Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 09-15-2010, 05:10 PM   #1
blckout7
Member#: 189845
Not sure if right area to post, i was tuned for 93 octane and usually i fill up 93 octane from sunoco and no problemo car runs great. Unfortunately running low on gas and closest gas station was Hess filled up 93 car felt slightly sluggish. Installed "big 3" today while my negative terminal was unplugged i reset my ecu, my question is will my ecu adjust everything to this bad tank of gas? Should I reset again when I fill up sunoco so that way the ecu learns on a good tank of gas. Thank you
P.s "big 3" has no negative effect on performance right? I was concerned that with a grounding kit maybe it would of been that making my car feel sluggish
blckout7 is offline   Reply With Quote
Old 09-15-2010, 05:31 PM   #2
RaineMan
Member#: 256727
2007 2.5I Wagon
Wait... your car is tuned for 93, you put 93 in, and you think something is different?
Generally speaking, 93 is 93 is 93 is 93. Some brands use more detergent than others, but honestly there isn't a whole lot of difference between Sunoco 93 and Hess 93.
Also... pardon my ignorance, but what's a "big 3"??
RaineMan is offline   Reply With Quote
Old 09-15-2010, 06:05 PM   #3
blckout7
Member#: 189845
It's upgraded wiring, like a ground from negative to alternator one to the chassis and the positive to the another part of the alternator
Old 09-16-2010, 01:27 AM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
You should be a-ok, but you can get a bad fillup of gas from time to time.
I had a friend who did research on this kind of stuff, and would find higher water content in the underground reservoirs that hold the gasoline under the station during certain times of day, and stuff... Not sure what the specifics were however... Sorry!
In general, top-tier fuels is always a safe bet.
Recently, the list has been updated with Exxon-Mobil on the list as a major change.
Strangely Sunoco Canada is on the list but not US.
formula91 is offline   Reply With Quote
Old 09-16-2010, 09:31 AM   #5
blckout7
Member#: 189845
Thank you, yeah that's what I hope it is cuz it's really strange. The way I had it tuned made the car extremely responsive when you made the slightest touch on pedal which I liked. So it's odd that it's not doing it
WRX wheels on my 96 outback, question about ECU/suspension/etc mxpunk Tire & Wheel 13 01-30-2007 09:20 AM
question about ECU (intake manifold) rotarypower8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-05-2005 02:13 PM
Questions about ECU Reset Rally Punx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-04-2003 02:52 PM
Question about ECU upgrades MrAceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-14-2002 06:21 PM
Question about ECU SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2002 11:56 AM
