Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 09-17-2010, 01:36 AM   #1
arisking
Member#: 245282
04 JBP STi
Default Stock location vs rotated???
Hey, guys I have researched every little thing I need to do for a build, so I am not a total n00b. I just can't find info on this. But I am now debating whether or not to go rotated or stock location. It seems to be the only thing I am stumped on.
First off besides the price and parts what's the real difference? Does rotated offer that much more power?
I would like to go stock location as I want to keep my TurboXS 4" DP as I believe spool times would be faster and the turbo would be louder out of the exhaust. I get to save money. And I don't want it to look super flashy because I went rotated and it looks different. Tucked away would be nice...LOL.
If they made a rotated kit with a 4" DP and if rotated is that much better I might just bite the bullet.
Thanks for the feedback guys, I look forward to your responses.
arisking is offline   Reply With Quote
Old 09-17-2010, 10:19 AM   #2
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
i know you have more options for a larger hot side on the turbo and larger maf pipe for topend power,what powerband are you looking for??
EROCS04SBRUSTI is offline   Reply With Quote
Old 09-17-2010, 01:16 PM   #3
arisking
Member#: 245282
04 JBP STi
Hmm, I did read that the only real change is the air intake side of things is different on a rotated setup. But that obvious too.
As far as power band I would like something with good bottom end and stronger mid range. I do not want a highway monster as I don't have my STi wing anymore, so not high speeds as I won't have the proper downforce.
Does that makes sense? I hope so. My goal is something like a 3067R with 425WHP on pump gas with a hood amount of TQ. Around 400 or more. I figure 3076R as I can have pretty fast spool, especially with that DP and a different UP if I feel like it, even though the stock STi UP is catless.
Those are what I am really looking for, and what do you mean hot side? Does that make a huge difference?
Old 09-17-2010, 01:23 PM   #4
06njsti
Member#: 150986
06 #001 LSB STi
obviously you didnt seach well enough http://forums.nasioc.com/forums/show....php?t=1808329
06njsti is offline   Reply With Quote
Old 09-17-2010, 01:24 PM   #5
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Dude, the stock location turbos have always been compromises to the rotated setups. Rotated just gives you so many more options.
ASU is offline   Reply With Quote
Old 09-17-2010, 01:33 PM   #6
arisking
Member#: 245282
04 JBP STi
Okay, well thanks for the information. If spool and power gain are that different in a rotated setup, then I'll just go rotated I suppose. Just going to see what my cash money situation looks like when I do the build.
Funny that I didn't find that in the search, oh well. Thank you very much for that! Now I can make my decision.
Old 09-17-2010, 07:36 PM   #7
subyguy21
Member#: 222612
04 GD EFR
Follow this.. I have a SL 3076R right now and its okay. But just paying that few extra hundred for a rotated and always being able to change your turbo with ease is WELL worth it. Im going to be posting my 3076r up for sale pretty soon so I can buy a rotated one.
subyguy21 is offline   Reply With Quote
Old 09-17-2010, 09:16 PM   #8
arisking
Member#: 245282
04 JBP STi
Yeah I am only looking for 425WHP, so a rotated kit almost isn't worth it. But it then again comes down to the money. If I have a lot left over, then rotated it is, 3076R .82.
But that is probably months away, so we'll see. Then I'd just have to chose which one. Treadstone seems like they know what they're doing, so that is nice.
Old 09-18-2010, 10:27 AM   #9
crashtke
Member#: 120912
If you are looking for 425 on pump, rotated will definitely make it easier to obtain.
crashtke is offline   Reply With Quote
Old 09-18-2010, 02:08 PM   #10
arisking
Member#: 245282
04 JBP STi
I suppose it will indeed. Now I will look up the different companies to see who makes the best one.
Old 09-18-2010, 08:07 PM   #11
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
What kind of car is this? What is your engine set up? Transmission set up?
a 3076 will not make 425 wheel on pump gas alone on a regular dyno. You will need 25+ psi to attain that number.
Either way, you will need a built engine to run that much power. If its a wrx, you will also need a new transmission.
godforbid67 is offline   Reply With Quote
Old 09-18-2010, 08:10 PM   #12
godforbid67
Member#: 137168
06 Built SGM WRX
That aside, go with a stock location blouch dom 4 xtr..... Or settlle for 380-400 wheel and get a dom 3 xtr.
Old 09-18-2010, 08:33 PM   #13
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
yeah the new xtr doms are putting down great numbers for being stock location, just so you know a turbo that can put down 400 hp is not going to have great lowend. its a give and take. but the new xtr line of turbos spool up great.
Alaskan EJ20 is offline   Reply With Quote
Old 09-18-2010, 08:54 PM   #14
godforbid67
Member#: 137168
06 Built SGM WRX
Yeah thats true also. The low end is not going to be there.
Old 09-19-2010, 01:02 AM   #15
arisking
Member#: 245282
04 JBP STi
If I can sell my STi TMIC, injectors, turbo and whatever else I don't need in this build for the difference from buying a rotated kit vs. stock location I'll do it.
Old 09-19-2010, 02:03 AM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
What car is this going into? Do you have the engine and transmission to support this power? If not, factor that into price as well.
Old 09-21-2010, 02:34 PM   #17
surfinSTi
Member#: 242933
2011 STi
Dark Grey
Rotated, my 2c
surfinSTi is offline   Reply With Quote
Old 09-21-2010, 03:24 PM   #18
R4ND0M_AX3
Member#: 67483
2005 WRX STi
The only thing keeping me from going rotated is the state of California. Other states are adopting our rules. If this is an issue for the OP then stay stock location. Otherwise go all out (even for a 3076) and get a rotated setup with external wastegate. Working on a rotated setup is so much less of a hassle. Opening your hood for a cop is so much less of a gamble with stock location.
R4ND0M_AX3 is offline   Reply With Quote
Old 09-21-2010, 03:47 PM   #19
arisking
Member#: 245282
04 JBP STi
I am most likely going to go rotated now, but once again I will see.
As far as my mods go for this build I will do all new internals, no head work, full fuel system upgrade, clutch, FMIC and little pieces. I have all the bases covered, no worries. This motor will be good for 700 flywheel HP, which is good enough for ~500WHP?, so I am well within my limit of 450WHP max as far as I understand.
EDIT:
I live in Manitoba, I don't think there is a huge deal with rotated or not here. I will look into it though and that will be my deciding factor because cops here in Winnipeg have really stomped on all of us cruisers for Sunday night cruise night. I'll ask around...
Old 09-21-2010, 07:20 PM   #20
Csquared33
Member#: 198053
93 2JZ something
no head work? at least do cams and buckets to match..
Csquared33 is offline   Reply With Quote
Old 09-21-2010, 07:26 PM   #21
azer408
Member#: 194303
2006 Stage 2 WRX
CGM
Yup. and make sure you upgrade your axles too or else you'll just keep snapping them.
azer408 is offline   Reply With Quote
Old 09-21-2010, 07:40 PM   #22
arisking
Member#: 245282
04 JBP STi
Meh, too much money. I just want a fun DD. And cams = bottom end boo-erns, or so I have heard.
And axles, far too much money. No such thing as cheap axles out there. Plus do I need axles if I am not going to launch? Torque from shifting snaps axles? Wow if so...
Fill me in if you can.
Thanks guys, and now I sound like a n00b...LOL.
Old 09-21-2010, 08:56 PM   #23
kasra007
Member#: 225361
2006 wrx sti
beige
30r rotated or stock just doesnt produce enough lbs/min to make a true 400 WHP. hasn't been done and not possible even if you give it 30 psi.
race gas is a different story.
kasra007 is offline   Reply With Quote
Old 09-21-2010, 08:58 PM   #24
kasra007
Member#: 225361
2006 wrx sti
beige
EDIT:
a cop can't give you a ticket because you have a rotated setup.. they don't even know what the hell a rotated setup is. now they will give you a ticket for having EWG (loudness) and exhaust (loudness).
Old 09-21-2010, 09:22 PM   #25
STiXXX
Member#: 177399
2005 Impreza WRX STi
XXX Black
I've had great success with a built motor-Axis Stg. II, with CP forged pistons, 850DWs, APS rail, walboro,
and an FP Green, FMIC, non-rotated, @ 360WHP/350TQ.
0-60 is 3.9-4.1, 180 top end, no sweat. Great highway TQ, great off the line response, my next will be a twin-scroll Green or Red.
Bleh on the 30R, too many lags, IMO.
Good luck with the build!
XXX
In a DD, 350TQ with the Green's very little lag, is WAY beyond enough to merge into traffic while drinking coffee, at 115.
STiXXX is offline   Reply With Quote
Stock Location VS Rotated 06njsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 76 04-16-2011 09:13 PM
rotated 30/35r vs. DOminator III vs. GT52 azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 53 12-28-2010 10:45 PM
EQ Stage 1 Shortblock, EQ Stage 2 Heads, ATP 35R Stock Location, 91 + Meth = 450whp! Equilibrium Tuning Proven Power Bragging 28 01-20-2010 02:30 PM
WTB looking for a stock location 35r SUBIEDUDE33 Private 'Wanted' Classifieds 2 01-01-2009 05:40 PM
Stock location turbo made rotated??? Jhovany Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-09-2008 10:15 PM
