Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-16-2010, 02:01 AM   #1
prem205
Member#: 233877
08 Impreza 2.5i
SSM
Default 08+ Impreza Fog lighting blub change concern
So i bought some new fog blubs for my 08 Impreza. Took stock ones out and they read 12v 51w. New ones say 12v 100w. Is it safe to use from the higher wattage?
prem205 is offline   Reply With Quote
Old 09-16-2010, 10:49 AM   #2
bjkeed21
Member#: 247029
2010 WRX Hatch (02C)
Proletariat
I'm not an expert, but I would assume that the ones you purchased might draw more power through the wiring harness - possible overheating. And, the bulbs might be too hot, and could possibly damage the fog lamp housing. Again, that's just what I think might happen.
bjkeed21 is offline   Reply With Quote
Old 09-16-2010, 11:54 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No. Do not put higher than stock wattage bulbs in the foglights or headlights, for the reasons stated above. Even with an upgraded wiring harness and relays, there is still the possibility of heat damage to the light housings over time.
Besides that, the additional light output may result in a less than optimal beam pattern from the fogs as they aren't designed to handle the extra light.
If what you're after is supplemental lighting for dark roads, buy some auxiliary driving lights and install them. Fog lights are not intended to serve this purpose and are for use in poor weather conditions only, you can't change that by putting brighter bulbs in them.
Old 09-16-2010, 03:21 PM   #4
prem205
Member#: 233877
08 Impreza 2.5i
SSM
Yeah thats what i intended to use them for, weather conditions. Not for running 24/7 in a DD car. I didnt even want these 100w bulbs. Its just that i didnt notice they were 100w till i took em home from the shop.
Thanks for the help guys
Old 09-17-2010, 10:06 PM   #5
pumpkinvw
Member#: 192383
It sounds like you're on the right track, but if it helps, I put Hella Optilux yellow bulbs in my fogs. I only use them in crappy weather. I'm no expert, but it helps me see lines in the road and that sort of thing better.
pumpkinvw is offline   Reply With Quote
08+ STI fog lights & 08+WRX/STI door moldings Matt_H MAIC Private Classifieds 4 04-06-2011 02:23 PM
FS/FT : 08/09 Impreza Fog lights 181stLeader Exterior/Styling 4 08-04-2010 01:59 AM
2006-2007 Impreza Fog Light Surrounds and Fog Lights (Obsidian Black Pearl) AreYouImprezzed? Exterior/Styling 8 02-09-2009 07:20 PM
fog light color change STI_1027 Electrical & Lighting 9 02-25-2007 06:18 PM
Taking off fog lights to change bulb takemetoothemoon Canada Region Forum 17 04-10-2006 04:15 PM
