#1 |
Member#: 99838
Vehicle:2005 2.5 FXT STG II Cayenne Red |
Someone decided to hitup my wifes car with some paintballs......any idea of what is good to take it off without ruining the paint? I tries taking it to the cars wash which was later that day when I got home, so it sat in the sun all day. Any Ideas????? Thanks.
Chris
#2 |
Member#: 104453
Vehicle:2010 FXT OBP |
the last i remember,some paintballs are water based. Have you tried cleaning it by hand with a wash mit or sponge?
#3 |
Member#: 236927
NESIC
Vehicle:1993 Legacy Sedan 1984 BRAT |
Yes, paintballs should come off with water. Spray it down, see if they run off, if not, give it a little scrubbing. It shouldn't leave any damage.
#4 |
Member#: 82989
NESIC
Vehicle:2002 WRX Hybrid VF22 |
Most likely you will have damage from the impact and the shards of the shell of the paintball though.
#5 |
Thanks Sir Alex!
Moderator Member#: 88606
Vehicle:2011 GMC Sierra 1990 Miata |
The paint itself is washable, but usually a thick waxy/oily consistency. Its designed to clean up, but not easily (I play on occasion). Spraying the car with a hose won't get it all off. You are going to need to get out a sponge or rag to scrub a bit to get the waxy/oily residue off.
#6 |
Member#: 213288
Vehicle:2007 SWP VF39 WRX Sti Mikey Tuned |
Paintball paint, 95% of the time, is water soluble.
Pending on how long the paint has sat on the car, attempt warm warm first. If that fails, try warm with a little dish soap. IF that fails, the paint isn't going to soak or seep into the cars finish, I'd say light clay work with a mild abrasive cleaner will work. Don't worry about shards. Paintball shells are not shells (like and egg) they are casings. NOTE: Paintball paint will ALWAYS be removed with water unless its hi-grade tournament paint, which I doubt these kids had. Hi-Grade paint is thicker tho, if this has run down the side of the car its cheaper paint and should come right off with enough water and very mild abrasion. |
#7 |
Member#: 99838
thanks....it is everywhere, it hit the rear window then splatered on the roof and hood.....little pricks
#8 | |
Member#: 222041
South East
Vehicle:2009 Impreza 2.5i PRP |
this, it will come off with dish soap, the casing is a thin rubber shell, it is slightly flexible, unless its dented the paint there should be no damage, and i can guarantee you these kids didnt buy tournament grade paint, at 65-70 bucks a case for that stuff people dont buy it to waste it. unless your wife was driving in this neighborhood http://www.autoblog.com/2009/08/18/r...aintball-guns/ |
#9 |
Member#: 256998
NESIC
Vehicle:2002 Wrx wrb |
even the tournament grade stuff is just thick and designed to stain fabric, the shell on the tournament grade stuff is actually more brittle then the stuff people buy at wal mart... Take it from someone who's washed many cars that were covered in paintballs after a tournament... stuff should come right off... maybe a dent or two if they were shot with high enough velocity and a harder shell but paint itself should come off with water and a little soap to get rid of the oily crap
#10 | |
Member#: 238239
Vehicle:2003 WRX |
I would make me ![]() ![]() if someone did that to me. If that happened I would comeback and and shoot their house with one. |
#11 | |
Member#: 256378
Vehicle:2011 WRX DGM |
#12 |
Member#: 239150
Vehicle:2003 WRX Sedan |
i would be more worried about dents
#13 |
Member#: 256953
Vehicle:2001 2.5RS Gloss White |
My car has never been hit by a paintball, but if it's any thing like getting egged (my civic got 2 dozen) they will leave a bunch of small chips in a circle around the point of impact.
#14 |
Member#: 170474
Vehicle:2002 wrx white |
I would try washing it with the culprits blood.
#15 |
Member#: 125575
Vehicle:1947 Woody |
soap and water will take care of the paint
#16 |
Member#: 159796
SCIC
Vehicle:2006 WRX |
for those of you who said the paintball shell wont damage the paint... how much do you know about paintball? ever got shot by one? the shell+impact can do damage to the paint. and paintballs can be flying at up to 350 feets per second from the average POS gun that you can find at walmart. i would even say that if your car paint is NOT damaged nor dented, you got lucky. if you get shot bareskin by paintballs, it's pretty common to get cut marks and/or slight bleeding, from the shattered shells slicing your skin.
and while the paint is just an oil that is water-soluble, they can leave stains if it sat on your car for some time. pink paint is famous for staining white cars. Last edited by vinxH; 09-17-2010 at 03:56 AM. |
#17 |
Member#: 215912
Vehicle:2008 Impreza 2.5i Topaz Gold Metallic |
Your lucky they didn't use "Ultra Evil" paint if you leave that on a car in the sun it will dye the paint yellow i've had experience with it on my old ford explorer.
#18 |
Member#: 242919
Vehicle:2013 Elantra 2dr 6MT Shimmering Silver |
#19 |
Member#: 256953
#20 |
Member#: 182551
Vehicle:2004 STi PSM |
after washing it, clay bar it and it should be minty clean again.
#21 |
Member#: 40534
South East
Vehicle:2008 STI M3, and more |
a lot of paintballs are actually water/soap based so you'll be fine. Just give it a good wash.
#22 | |
Member#: 222041
South East
When I would play I was a back to mid player, getting shot from about midfield resulted in bruises. Getting shot fromm abiut 3 feet away while crawling the snake led to welts. And knowing that anyone who is mature enough to respect the sport of paintbaqll leads me to believe these were teenagers. And knowing teenagers they have probably no balls so shot from a good distance away as theyb would be too scared to come out point blank and shoot the car But yes good luck with paint stain..... |
#23 | |
Member#: 256953
Back on topic: Paintballs will most definitely damage your paint if being shot from a paintball gun. |
#24 |
Member#: 258208
Dude if someone did that to my subi, they'd prolly die of blunt force trauma from the 1 1/4" combo-wrench i keep beside my seat hahaha
#25 |
Member#: 68213
NESIC
Vehicle:92? justy rally car white/blue/mud #44 |
yeah cause hitting someone with a wrench because they got washable paint on your car is worth it. ****ing idiot...
| Thread Tools | |
| Display Modes | |
| FS: Illinois...PAINTBALL PAINTBALL PAINTBALL!!!! | Leon04GT | MWSOC Private Classifieds | 13 | 02-27-2009 04:53 AM |
| Any paintballers? - FOX Paintball ~ Tomorrow ~ Saturday 5/10/08 @ Fox Paintball | Jeenyus | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 05-09-2008 06:10 PM |
| my WRX is forsale....... sob sob sob | jared nelson | Rocky Mountains Impreza Club Forum -- RMIC | 27 | 02-21-2005 07:38 PM |
| sob sob, I need a mechanic in Queens | Qbushido | Tri-State Area Forum | 3 | 12-03-2002 10:51 PM |
| A little sob story... | Greg I | General Forum Archive | 8 | 05-23-2000 11:26 PM |
