Old 09-13-2010, 11:42 PM   #1
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Default HELP! Electronic functions failing since gauge install
Hey guys,
I began a gauge install about a week ago. I had to pause due to a shady pod that didnt fit right, but the following is what happened in the time since. I removed the factory boost gauge from steering column by snipping yellow and black wires. I removed the factory clock snipping the factory white clock wiring clip. Nothing else was touched, the boost gauge was installed and powered up and functions just fine but the following problems arose in the car; no turn signals, no dome light, no radio unit power, trip odomoeter resets every time car is off, and finally my keyless entry no longer works. PLEASE offer any and all info.
Thanks, Ian
suba03ru is offline   Reply With Quote
Old 09-14-2010, 02:46 AM   #2
boardinshorty81
Member#: 174965
07 WRX VF43
Did you disconnect the battery before cutting those wire you describe? Maybe you shorted something out.
Did you start checking fuses? You can also grab a volt meter(set correctly) and check the battery and different systems of the car.
boardinshorty81 is offline   Reply With Quote
Old 09-14-2010, 06:11 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
When you cut the clock harness (presumably by cutting across all the wires simultaneously) you blew a fuse. Check both fuse boxes (under dash and engine compartment) and you'll find it.
Old 09-14-2010, 09:21 PM   #4
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Thanks for the help. I'll try fuses. Any other ideas?
Old 09-14-2010, 10:29 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You won't need any other ideas once you find the blown fuse.
Old 09-16-2010, 02:42 PM   #6
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Replaced clock wiring harness fuse and everything is working again but my turn signals. Checked turn signal fuse and its all good, any ideas?
Old 09-16-2010, 02:50 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Did you unplug the hazard switch while doing the gauges? That will kill the turn signals if left unplugged.
Old 09-17-2010, 07:17 PM   #8
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Got everything squared away agian. thanks for the input mulder
Old 09-17-2010, 07:20 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So what was it?
Please help electrical n00b with Boost Gauge Install WRblueX_Guy Electrical & Lighting 15 06-09-2005 11:30 PM
Help!!! AC relay fails after injectors install!! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-22-2003 03:02 PM
Need help finding parts for turbo gauge install scoot1212 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-15-2002 03:30 PM
Help!: Autometer A/F Gauge Install [email protected] Normally Aspirated Powertrain 12 07-02-2001 06:12 PM
Need help w/ water & oil gauge install RS>Z Technical Forum Archive 3 07-24-2000 01:28 PM
