Old 09-16-2010, 11:30 AM   #1
chompy630
Member#: 166434
1998 Impreza L 2.5
Red
Default High Voltage?
Ok so I have been having this problem where my battery and ebrake light would come on while I was driving and also sometimes my lights would get bright to where I assume they should be and then dim again.
So anyways I finally plugged my friends radar detector that has a voltage read out into my car to see what it was really doing.
When the light on the dash isn't on it is running at 13.7v
When the lights on the dash are on it jumps to 14.4v
When the lights got bright it jumped super high to above 16v and stayed there for a while.
Alternator and battery were replaced within the past year
I have a 1200w amp and sub other than that there isn't anything wired into the car at the moment
Does anyone have a clue as to what this is?
chompy630 is offline   Reply With Quote
Old 09-16-2010, 11:54 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The voltage regulator is in the alternator so it's probably that, even though it was recently replaced. The alternator should be tested but it's most likely bad.
You may need a new battery again as well, if the voltage has been running that high for a while the battery will be overcharging and venting and eventually that will damage it.
Old 09-16-2010, 12:00 PM   #3
chompy630
Member#: 166434
1998 Impreza L 2.5
Red
cool thanks for the quick response I'll get it tested sometime this week.
Old 09-16-2010, 12:55 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Get it fixed ASAP, it's not good for the electronics and bulbs to have fluctuating (and excessively high) voltage like that. And as I said it may have already trashed the battery, look for signs of acid overflow. If the battery has indeed puked out some acid you'll need to do a cleanup with a baking soda solution to minimize any damage and avoid future corrosion, and plan on replacing it.
Old 09-16-2010, 01:15 PM   #5
porcupine73
Member#: 146199
2000 OBW
green
I had this happen on my '00 obw. I replaced the alternator and the problem went away.
I went to start it up one morning and the battery was dead. So I recharged the battery (set on 2 amp rate for about 3 days). Then when I started the engine, it wasn't idling right. It was like it was running on 3 cylinders. Then the ABS light came on. I have a voltmeter installed and that's when I noticed it was reading 16.3V. So I shut her down immediately. It took a few days before the reman'd alternator arrived. The battery again went dead during this time. (Something in the old faulty alt was draining the battery too.) I had also seen this same sort of thing happen on a lifted truck for sale because the guy installed this big Wrangler alt to power these huge flood lights, but when it was running at high rpm and low load it put out almost 16 volts. Another time on a 4x4 for sale something similar happened, but it was because the alternator didn't have a good ground, so it was assuming the output voltage was really lower than it was. When a supplemental ground wire was added (2 gauge, right to the battery, then to the frame crossmember), that problem cleared itself right up. So make sure your grounds are good!
After replacement a couple years ago she's been golden.
porcupine73 is offline   Reply With Quote
Old 09-16-2010, 01:16 PM   #6
porcupine73
Member#: 146199
2000 OBW
green
Yes, especially if you have automatic trans. The PO leaked battery acid all over the ATF cooler lines that run right below the battery on my '94, and it ate through the lines last winter.
Old 09-16-2010, 01:22 PM   #7
chompy630
Member#: 166434
1998 Impreza L 2.5
Red
Well i got ambitious and went and got a new one just now it's in and now the car doesn't run like crap which is great they tested the battery for me and it was fine and I see no signs of acid so I'm gonna run with it.
Thanks for the help
Crank 2: High Voltage Gr8Dane Off-Topic 69 04-28-2009 09:59 PM
You have GOT to be kidding me....Crank: High Voltage upnygimp Off-Topic 5 03-30-2009 08:55 PM
Ford alums in high-voltage competition AVANTI R5 Non-Subaru News & Rumors 0 02-10-2009 02:42 PM
Danger! High Voltage infinite012 Member's Car Gallery 5 05-24-2008 07:22 PM
Working in high voltage station ?? qtr_wrx Off-Topic 41 10-28-2006 08:08 PM
