Old 09-14-2010, 04:31 PM   #1
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
Default How to fix rusted exhaust pipe flange.
Hello,
Could anybody tell me what would be best to repair this rusted flange?
The pipe got loose and I will need to re-attach it. The problem is that the rust is so bad, that I almost have no flange to attach the pipe to anymore.
I do not know how to weld, so should I use a split flange? Or just change the cat pipe for a used one?
Thanks!
KAT_Ayanami is offline   Reply With Quote
Old 09-14-2010, 05:59 PM   #2
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
I am not going to even ask...but that thing is abnormally corroded. The old flange has got to be cut off and a new one welded on. Take it to a muffler shop. Something like that would cost me 50-80 bucks.
Just see if your exhaust has enough play to be pulled in about half an inch.
Henry H is offline   Reply With Quote
Old 09-14-2010, 07:07 PM   #3
RaineMan
Member#: 256727
2007 2.5I Wagon
wow... I guess salty roads will do that... ouch.
RaineMan is offline   Reply With Quote
Old 09-14-2010, 07:39 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Split flange will fix that right up. They all end up looking like that around here after a few years.
Old 09-14-2010, 07:41 PM   #5
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
Mine look the same way. I just cut new ones as I used the gasket as a template. I brought it to the muffler shop to have them welded on.
swede978 is offline   Reply With Quote
Old 09-15-2010, 08:21 AM   #6
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
This is what I would say, too. You could weld on a new one, but this will be cheaper, and should still work.
Boxer4Dad is offline   Reply With Quote
Old 09-15-2010, 02:35 PM   #7
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
Thanks. Just got the split flange, and will try to put it on today.
I just hope that the flat gasket that goes between the mid pipe and the tail pipe does not give me trouble (the interior diameter is smaller than the pipe opening, so I might cut the interior of the gasket to make it fit).
how to fix my exhaust help please chris025 Newbies & FAQs 2 11-13-2009 02:30 PM
Fixing rusted exhaust Hotsho111 Interior & Exterior Modification 5 06-05-2009 03:40 PM
How to fix 2-bolt flange header leak? riggy30 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 04-30-2009 06:12 PM
Rust on jack points and sideskirt holes. how to fix? BlackoutWRX Interior & Exterior Modification 0 11-07-2006 06:45 PM
Up Pipe Leaks, how to fix them!! (long) lestion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-15-2002 11:03 PM
