Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 09-17-2010, 06:54 AM   #1
flightwatch
Member#: 231058
2013 Genesis Coupe
Default Just noticed something intresting tonight...
When I let off the gas, my car goes into open loop. When I get back on the gas, it goes into closed loop...unless I get on it and then it will switch to open loop. I'm tuned, but I don't remember ever seeing that. Is it normal?
flightwatch is offline   Reply With Quote
Old 09-17-2010, 08:01 AM   #2
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
Originally Posted by flightwatch View Post
When I let off the gas, my car goes into open loop. When I get back on the gas, it goes into closed loop...unless I get on it and then it will switch to open loop. I'm tuned, but I don't remember every seeing that. Is it normal?
Mine does that until it is warmed up then just stays in open loop all the time.
So in short IDK if it is normal, but mine is wierd too.
iluvdrt is offline   Reply With Quote
Old 09-17-2010, 09:20 AM   #3
Skidd
Member#: 1853
GC6 Supercharged
STM
Not sure about the 2006, but it's perfectly normal in my 00RS EJ251.
When you let off the gas, your car cuts all fuel on engine-deceleration.
Thus, your ECU goes into OpenLoop during this "fuel cut" mode.
So yeah, it's normal.
Skidd is offline   Reply With Quote
Old 09-17-2010, 09:28 AM   #4
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Mine does the same. Before my tune it would warm up in open loop and tried to remain in CL as much as possible. After I tuned it, it's generally only in CL when Im cruising at a constant speed or acceleration gently. Anytime I'm over 75% load or decelerationg in gear im in OL. It will also go to OL during fuel cut.
treksofar is offline   Reply With Quote
Old 09-17-2010, 12:47 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
It's not just 2006, it's OBDII. It's an emissions savings technique. When you're in gear and the car is driving the engine(coasting), the ECU cuts fuel. So it really is a smart idea to coast as much as you can...in gear.
Old 09-17-2010, 01:43 PM   #6
RaineMan
Member#: 256727
2007 2.5I Wagon
Yep... so leave the car in gear as long as possible when approaching a stoplight. When coasting the fuel isn't reapplied until you push in the clutch.
RaineMan is offline   Reply With Quote
Old 09-20-2010, 08:23 PM   #7
GrundleJuice
Member#: 165749
the fuel is only ever injected when the engine rpm's are approaching idle IF the accel pedal angle is 0%. so when coasting, if you are in gear or not, the injectors are "off" until rpms approach idle. then the injectors are back "on" to keep the engine from stalling. staying in gear keeps the injectors "off" longer because engine speed stays above idle as long as wheel speed and gear selected are appropriate. It saves brakes, too. if you are good it saves the clutch and if you are real good it saves clutch, brakes, syncros and maybe a little fuel.
Old 09-20-2010, 08:39 PM   #8
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
yeah I've noticed it on my 06 more since the morning have been getting colder. The whole OL under deceleration was a little weird to get used to, but I noticed I can get a nice backfire if I blip the gas and rev-match 2nd when I'm coming to a stop for an intersection haha
Rudgers73 is offline   Reply With Quote
Old 09-20-2010, 09:01 PM   #9
cmiovino
Member#: 134005
2004 WRX Premium
When off throttle, you're in fuel cut mode as someone stated before. Great for on the highway when concerving fuel. Let the hill do the work, not your engine, heh.
Old 09-21-2010, 02:49 AM   #10
vanquish88
Member#: 165842
06 wrb wrx 1999
impreza 2.5rs
rev matching ftw. my brakes hardly see hard condtions.
vanquish88 is offline   Reply With Quote
Old 09-22-2010, 08:42 AM   #11
mshipes
Member#: 218455
All cars after 2002 have this change.
mshipes is offline   Reply With Quote
Just noticed something in "Gladiator" Hypernoodle Off-Topic 20 01-10-2003 07:12 PM
I just noticed something VSM EXtasy Mid Atlantic Impreza Club -- MAIC 1 01-10-2003 01:30 PM
damn. just noticed something. bdrift Hawaii Impreza Club Forum -- HIIC 8 11-04-2002 12:39 AM
Hey!!!...I just noticed something! obyone Mid West Subaru Owners Club Forum -- MWSOC 11 05-16-2002 02:30 AM
Just noticed something, hope someone can answer this? Why... BlazeWRX Member's Car Gallery 6 11-19-2001 05:52 PM
