#1 |
Member#: 214982
Hey guys,
I began a gauge install about a week ago. I had to pause due to a shady pod that didnt fit right, but the following is what happened in the time since. I removed the factory boost gauge from steering column by snipping yellow and black wires. I removed the factory clock snipping the factory white clock wiring clip. Nothing else was touched, the boost gauge was installed and powered up and functions just fine but the following problems arose in the car; no turn signals, no dome light, no radio unit power, trip odomoeter resets every time car is off, and finally my keyless entry no longer works. PLEASE offer any and all info. Thanks, Ian
#2 |
Member#: 174965
Vehicle:07 WRX VF43 OBP |
Did you disconnect the battery before cutting those wire you describe? Maybe you shorted something out.
Did you start checking fuses? You can also grab a volt meter(set correctly) and check the battery and different systems of the car. |
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
When you cut the clock harness (presumably by cutting across all the wires simultaneously) you blew a fuse. Check both fuse boxes (under dash and engine compartment) and you'll find it.
#4 |
Member#: 214982
Thanks for the help. I'll try fuses. Any other ideas?
#5 |
Trust no one
You won't need any other ideas once you find the blown fuse.
#6 |
Member#: 214982
Replaced clock wiring harness fuse and everything is working again but my turn signals. Checked turn signal fuse and its all good, any ideas?
#7 |
Trust no one
Did you unplug the hazard switch while doing the gauges? That will kill the turn signals if left unplugged.
#8 |
Member#: 214982
Got everything squared away agian. thanks for the input mulder
#9 |
Trust no one
So what was it?
| Thread Tools | |
| Display Modes | |
| Please help electrical n00b with Boost Gauge Install | WRblueX_Guy | Electrical & Lighting | 15 | 06-09-2005 11:30 PM |
| Help!!! AC relay fails after injectors install!! | Elliot | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 05-22-2003 03:02 PM |
| Need help finding parts for turbo gauge install | scoot1212 | Factory 2.0L Turbo Powertrain | 2 | 08-15-2002 03:30 PM |
| Help!: Autometer A/F Gauge Install | adam@stonehill.edu | Normally Aspirated Powertrain | 12 | 07-02-2001 06:12 PM |
| Need help w/ water & oil gauge install | RS>Z | Technical Forum Archive | 3 | 07-24-2000 01:28 PM |
