Old 09-16-2010, 06:24 PM   #1
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Default URGENT: how should this ground wire be repaired?
Removed the Prolumen H1 hid kit after it didn't fire up on the first try, started to smoke last night and melted a splice connector when I went to investigate the problem (performed flawlessly for 4+ years and never again will I bother with aftermarket hid kits). The kit was spliced into the ground wire for the low beams via a vampire tap splice, I managed to free the ground wire from it, but now it's slightly exposed.
What should be my plan of attack in repair of the wire? Cut, stripped, soldered and rejoined together?
eurospek is offline   Reply With Quote
Old 09-16-2010, 06:37 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the wire itself appears ok and just the insulation is trashed, you can wrap it up well with electrical tape and it should be ok. It may be best though, to just cut out the bad section and splice in a new section of wire. Those taps usually cut through a few strands of the wire.
Clip-on taps should never be used for headlights and it was totally insane to use them with HIDs. You're lucky it only smoked and didn't go on fire.
Old 09-16-2010, 06:44 PM   #3
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Total noob mistake on my part. Bought into the hype of hids in 2006 and they definitely did look cool (had 5000K), along with my PIAA Ion yellow fogs. But lately they were never firing up right away, the passenger side always color shifted a little before getting up to the correct color and the cutoff of them was bothering me lately everytime I saw it on the car in front of me on the highway.
But never again.
Old 09-16-2010, 10:34 PM   #4
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
Also Mulder, instead of soldering, could something like this be used or stay away from splices?
http://order.waytekwire.com/productd...MPED%20SEALED/
Where does this ground wire go?! helievacpilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-13-2006 01:18 AM
How should I run wires to my trunk? mora2818 Car Audio, Video & Security 4 02-12-2005 06:09 PM
Should this classic thread be unlocked? Kha0S Off-Topic 21 08-13-2004 06:02 PM
can this damage bumper be repaired? etam Off-Topic 3 02-09-2004 09:17 AM
Should this site URL be changed to www.impreza-wrx.com? IsraelGT General Forum Archive 6 11-22-2000 09:20 AM
