Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-14-2010, 02:46 AM   #1
cubuff
Member#: 38345
2004 WRB WRX
Default misfire @ 6500 and above on higher boost
My problem is I have a misfire that seems to be somewhat intermittent, it is load dependent it will miss in 4th at 28psi but not in 3rd with 30+ psi. I have tried changing coil packs, adjusting dwell, timing, fuel etc... Its not in the tune its mechanical or electrical. I have filed down the crank sensor to close the airgap and I have changed plug gaps from big to small with no changes
I have a built ej207
Built version 8 heads w/1mm manley valves, supertech valvetrain, cosworth 278/274 cams
Twinscroll borg warner 91/79
FIC 2150cc injectors
In tank walbro to swirl pot with Fuelab external pump
-8 feed with -6 return
aeromotive fpr
AEM EMS
Compression is good and im waiting to do a leakdown to rule out any headgasket issue. I have a HKS amplifier on the way to try out and new race plugs to try. I am willing to try anything at this point I want to get this car back on the dyno asap without any misfire issues. Im itching to make good power with this car. Any info or help is welcome.
Thanks.
cubuff is offline   Reply With Quote
Old 09-14-2010, 03:47 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Not the AEM EMS issue that was occurring a while back?
alcoolaid is offline   Reply With Quote
Old 09-14-2010, 09:17 AM   #3
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
avcs heads? there has been an issue with avcs and ems
robbieshonda is offline   Reply With Quote
Old 09-14-2010, 12:30 PM   #4
cubuff
Member#: 38345
2004 WRB WRX
I was thinking this also. I have AVCS heads with AVCS cams but the AEM for the WRX doesnt control JDM AVCS. So.... a short answer is AVCS isnt hooked up. My cam sensor is in the same as the WRX on the drivers side front of the head.
Old 09-14-2010, 03:53 PM   #5
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I will bet that as soon as you install the amplifier your problem will go away,with bumping up the primary vlotage to the coils you will have a mucher stronger,hotter spark.you are not the first high hp high boost suby that has needed a spark amplifier added.good luck
john 1badSTI is offline   Reply With Quote
Old 09-14-2010, 04:15 PM   #6
cubuff
Member#: 38345
2004 WRB WRX
I really hope it fixes the problem. I cant wait to try it. e85 probably doesnt help the problem at all either.
Old 09-14-2010, 04:41 PM   #7
john 1badSTI
Member#: 77470
no it doesn't because of the larger volume of fuel to ignite it will show any weaknesses in the ignition system.I have confidence in saying I am 99% sure the amp box will fix your misfires and you should be able to run a gap of .026-.028 no problem.
Old 09-14-2010, 04:52 PM   #8
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
What is the gap?
ronzogonzo is offline   Reply With Quote
Old 09-14-2010, 06:35 PM   #9
cubuff
Member#: 38345
2004 WRB WRX
Originally Posted by ronzogonzo View Post
What is the gap?
.020 is the current gap. I have tried a little smaller and higher.
Old 09-21-2010, 03:50 PM   #10
sean18337
Member#: 135588
2007 STI *SOLD*
Did the ignition amplifier help??
I’m pretty sure I need one as well… My car does misfire a bit above 7200 RPMs and I already have the plug gap at 18thous
sean18337 is offline   Reply With Quote
Old 09-21-2010, 03:57 PM   #11
cubuff
Member#: 38345
2004 WRB WRX
It made a pretty noticeable difference. I believe it solved my problem. misfire in 4th appears to be gone. I did a few pulls to 8500 in 4th and no misfires.
