Old 09-16-2010, 01:28 PM   #1
vmax
Member#: 160299
06 sti
rally blue
Default Oil heater VS Block heater
I installed a Moroso oilpan on my 06 sti and needed to eliminate the blockheater for clearence of the new dipstick tube on the Moroso pan. My problem is that I live in Edmonton Alberta and temps drop around -35 and need some type of heater besides the stock oem blockheater. Is there another port in the block for the blockheater?? could I install a heater in a rad hose?? Or could I install a oil preheater that screws into my Moroso Pan??? Which would be the best solution??
vmax is offline   Reply With Quote
Old 09-16-2010, 03:09 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would just use a stick on oil-pan heater... Good enough. Or an in-line water coolant heater works great too... Get both and you are set to be able to start even in -45*C no problems.
wrxdrvr is offline   Reply With Quote
Old 09-16-2010, 03:15 PM   #3
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
I'm actually pretty interested as well because I want my built motor to last as long as possible and my neighbors aren't exactly fond of a my exhaust resonating thru their house while I let it warm up.
Byzantium is offline   Reply With Quote
Old 09-16-2010, 07:49 PM   #4
vmax
Member#: 160299
06 sti
rally blue
I think I will buy the Moroso oil preheater since I can thread it into my pan and run synthetic 5w30..Where can you buy these inline coolant heaters ?
Old 09-16-2010, 08:12 PM   #5
marcusklemme
Member#: 237054
2007 Cobalt =(
Red
I'm also interested in this, I just moved to Southeast Saskatchewan and am buying a Subie soon. Dare I say the winters here might be a little worse that Edmontons? What kind of oil do you run in the winter vmax?
marcusklemme is offline   Reply With Quote
Old 09-16-2010, 08:34 PM   #6
vmax
Member#: 160299
06 sti
rally blue
I run Redline 5w30 in the engine and 75w90 in tranny and rear diff seems to work good but I think the oilheater will help those cold starts
Burping the cooling system-Block heater install wild wild west Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-02-2002 12:53 AM
Block heater question mr2guru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-29-2001 06:10 PM
Subaru engine block heater install - need HELP! Peaty Normally Aspirated Powertrain 2 11-17-2000 12:42 AM
Subaru Engine block heater tomrichardson Normally Aspirated Powertrain 5 11-11-2000 12:30 AM
Block Heater Silver2000RS Newbies & FAQs 3 10-21-2000 09:04 AM
