Old 09-15-2010, 08:59 AM   #1
Mica32j
Member#: 214290
2005 saab 92-X Aero
mica32j Black
Default High Beam Problem
I think I have a High beam on the drivers side partially burnt out but maybe it is possibly a relay or the switch stalk, so I made a table to create a diagram of what I'm dealing with. Canadian car with stock halogens, not HID, with DRL. Note, the low beams have a little extra bulb in the lower outer corner.
Here is what I've got facing the car:
I'm totally inept at reading a wiring diagram or properly diagnosing this myself. I'm guessing I should replace the drivers side high beam bulb first & see if this solves the problem. Anyone got a better idea?
Mica32j is offline   Reply With Quote
Old 09-15-2010, 07:04 PM   #2
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
A relay is usually either on or off.
Before you had this problem, with respect to the DRL's, how are they supposed to normally function?
Meaning, when all of the lamps are normally off and the parking brake is disengaged, the DRL's are now active. Which lamps are dimly illuminated? The low beams only? The high beams only? Both?
I ask because DRL's are either the low beams or the high beams, not both.
I would say that if the car utilizes a switched-ground system that the problem is more-than-likely in the column stalk-switch itself.
Old 09-15-2010, 07:44 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The driver side headlight fuse is probably burned out. Check it.
Old 09-16-2010, 01:10 AM   #4
Mica32j
Member#: 214290
2005 saab 92-X Aero
mica32j Black
I think the DRL light up both high beams with limited power & are activated when the emergency brake lever is released. I doubt it is the switch - the switch is common to both driver's and passenger lights, if it works on the passenger side it is working. The relays and DRL relays are also common to both sides so I doubt these are the problems either.
I checked the fuses prior to posting. It looked good & I swapped it with the passenger side to see if the problem switches side. Nothing. Problem still on the driver side even after fuse swap.
Next logical thing to do would be to swap the high beam bulbs to test.
hid morette, fog and high beam problem chadt02 Electrical & Lighting 2 12-22-2007 10:15 PM
Problem with morrette high beams! JoeBloggz23 Electrical & Lighting 8 04-04-2004 04:14 PM
High Beam Problem ursine Electrical & Lighting 3 01-07-2004 01:26 PM
high beam wire and ebrake problem Eaglesfan2422 Car Audio, Video & Security 9 12-28-2002 12:07 AM
morette high beam problem BashoPoem Interior & Exterior Modification 6 06-25-2002 02:39 PM
Message Board Statistics All times are GMT -4. The time now is 03:28 AM.
