Vancouver Impreza Club
Old 09-16-2010, 01:31 PM   #1
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
Question Advice: Engine job vs. Swap
What up guys, I have been lurking from time to time but no time to post regularly.
Anyways I have the dreaded internal coolant leak it seems.
I am just wondering if it is of any use to consider a swap over a repair. I dont want to go turbo, so it would just be a NA swap. Is that stupid/crazy/smart? Ball park on labour cost is about the same Im guessing so it would be the additional cost of the newer engine? My engine may need more work also since I have not driven it much the past 6 months, so a full rebuild might be in order.
If I swap a used engine is fine since I can probably pick one up from a someone else swapping I am thinking. A have a lot of miles on my engine anyway, over 200k KM.
Im planning on keeping the ride for a few more years at least.
polaris is offline   Reply With Quote
Old 09-16-2010, 02:16 PM   #2
sandman21_21
Member#: 152118
1999 RBP 2.5RS Sold
1998 RBP WRX swap XO GC
If you were to stick with a N/A engine, you could check with RR as they likely have a few left over from swaps they had done. You can find used WRX engines around as well, but either process is not overly cheap (if done by a shop). Personally, from driving a N/A and a turbo'd GC, you're better off spending a little bit extra to get an engine that gives you a few more options (future mods, etc). It can be costly though. I sold my last GC for my current one because the swap had already been done, and it was more economical than trying to undertake the swap myself.
Obviously if you're mechnically inclined, the swap can be done for cheaper.
sandman21_21 is offline   Reply With Quote
Old 09-16-2010, 02:52 PM   #3
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
Your body style is unique to have a turbo swap in it. I would spend the $$ and swap in a turbo motor and have a super fun little beast
If you looking for practical, then put in a stock replacement motor to get you back on the road
you have to deceide what you wanna spend and that will tell you where you wanna go
rs420 is offline   Reply With Quote
Old 09-16-2010, 04:17 PM   #4
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
swapping in another used motor will be much cheaper than a full rebuild...
but then again you will be in the same place as you are now a lot sooner with a swapped used motor than with a rebuild...
trade offs
Jeff54 is offline   Reply With Quote
Old 09-17-2010, 12:40 AM   #5
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
if you plan on keeping it for a few years at least then I would rebuild.
2010 WRX Limited is offline   Reply With Quote
Old 09-17-2010, 02:04 PM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
+1. Putting another used motor in there that is high mileage already or you don't know the history probably won't last as long imo.
Just make sure you find someone that is capable of doing a good rebuild. Poor machine work on a Subaru = fail.
alcoolaid is offline   Reply With Quote
Old 11-09-2010, 05:47 PM   #7
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
So I finnally got it over to a recommended shop.
Cylinder #3 has the blown gasket. Quote is:
$1200 repair that side of the engine
$1000 more to do the other side also.
$580 to also do the belts, water pump, thermostat.
Then plus taxes. It doesnt hurt me so badly since I can write off against my business use, and I can drive this for another 4-5 years afterwards without engine issues hopefully? The rest of the car is in good shape, and clutch was done recently as well.
Any thoughts? Thanks
Old 11-09-2010, 05:51 PM   #8
alcoolaid
Member#: 134949
'07 SWP STi
$580 not bad for the belts, water pump, thermostat, etc. Parts included I assume?
Seems weird its $1200 to repair 1 side of the engine then another $1000 to do the other side. The engine is out already. It's not much more work to repair the other side.
Old 11-09-2010, 06:34 PM   #9
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
not necessarily....they might replace the gasket with the engine in the car...it's not hard to do at all with the SOHC 2.5L. god i ****ing love that engine
Old 11-09-2010, 08:28 PM   #10
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
having said that it's simple to remove the engine, and i know a couple techs that are happier working on an engine stand.
FunkMasta is offline   Reply With Quote
Old 11-09-2010, 11:04 PM   #11
iht
Member#: 196742
2000 Impreza 2.5rs
1200+1000 is about the price for a used WRX motor. add a bit more and you'd get a tune / ETC.
iht is offline   Reply With Quote
Old 11-09-2010, 11:38 PM   #12
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
yeah the mech. did NOT remove the engine from the bay. He is working with it in there and just removed the heads for now.
Parts are in I would think (I did not confirm but I had asked for 'all in' prices). I still have to give him instructions.
I think I will get it done. I love the car, even though I would love to get a newer STi at some point.
Used engine I considered, but again who knows whats up with it. This will be should be solid for another 100km. Going with a turbo engine adds another layer of work I really dont need for a daily driver.
Old 11-10-2010, 01:47 AM   #13
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
of course an engine is easier to work on on a stand....
but quicker? **** no....not even close...way faster to do it in the engine bay with a 251
205, 255, 257, etc are a different story, hell even 25d...
Old 11-11-2010, 11:59 PM   #14
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
never said it was quicker....
Need rotor replacement advice: buy new vs. resurface MasterPain Brakes, Steering & Suspension 2 09-21-2006 02:53 PM
Need Advice: Rockford Fosgate vs. Concept Ovaltine Car Audio, Video & Security 8 11-04-2004 10:42 PM
Bar job vs Bank job. Who's more professional? 4x4GGG Off-Topic 5 08-17-2004 08:23 PM
Current Job vs. Potential New Job. Opinions Redneck Ricer Off-Topic 28 12-29-2003 11:24 AM
OT Advice: Jobby Jobs.... Jimmy S. Off-Topic 6 12-11-2003 04:31 PM
