Old 09-15-2010, 01:41 AM   #1
choleaoum
Member#: 255484
2010 EVO
Default Question regarding the rotation of the cams when changing timing belt..
Alright so I read about on the driver side cam gears, that the intake should only be roated clock-wise, and the exhaust should be rotated only counter-clockwise.. what about the passenger side pulleys? Same rules apply?
choleaoum is offline   Reply With Quote
Old 09-15-2010, 09:10 AM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I always do the passenger side the same way except I turn the intake counter and exhaust clock wise thats on the passenger side though of course. I dont really worry about the pass side though since the driver side is the one thats loaded and therefore if the tools slip and the cam gears both spin towards the inside you can get valve to valve action. Just set your pass side gears and then when you do your driver sides make sure they spin the way you posted and you will be fine.
stretchedk7 is offline   Reply With Quote
Old 09-15-2010, 09:13 AM   #3
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
And since none of what I just posted answered your question I personally spin the passenger sides however is closest to lining up the marks and have never had any problems. I just make sure the drivers side is perfect and I am spinning them as subaru states they should be. GL
Old 09-15-2010, 09:15 AM   #4
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
And once you get the timing set remember the marks will never line up again after you spin the crank so make sure your marks are perfect (use the marks on timing belt-dotted line is crank) and then when your all done rotate the crank shaft with a breaker bar or something and make sure your all smooth and no interference. You will know it if you did it wrong.
Old 09-15-2010, 12:28 PM   #5
choleaoum
Member#: 255484
2010 EVO
Great! Thank you for your response, just wanted to make sure before I actually started doing it I should be fine now haha.
Old 09-15-2010, 09:33 PM   #6
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
My marks always line up again? Do you mean on the T belt? Then yes
sense of nature is offline   Reply With Quote
I know the manual says change timing belt at 105k... Cababah Service & Maintenance 33 09-19-2015 06:48 AM
changing timing belt... help w/ lower drivers side cam moved in wrong direction TBone7281 Service & Maintenance 4 09-11-2010 11:36 AM
I have questions re: the movement of things and the rotation of the Earth. hikeeba Off-Topic 48 04-17-2008 02:50 PM
Changing timing belt, cam sprocket/valve questions lsnaple Service & Maintenance 5 12-22-2007 02:42 PM
When are people changing timing belts? GQ Service & Maintenance 18 12-28-2003 01:23 PM
