01-13-2011, 08:48 AM   #22
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 01-13-2011, 01:37 PM   #23
sublyme
Member Sales Rating: (15)
Member#: 244114
2016 WRX premium
*free bump*
any discounts? need an AFR setup..
sublyme is offline   Reply With Quote
Old 01-17-2011, 01:55 PM   #24
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Old 01-26-2011, 08:13 AM   #25
subaruwrxparts.com
Member#: 26010
2006 STi
*bump*
__________________
[COLOR=Black]
[B]Email: [/B]
Defi Advance BF Gauges IN STOCK!! Best prices on AEM Digital, Defi Racer, CR & more!! CygnusPerformance Gauges & Electronics 300 03-15-2014 01:04 AM
FS : AEM UEGO WBO2 w/ gauge and AEM boost gauge and cubby pod! Cossey Interior/Dressup/Audio & Security 9 09-29-2010 02:07 PM
AEM UEGO | DEFI | STRI | SPT and more! subaruwrxparts.com Gauges & Electronics 15 09-07-2010 12:39 PM
Great pricing on AEM UEGO! Defi/STRI/SPT subaruwrxparts.com Gauges & Electronics 17 03-15-2010 01:53 AM
Cobb,Perrin,Turbo XS,HELMETS,Gauges,Autometer,Defi,AEM,DC Sports,HKS,Crower, and MORE JBK Performance Engine/Power/Exhaust 20 08-09-2007 03:36 AM
