Old 09-16-2010, 06:16 PM   #1
bugeye1257
Member#: 188598
Default ej207 build..HELP no oil pressure!
alright, so it has come time to build my motor. i have a v7 207 long block and recently i seized a ring-land im pretty pissed about it but hey what are you going to do, let it sit or rebuild? my plans for it, are not to go over bored with the build. this is still my daily driver! i will most likely be going to hit 460whp on pump, which i think i can easily hit with this turbo. so far i have been making around 430whp give or take. BELIEVE IT OR NOT i am still on my stock 5 speed with an act 6 puck clutch yes i cant believe it either but i think its a factory freak haha i sure have not babied it at all, thats for sure. i guess thats all i have to say... let the build begin!
parts that will be going in the new build-
grimmspeed phenolic mani 8mm spacers
wiseco pistons 92mm w/.020 over bore
gates oem water pump
clevite main bearings
clevite rod bearings
arp head studs
gates racing timing belt
ej25 11mm oil pump
full gasket set
gates racing alternator/power steering belt
oem headgaskets
my current setup on the engine-
holset hx40 .63 ar (v-band now)
rotated perrin down pipe
rotated perrin up pipe
tial 44mm ewg
850cc injectors
255 fuel pump
turboxs front mount (custom pipes)
aem ems
gm bc
custom ccv added to down pipe
blow thru maf
custom coolingmist alcohol/water kit (not hooked up yet)
thanks,
andrew
bugeye1257 is offline   Reply With Quote
Old 09-16-2010, 07:12 PM   #2
arghx7
Member#: 232940
That's a big turbo--what are your goals for the engine? And why are you running a blow through MAF with an AEM EMS?
arghx7 is offline   Reply With Quote
Old 09-16-2010, 11:27 PM   #3
bugeye1257
Member#: 188598
well ive hit 430 whp pretty easy with this setup now on stock trans. i dont wanna go crazy with this build like i said before. something around 430-460 is fine with me. it is my daily driver. i just wanna get it back on the road again because i miss it so damn much haha ive had better results with that setup so im gonna stick with it. is there a reason i shouldn't be?
Old 09-16-2010, 11:51 PM   #4
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Phenolic spacers: 8mm for FMIC, 3mm for TMIC (not enough space for everything to fit with the extra 0.5cm)
Like the holset
SurfWagon is offline   Reply With Quote
Old 09-17-2010, 12:08 AM   #5
bugeye1257
Member#: 188598
oh ok thats what i thought.
thankyou
Old 09-18-2010, 03:56 PM   #6
bugeye1257
Member#: 188598
No one!??
Old 09-19-2010, 10:42 PM   #7
bugeye1257
Member#: 188598
ok so i decided to order i new water pump and grimmspeed 8mm spacers
im still looking for other answers for the questions above!
Old 09-19-2010, 11:55 PM   #8
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
I am about to start on my 207 build and will be using head studs, probably gong to get ferrera valves and either cp or je pistons I feel the same about the headgasket as you, not sure what to go with
seanathanq83 is offline   Reply With Quote
Old 09-20-2010, 12:10 AM   #9
bugeye1257
Member#: 188598
yeh i think im gonna order some. might as well since its gonna be apart. ive been looking into ferrera valves too but i dont know if i need them or not. with the headgaskets im hesitating to order one of them.
Old 09-20-2010, 07:42 AM   #10
seanathanq83
Member#: 173241
well i had a ver8 and it had sodium filled and i wanted to get rid of those while i am in there and i have herd some good stuff about the ferrera super alloys
Old 09-20-2010, 08:57 PM   #11
bugeye1257
Member#: 188598
also i have decided to get a ej25 11mm oil pump. so thats going on my list to order too!
Old 09-22-2010, 12:01 AM   #12
bugeye1257
Member#: 188598
so what kind of head gaskets to get!? oem, cometic, cosworth???
Old 09-22-2010, 12:35 AM   #13
SLOWSUBY
Member#: 169417
the cometic mls gaskets are not the greatest to me. the middle layer is to thick and doesnt like to bend to seal up. i liked the oem and the cosworth they worked fine for me and easier to get to seal. with the hp goals your going for i would go ahead and do the head studs. unless arp came out with a stronger material since cosworth did i would go with who ever has the stronger material. if your going aem you dont need a maf but you will need a map sensor. or to save some money you could go with a reflash or something i would find a tuner and see what they would prefer on you setup. i have a almost new set of custom wiseco pistons they only in there for about 500 miles no pits burs or marks of any kind no wear marks on the side skirt or anything. ill let them go for $200 pm me if your interested. and new oil pump are always i good idea on a new motor.
SLOWSUBY is offline   Reply With Quote
Old 09-22-2010, 01:49 AM   #14
bugeye1257
Member#: 188598
i think im gonna try to find a set of cosworth gaskets on here. arp head studs are also on the list to get now. i already have those other parts on my car with the aem hooked up. ive had that setup for awhile now but then this happened and i will be messaging you shortly! thank you for the info man!
Old 09-22-2010, 01:58 AM   #15
bugeye1257
Member#: 188598
found a full gasket set that ill be picking up!
http://www.fredbeansparts.com/index....eal-kit-s.html
Old 10-14-2010, 02:44 AM   #16
bugeye1257
Member#: 188598
picked up some parts today at great prices thanks to Fred Beans Subaru! nothing to exciting
gates water pump
ej25 oil pump
full gasket set
gates racing alternator belt
I havnt been able to work on the car to much because of school holding me back. but yesterday i finally got to work taking it apart. motor should be out this weekend. ill make sure to take pics while in progress
Old 10-19-2010, 12:42 AM   #17
bugeye1257
Member#: 188598
just some pics of the turbo. im thinking about polishing it?
Old 11-01-2010, 07:56 PM   #18
bugeye1257
Member#: 188598
just have a question about the acl main/rod bearings in what size to get?? i don't know if i should go .001"/.010"/.020" or just standard? anyone have any input!?
Old 11-01-2010, 09:58 PM   #19
seanathanq83
Member#: 173241
thats what i am wondering, my stock lasted for ever but i want to go to 8000-8500 when i get my bigger turbo, i was thinking the hx hi flow, but not positive yet
Old 11-03-2010, 06:30 PM   #20
bugeye1257
Member#: 188598
anyone have info on the bearings??????
Old 11-03-2010, 07:54 PM   #21
Mohammadov
Member#: 110160
2005 STI+JDM V7 Swap
not sure about this,but i think Cosworth bearing will be better.i just like that company!!
Mohammadov is offline   Reply With Quote
Old 11-03-2010, 08:41 PM   #22
bugeye1257
Member#: 188598
meh cosworth is a good company and all but over priced for some of the things they sell
Old 11-03-2010, 09:15 PM   #23
seanathanq83
Member#: 173241
thats what i am thinking
Old 11-04-2010, 04:18 AM   #24
Mohammadov
Member#: 110160
Engine bearings are one of the most vital components within an engine and are often overlooked when considering high performance upgrades.
Main bearing price is 110 USD
Rod Bearing is 83 USD
Its all returns to you.
Regards.
Old 11-24-2010, 01:05 AM   #25
bugeye1257
Member#: 188598
looks like this needs to be fixed
while waiting for the motor, i decided to do some painting. used vht wrinkle black spray paint. didnt really come out how i wanted but good enough..
i will have these powercoated later on, i was just bored haha tgv will be black also
Gear clash question on 6MT with lots of poly mounts/bushings Conduit Transmission (AT/MT) & Driveline 1 03-20-2011 04:26 PM
New guy with lots of noobish upgrade questions tickthrow Newbies & FAQs 9 03-26-2008 06:40 PM
Wtt tb evo with Lots of mods. For a 2.5rs coupe with sti swap. beast Private Vehicle 'For Sale' Classifieds 3 04-05-2007 02:23 AM
Massive part-out of very nice STi with lots of mods cdraayer Texas Impreza Club Forum -- TXIC 14 04-22-2004 10:14 PM
