Old 09-15-2010, 01:53 PM   #1
Bishj275
Member#: 225810
Default 2005 Vs. 2007 SOHC????
Anyone have any idea how much hp and tourqe differences there is between 2005 forester SOHC and a 2007 Impreza SOHC with AVLS? Do you all think that the gains from the 2007 out wiegh the cost of getting a few more wires added to my wireing harness???
Bishj275 is offline   Reply With Quote
Old 09-15-2010, 02:07 PM   #2
RaineMan
Member#: 256727
2007 2.5I Wagon
In short... no.
It's not even a 10hp difference at the flywheel. By the time you factor in drivetrane loss you've got 5 or 6hp to the wheels... which is nothing.
RaineMan is offline   Reply With Quote
Old 09-15-2010, 02:22 PM   #3
Bishj275
Member#: 225810
Thats what i figured, i can proably get that much by getting my cams re profiled in the 2005.... anyone else has some input??? im looking for opinions
Old 09-15-2010, 03:31 PM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
The 10 HP difference is between the switchover the SAE Net HP ratings. Correct me if my timeframe is wrong, but that means the actual difference in power is a bit larger.
The 10HP is from AVLS, which can only be used with an 06+ ECU. So unless you're planning on swapping the ECU, and deal with the pains of rewiring (whether or not you swap the ECU) you will have no benefit of AVLS on an 05 car.
However, from what I understand, once you start getting past intake/header and start tuning and looking into cams, AVLS becomes a big help.
formula91 is offline   Reply With Quote
Old 09-15-2010, 03:50 PM   #5
RaineMan
Member#: 256727
2007 2.5I Wagon
Interesting... hadn't considered that but it is a good point.
The new SAE certification standards went into effect 2005, but manufacturers weren't required to test by that standard yet. Switching over was all voluntary.
It all depends on when Subaru switched to the "new" standard. It also depends on if the older 2.5 would gain or lose power under the new standards.
Does anyone happen to know when that was done?
Speaking from my knowledge of GM's Ecotec engines, adding variable valve timing was good for about 20hp at the flywheel.
Old 09-15-2010, 08:18 PM   #6
Bishj275
Member#: 225810
Well i am running a stand alone ECU, and was told that it can be wired to run the AVLS, However i just bought the 2005 Forester 2.5X engine, it is rated for 173 hp but i dont have the head ache of messin with the AVLS now. Anyone have the actaul hp rateing of the AVLS engine to make me kick myself in the @$$.....????
Old 09-15-2010, 08:45 PM   #7
RBP2.5i
Member#: 95740
2005 Legacy GT
From my knowledge, Subaru switched to EL headers for the n/a motors in 07. Atleast that is what happened with the 2.5i Legacys.
RBP2.5i is offline   Reply With Quote
Old 09-15-2010, 09:34 PM   #8
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i think they switched to el in 06
olsen726 is offline   Reply With Quote
Old 09-16-2010, 12:24 AM   #9
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I can second 173 BHP and the switch to EL in 06. Also they did decide to use the new HP ratings in 2006, I remember this fully because they decided to increase the power of the STi that year, but it only ended up being "5" because they lost a bit through numbers in the switchover.
I remember the EL switchover because a bunch of you 2.5i lamers were complaining about how much it sounded like a Civic. I kid... I kid... sort of. lol
Old 09-16-2010, 08:32 AM   #10
GEE-OTTO
Member#: 201277
2009 Legacy GT
THEY HAVE ALWAYS BEEN EL (well very close but NEVER UEL)
GEE-OTTO is offline   Reply With Quote
Old 09-16-2010, 08:38 AM   #11
GEE-OTTO
Member#: 201277
2009 Legacy GT
The increase in Crank HP was due to the addition of the AVLS and a reworking of the internals. The The current stock manifold configuration changed to fit the relocation of the water pump, the new internals which resulted in a new oil pan, SOA aiming for higher emissions ratings meaning they moved the primary cat closer to the exhaust ports.
All these could not be achieved with the old style EL manifold if you swap the CBE on any EJ251 or Ej253 it will sound like any other import. The only N/A Subarus with a mostly UEL are 95 and older N/As
Old 09-16-2010, 12:29 PM   #12
bmobs06
Member#: 252783
my 06 wraps around the passanger side.
bmobs06 is offline   Reply With Quote
Old 09-17-2010, 07:14 AM   #13
flightwatch
Member#: 231058
2013 Genesis Coupe
Yes and the 05's went down the drivers side...that's one of the reasons why it's such a pain in the ass to do a header install on our cars
flightwatch is offline   Reply With Quote
Old 09-17-2010, 09:46 AM   #14
GEE-OTTO
Member#: 201277
2009 Legacy GT
Yes the same as my 2008 Legacy 2.5i but those primary length are as follows (both passenger sides are 25" the driver sides are 21" and 19" all @ 1.625" dia)
Old 09-17-2010, 09:52 AM   #15
GEE-OTTO
Member#: 201277
2009 Legacy GT
Yeah major limiting factor is the cat and its placement T 3 axis graph would best depict it: X-O2 reading Y-Values that are acceptable Z- Temp of catalyst
The temperature isn't a value in any table in the ECU but it plays into how the cat converts gases. HOTTER better Colder No bueno move the stock cat back 20 inches it will be 30 degrees cooler and still converting quite well but not per the rear sensor table values range in the ECU.
This is why the best fix is to "tune" for the rear O2 which is nothing more than an annoyance Get some logs to see what is actual, then adjust table values to accept the readings.
Old 09-17-2010, 11:45 AM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
So that in your opinion is not UEL? That's a 25% difference in primary lengths - in other words, that's unequal length.
Old 09-18-2010, 03:12 AM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Technically, any non-zero length difference is going to be UEL. The thing is, the 97-05 header is every bit as UEL or EL (take your pick) as the 06+ header. When people call one EL and the other UEL, it's just stupid. What really changed is the style. The older header was basically a 4>2>1 style header with extremely short primaries. The new header is basically a 4>1 style header with longer primaries and a close-coupled cat. The differences in power and the shape of the power band come from the design type and the primary length, not UEL-ness vs EL-ness.
The total power difference comes from the different header, different cams, AVLS, and the different pistons. Frankly, none of that is as good as you could get aftermarket. Keep your 2005 motor, get a Techworks Engineering 4-2-1 High Output header, keep your stock cat, get a set of Delta 1000 Grind cams, make a hybrid intake, get a tune, and be happy.
Or spend like a 10th of that on suspension and be even faster.
Old 09-19-2010, 11:47 AM   #18
VIsubi
Member#: 187834
06 2.5i impreza
Red
Cams got AVLS and our intake manifold was inlarged from what I have noted..along with EL headers and no my car doesn't sound like a Civic in no way way to deep to be a Honda. Also 06+ share similar rods and crank as the wrx well all three share the same crank. AVLS from my understanding is due to the cam profile could be wrong but has nothing to do electronically,,they sure do make a difference when boosted I'll tell you that for sure.
VIsubi is offline   Reply With Quote
Old 09-19-2010, 02:26 PM   #19
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
That happened in 05.
EL headers
The 06 headers are no more EL than the headers from 05. We just covered this in another post recently.
All modern 2.5L EJ engines share the same crank. The RS/2.5i has unique rods that are significantly longer than the turbo rods.
Old 09-19-2010, 11:28 PM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
AVLS from my understanding is due to the cam profile could be wrong but has nothing to do electronically,,...
The AVLS is variable lift, which does affect the cam profile. It's actuated by a solenoid valve, so electronics is definitely involved.
Old 09-20-2010, 01:05 AM   #21
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Be sure to check out the research I assisted with on the function of AVLS. It doesn't behave like people think it does.
Old 09-20-2010, 07:47 AM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Yeah, I was just reading that yesterday. I was at sea when you guys had originally posted it, so I had missed it. Pretty interesting.
Old 09-20-2010, 06:03 PM   #23
VIsubi
Member#: 187834
06 2.5i impreza
Red
I can feel it engage at around 4,000 rpm ever time seems heads start to flow alot better around there. As for intake manifold looks alot different than the 05 but I guess runners are the same. Rods stroke seem about the same. If longer the rpm redline is reduced but thought that was due to rev limiter adjustment and or valving.
Old 09-20-2010, 07:31 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You are wrong, as you are almost every time you open your mouth. The AVLS crossover happens barely off idle. The change you feel around 4kRPM is partially the CL->OL transition and partially hitting the efficiency region of the cam profile.
Old 09-20-2010, 07:49 PM   #25
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I can feel it engage at around 4,000 rpm ever [sic] time ...
Actually, you can't. Read this (which is what williaty was referring to before).
As for intake manifold looks alot [sic] different than the 05 but I guess runners are the same.
Here's an '05 2.5RS from over on rs25.com:
Here's an '06 2.5i also from rs25.com:
Ignoring the CAI, which part looks "alot [sic] different"? (I'll give you a hint - no part looks different, because they're the same exact intake manifold.)
Did you base that on looking at the engine or how it feels or what?
Double . There just might be something to what williaty said about you opening your mouth!
2005 vs 2007 leggy 2.5 gt overdriven707 North West Impreza Club Forum -- NWIC 6 08-28-2009 06:51 PM
STi 2005 VS 2007 little miss nicks General Community 30 12-10-2008 06:17 PM
2007 Acura MDX vs 2007 GMC Acadia vs 2007 Mazda CX-9 (Motor Trend) NYCshopper Non-Subaru News & Rumors 5 05-08-2007 02:57 PM
Comparison: 2007 GMC Acadia vs 2007 Ford Edge vs 2007 Suzuki XL7 (Motor Trend) NYCshopper Non-Subaru News & Rumors 9 03-15-2007 08:13 AM
2007 Acura RDX vs. 2007 Mazda CX-7 GT vs. 2006 Toyota RAV4 Limited V6 (MotorTrend) NYCshopper Non-Subaru News & Rumors 5 10-25-2006 03:25 PM
