Old 02-22-2011, 04:26 PM   #126
Britain
Member#: 247604
1974 Porsche 914
1700lb AX Car w/ Spec-C
Hey Dan...come by whenever you want, I am sure I will be out there troubleshooting all evening.
-Britain
Britain is offline   Reply With Quote
Old 02-23-2011, 12:27 AM   #127
Britain
Member#: 247604
1974 Porsche 914
IT'S ALIVE!!!!
First start of my Subaru engine conversion. Still a couple of things to sort out, but I am 99% of the way there. Dyno time in less than a week.
Sponsored by http://www.where2race.com/
Old 02-23-2011, 08:53 AM   #128
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
I love this project, hopefully I'll be able to see it at Nationals.
piknockout is offline   Reply With Quote
Old 02-23-2011, 08:59 AM   #129
yerrow
Member#: 59094
04/7 wagon & fozzie
wrb/blk
Superb!
yerrow is offline   Reply With Quote
Old 02-23-2011, 12:41 PM   #130
Britain
Member#: 247604
1974 Porsche 914
I hope to make it this year.
-Britain
Old 02-23-2011, 01:24 PM   #131
piknockout
Member#: 192173
If not, I'll pay someone to tow it out there and I'll drive it for you.
Old 02-23-2011, 01:37 PM   #132
Britain
Member#: 247604
1974 Porsche 914
It is not me that won't be able to go...it is the car, gotta make sure it will perform.
-Britain
Old 02-23-2011, 02:46 PM   #133
xpingux
Member#: 259821
2002 WRX Wagon
I can't believe how much stuff you've done without a post about 'So I bent and broke this' or 'This didn't fit and now needs to be replaced with'.
There's so little drama in your build it's crazy.
The amount of patience and planning you have is fantastic. Kudos to you, sir.
xpingux is offline   Reply With Quote
Old 02-23-2011, 04:38 PM   #134
K.Linchpin
Member#: 97984
2015 2.5i Foz w/6pd
You're right. There has been zero drama. This is a man who has been around for a while and knows what to expect. W/my engine swap I ran into a little trouble w/a custom exhaust and I was cursing at the world!
Britain, what's the deal w/your clutch? Is that a one of a kind deal or is it something porche's use? If it's a one of a kind design, that thing had to cost a fortune!
What are the benefits of a hydraulic throw out bearing vs the whole slave cylinder deal that subarus use? Maybe less hassle when it comes to mounting it?
K.Linchpin is offline   Reply With Quote
Old 02-23-2011, 05:37 PM   #135
wrxtasy555
Member#: 8293
2006 Forester XT
Crystal Gray Metallic
That vid was well worth the wait. Can't wait to see it in action.
What are you shooting for tune wise? Do you have a power goal? I'm not really into AutoX but I imagine you want the curve to be as far left as possible right?
wrxtasy555 is offline   Reply With Quote
Old 02-25-2011, 06:46 PM   #136
Britain
Member#: 247604
1974 Porsche 914
Many thanks to the kind words guys...but I must admit this there have been a few parts of this build that didn't go completely to plan. That said, everything was researched and thought out extensively before starting. I have about 10 pages of wiring diagrams and engineering drawings for custom parts. Lots of things drawn up in CAD and cut on a waterjet or machined.
Speaking of issues, right now I am delayed a bit waiting on parts. During the first start-up, I determined that there was an oil leak in the turbo drain as a result of the position of the turbo. There are two problems with the position of the turbo, first of all it is a little too low in relation to the oil pan. This is not an issue during normal operation, but during start-up or shut-down the accusump takes in another 2 quarts of oil. If it is not operated properly, then that oil is in the block and potential filling the turbo and could ruin the turbo. The second problem is the turbo drain flange that I made is not perfect flat and leaks.
To alleviate the problem, I have ordered a scavenge pump from www.turbowerx.com and all the associate AN fittings from www.aeroquip.cc and it should all arrive next week. It should be a straight forward install and a little extra wiring. Dyno time has been pushed a week to sort out this problem. Everything else on the car seems to be working properly at this point.
-Britain
Old 02-26-2011, 02:10 PM   #137
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
That pump is really nice. I am using Tilton pumps on a couple other engines and transmissions and used to think they were well built. Thanks for the info...
RSti_Spyder is offline   Reply With Quote
Old 02-26-2011, 02:16 PM   #138
Britain
Member#: 247604
1974 Porsche 914
Yea, the quality of the Tilton are not what they used to be. I have heard good things about the Turbowerx pump so we shall see.
-Britain
Old 02-26-2011, 03:48 PM   #139
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
-Britain
This project is close to the top of my Fantasy build list. I have been following your build for a bit now but had not noticed you were NWIC until you mentioned getting the car tuned by Tim.
So, when do you have dyno time scheduled, I want to come see this little beast in roar in anger in person.
etothen is offline   Reply With Quote
Old 02-27-2011, 12:56 PM   #140
Britain
Member#: 247604
1974 Porsche 914
I am working to finish everything up before receiving the oil scavenge pump and getting this thing on the dyno.
First thing was to add a additional switch for the oil scavenge pump and while I was there, I added labels for the confused.
Shifter installed and functioning.
I installed a Hall Effect Sensor under the shifter and a magnet in the shifter to detect Neutral Position for the ECU. The red LED indicates that is it aligned.
Hall Effect Sensor installed on the CV to pick up Vehicle Speed.
In full droop, the axle doesn't hit the exhaust pipe. WIN!
ECU fully wired up and wires secured.
Oil filter sandwich plate with Oil Temp Sensor.
In-line water temperature sensor.
The scavenge pump and the associated AN lines and fitting should all be here by Thursday. That gives me a week to sort everything out before the dyno tuning.
-Britain
Old 02-28-2011, 04:45 PM   #141
wrxtasy555
Member#: 8293
2006 Forester XT
impressive!
Old 02-28-2011, 04:51 PM   #142
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I'm beginning to wonder when this man sleeps.
Old 02-28-2011, 04:59 PM   #143
Britain
Member#: 247604
1974 Porsche 914
There is always time to catch up on sleep later in the year
Between the work on the car and launching my new site www.where2race.com it has been a busy winter. I didn't even get to go snowboarding yet...but I still have time.
-Britain
Old 03-04-2011, 02:51 PM   #144
Britain
Member#: 247604
1974 Porsche 914
Got the Turbowerx scavenge pump and associated AN fitting in the mail yesterday and got them all install. Due to space limitation and rules around the size of holes allowing in the firewall, I chose to plumb this up using bulkhead fittings. The turbo drain is now connected on one end and pump oil back into the oil pan. Few wires to hook up and the system is working perfect.
Still working on understand the coolant system, for some reason I don't think I am getting water to circulate properly. I will troubleshoot more this evening.
-Britain
Old 03-05-2011, 08:48 PM   #145
Britain
Member#: 247604
1974 Porsche 914
Alright, world premier. The car is officially off jackstands and driving under it own power. The throttle is a light switch, the acceleration is unbelievable, and the hydraulic clutch assembly is perfect. Gotta fix a water leak on the coolant line coming out of the turbo and need to determine why so much oil is coming out of the muffler...most likely due to the issues I had with the turbo drain or overfilled from the accusump. Either way, it will be ready for the dyno on Monday.
Check out the video...
-Britain
Old 03-05-2011, 08:51 PM   #146
Britain
Member#: 247604
1974 Porsche 914
BTW, that wasn't even full throttle in the video...I tried full throttle once and the back end jumped out on me...perfect!
-Britain
Old 03-06-2011, 09:14 AM   #147
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
your neighbors must love you .. first the 912 now the 914
did you get the car warm enough to open the thermostat? (water circulation)
Old 03-06-2011, 09:47 AM   #148
piknockout
Member#: 192173
*swoon*
Old 03-06-2011, 03:26 PM   #149
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Little smokey there.
Old 03-07-2011, 02:05 AM   #150
Britain
Member#: 247604
1974 Porsche 914
The car is officially ready to go. All the body panels on, fluids in, and everything checked. Just gotta load her up and take her to Dr. Bailey at Cobb Tuning Surgeline in the morning.
All the body panels on.
Engine lid fits with no issues.
Passenger seat in and waiting for Dr. Tim Bailey at Cobb Tuning Surgeline to work his magic.
We shall see how it goes.
-Britain
Porsche 914 with subaru conversion malaga_red75 Subaru Conversions 3 01-04-2010 11:22 PM
My Porsche 914 Track Car soloracer Member's Car Gallery 19 06-25-2003 10:01 PM
EJ25 into Porsche 914!!! :) Clegg Mid West Subaru Owners Club Forum -- MWSOC 4 02-10-2002 12:39 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 14 06-19-2001 02:58 PM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 2 05-29-2001 07:42 PM
