Old 09-15-2010, 04:21 PM   #1
bluesubie
Member#: 767
04 FXT
Default Used Oil Analysis on M1 0W-40, 6,034 miles, FXT
UOA by Oil Analyzers Inc.
Driving conditions: Oil in use May – September; 7 mile daily commute each way; spirited driving with a few WOT’s here and there on days where I have a 30 minute drive. Drove on the beach about a dozen times. A trip to RI in May and to SC in July. Most of my consumption is on trips after driving on the Interstate.
Although TBN and oxidation were flagged, I’m pleased that the lead dropped to 0. Oxidation may be from Red Line during the previous OCI which is 150 according to someone at bitog.
I recorded 1 quart of make-up oil, although I believe that I forgot to log a quart addition somewhere. 24 oz added 2,247 miles into OCI and 6 oz. added 3,877 miles. I think I will keep my OCI’s at 6k, instead of pushing to 7-8k, regardless of what I use.
Comments: Base number is below acceptable minimum; Infared results indicate OXIDATION is SIGNIFICANTLY HIGH; Lube mixing possible due to change in additive levels; Lubricant and oil filter change acknowledged.
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 6,034 miles
Oil type & Grade: Mobil1 0W-40
Make-up oil added: 1 qts. (really about 1.5)
Miles on unit: 99,642
Air filter: Amsoil Ea panel filter
Oil filter: OEM Honeywell
Overall severity of report = 3 abnormal
M1, SSO; SSO;
Iron 7 11 11
Chromium 0 0 0
Nickel 0 0 0
Aluminum 0 3 3
Copper 15 5 6
Lead 0 10 4
Tin 0 1 0
Cadmium 0 1 0
Silver 0 0 0
Silicon 8 10 11 (first time in single digits!)
Sodium 22 28 90
Potassium 3 2 2
Titanium 0 0 0
Molybdenum 123 2 1
Antimony 2 0 0
Manganese 0 4 0
Lithium 0 3 0
Boron 112 7 7
Magnesium 30 17 17
Calcium 2805 3497 3423
Barium 0 0 0
Phosphorus 880 654 677
Zinc 1061 717 755
Lube chg Y
Filter chg Y
Fuel <.5% <.5% <.5%
Soot <.1% .1% <.1%
Water <.1% <.1%
Vis @ 100C: 13.2 10.1 9.6
TBN 1.99 4.35 4.01
Oxidation 37 43 38
Nitration 27 32 27
This is my first uoa since last September. At 60k miles, I got a new OEM turbo due to oil getting past the seals. That one lasted 20k miles and blew after 3k on Amsoil DEO. I got another OEM turbo (no more OEM TD-04 turbos!). The head tech at the dealership was surprised at the failure, especially since the oil filter screens were all clear. Ran dealer conventional for 700 miles and then used Red Line 5W-30 for 5k miles before switching to M1.
-Dennis
Old 09-15-2010, 05:56 PM   #2
Dr. octagon
Member#: 171127
2015 Subaru
Driving conditions: Oil in use May September; 7 mile daily commute each way; spirited driving with a few WOTs here and there on days where I have a 30 minute drive. Drove on the beach about a dozen times. A trip to RI in May and to SC in July. Most of my consumption is on trips after driving on the Interstate.
Although TBN and oxidation were flagged, Im pleased that the lead dropped to 0. Oxidation may be from Red Line during the previous OCI which is 150 according to someone at bitog.
I recorded 1 quart of make-up oil, although I believe that I forgot to log a quart addition somewhere. 24 oz added 2,247 miles into OCI and 6 oz. added 3,877 miles. I think I will keep my OCIs at 6k, instead of pushing to 7-8k, regardless of what I use.
M1, SSO; SSO;
Iron 7 11 11
Chromium 0 0 0
Nickel 0 0 0
Aluminum 0 3 3
Copper 15 5 6
Lead 0 10 4
Tin 0 1 0
Cadmium 0 1 0
Silver 0 0 0
Sodium 22 28 90
Potassium 3 2 2
Titanium 0 0 0
Molybdenum 123 2 1
Antimony 2 0 0
Manganese 0 4 0
Lithium 0 3 0
Boron 112 7 7
Magnesium 30 17 17
Barium 0 0 0
Zinc 1061 717 755
Lube chg Y
Filter chg Y
Fuel <.5% <.5% <.5%
Soot <.1% .1% <.1%
Water <.1% <.1%
TBN 1.99 4.35 4.01
Oxidation 37 43 38
Nitration 27 32 27
-Dennis
Sorry but
Dr. octagon is offline   Reply With Quote
Old 09-15-2010, 05:59 PM   #3
bluesubie
Member#: 767
04 FXT
I went with Red Line because I thought that I would stick with it. I went through two quarts in 5k miles, which is probably normal for all of the cleaning that it was doing.
When Autozone had their $30 special, including a filter, I crossed to the dark side to try Mobil1. It was also convenient since I never keep an oil stash and I was able to pick it up anywhere.
Currently running Pennzoil Ultra 5W-40 because I got it for free.
-Dennis
Old 09-15-2010, 06:01 PM   #4
Ryguy32789
Member#: 214559
2005 WRX
Ryguy32789 is offline   Reply With Quote
Old 09-15-2010, 09:20 PM   #5
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
I don't recall the miles on the two SSO OCIs, bluesubie, but this analysis (assuming the same or similar miles) certainly looks better, doesn't it?
But DUDE! What's with the *crazy* nitration numbers out of your engine?!
bulwnkl is offline   Reply With Quote
Old 09-15-2010, 09:39 PM   #6
bluesubie
Member#: 767
04 FXT
About 8k on both runs of SSO. Maybe the nitration is from using sub-par oil for too many miles?
I wish I would have had nitration checked when I used GC (as a comparison).
-Dennis
Amsoil SSO 0W-30 used oil analysis, 7,988 miles bluesubie Service & Maintenance 9 11-15-2008 04:28 AM
Used Oil Analysis, German Castrol 0W30, 7,946 mi., '04 FXT bluesubie Service & Maintenance 16 01-17-2008 10:22 AM
German Castrol 0W30 used oil analysis, 7,478 miles, '04 FXT bluesubie Service & Maintenance 0 06-11-2006 08:09 AM
Used oil analysis FXT 6,144 miles German Castrol Syntec 0W30 bluesubie Service & Maintenance 4 11-19-2005 08:21 AM
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT bluesubie Service & Maintenance 8 03-26-2005 10:06 AM
