Old 06-24-2002, 05:21 PM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default Where to find 440cc Injectors?
Where can I buy 440cc or 550cc high impedence injectors that will fit into a 2001 2.5rs? I called RC enginering and they said at this time they dont have any injectors for me. They would allow me to prototype a set, but the price is still 360 and I would have to splice the injector harness. I was wondering where everyone else are getting their injectors?
-Chav
Chav is offline   Reply With Quote
Old 06-24-2002, 09:12 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
I'ld be willing to prototype mine
would sylvia injectors work? I'm sure there are companies that make them for the sylvia's
Brad
STiTuner is offline   Reply With Quote
Old 06-24-2002, 09:37 PM   #3
N/A
Member#: 133
TBA TBA
TBA
The Silvia uses a side feed style injector and the GTI-R uses a top feed injector but there are alot of aftermarket companies who make injectors for the Silvia. Doesn't SARD make injectors for everything?
N/A is offline   Reply With Quote
Old 06-24-2002, 09:58 PM   #4
Chav
Member#: 3269
RSTi
What are all you other rs-t's using? Tomorrow I'll call vishnu and see if they have any ideas.
-Chav
Old 06-24-2002, 09:59 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
what about sub injectors? that way you only use the extra fuel when you need it, however I'm not so sure how reliable it would be if it was in constant use.
Brad
Old 06-25-2002, 02:00 AM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Why would the 440's from RC not work for you? I talked to Vishnu and they said they use RC 550's in their TEC kits. I have a set of 440's from RC, they are high-impedance and top-feed.
edit: I think the TEC uses low-impedance. But still, I believe you can get high-impedance from RC.
wcbjr is offline   Reply With Quote
Old 06-25-2002, 02:19 AM   #7
Chav
Member#: 3269
RSTi
RC does have injectors that will work on the RS? I've asked them that question at least three times and each time they say "no". This is getting very frustrating! Wcbjr and others on here use the RC injectors yet RC says they have none for me. They must not like me.
Wcbjr: Are you the one testing their prototypes? Have you installed them yet? Any fitment problems? Do they plug right in? If yes do you have a part number?
-Chav
Old 06-25-2002, 10:49 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
They say they won't work because they are not drop-in injectors... you have to solder on the harness to get them current since they use different plugs ($9 each from RC Eng). I'm not sure, but it could be that the o-rings need to be changed too.
I've got a set sitting in a box, though I will most likely end up using them.
Old 06-25-2002, 12:33 PM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Not only is there a problem with the harnesses, but I believe the injectors are 1/4" taller than the stockers. So you must raise them somehow.
Old 06-25-2002, 12:58 PM   #10
Delicious Tuning
Member#: 1990
Well I am working on getting STi 565cc injectors. Hopefully at a good price but we will see.
~Bill
Delicious Tuning is online now   Reply With Quote
Old 06-25-2002, 01:32 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Bill -
Keep in mind that WRX injectors are much different in shape to the RS ones, so the modification it'll take will be pretty extensive.
Old 06-25-2002, 02:58 PM   #12
Chav
Member#: 3269
RSTi
Andrew at AMR said that the wrx stock injectors drop right in. The only problem is they are low impedence and we have to get resistors ($60) to compensate. The stock wrx injectors are 440cc. Would this mean that the sti 565cc injectors would drop right in and only need the resistor pack?
-Chav
Old 06-25-2002, 03:56 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The stock WRX injectors drop right into what? Last time I looked at them, they were WAY off on size. I'll see if I can borrow one from someone that has swapped them out and fit them into my extra intake manifold and rails... I doubt they'll fit, but it's worth a shot.
Old 06-25-2002, 04:58 PM   #14
Chav
Member#: 3269
RSTi
I just talked to Andrew and the stock wrx injectors are high impedence and so are the sti's. So we wouldnt need the resistors. They flow 420cc and fit into our fuel rails. I hope you get a chance to check 8complex. I would love to get the sti 565cc's especially if they fit right in.
-Chav
Old 06-25-2002, 05:09 PM   #15
Delicious Tuning
Member#: 1990
There seem to be a few different versions out there from what I am finding. Some fit and some don't. Sort of strange don't you think.
8complex,
If you find a set that does not fit let me know, I will try to stay away from those then and hopefully find the right ones.
Old 06-25-2002, 05:13 PM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, if I can find one locally, it'll be a stock WRX injector. So anything that drops into the WRX will be in the same group with those. I think I can find one pretty easily... there are two people I can ask that I know have stocker's out, but not sure if they have the stock o-rings on them still.
Old 06-26-2002, 03:01 AM   #17
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
xephyr here on i-club is using STi 565cc in his 98 RS-T with his own custom made fuel rails.
He sells new ones if you want to order - PM him, his name is Mark Ramirez...
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 06-26-2002, 09:22 AM   #18
redmeanie
Member#: 15702
2001 2.5 RS-T LINK'D
911verion2.0TT (soon)
Default RC injectors
RC is a pain to deal with....No matter what info you give them they will still pretend that they are not available....I had their product code and their model # off of a freinds set right off of his RC injectors that he ordered about 6mnths earlier and they still pretended they did not have them available.I ended up buying a set from Andrew at AMR that he had from an RS he had used during developing the LINK system for it. I don't know what the deal is with RC now they used to be cool and real knowledgeable. By the way Vishnu's fuel rail mod comes with RC injectors? Go figure...
redmeanie is offline   Reply With Quote
Old 06-26-2002, 11:18 AM   #19
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
I've been having the same problems with RC. They seem very disorganized.
So your the one who got those 440'c from Andrew
On top of that RC wants people to try out their prototype, not sure if it will work, at retail!
rrrriiiight.
WRC 555 is offline   Reply With Quote
Old 06-26-2002, 01:30 PM   #20
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
I talked to Robert at Forced air tech, and he said they have been using any generation Eagle Talon TURBO 450cc injectors. He said the idle is a little rough, but not enough to have any problems.. I just picked up a set on EBAY for 61 dollars shipped. If you send them to RC Engineering to have them cleaned and blue printed, you can have an awsome set of 450cc injectors for about 140 dollars.
Pi7467mp is offline   Reply With Quote
Old 06-26-2002, 01:34 PM   #21
Chav
Member#: 3269
RSTi
WOW! Thanks that is a kickass deal! Gonna hunt me down some injectors now.
-Chav
Old 06-26-2002, 02:13 PM   #22
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
wrx, sti and rs injectors are high impendance (I tested and re tested), the wrx and sti ones will fit with no big issues the My99 2.5 rs imprezas, you just have to play with the o-rings and eliminate the bracket on top of the injector, sti will work as well!, on my00+rs, is a diferent history, the intake manifold is diferent where the injectors sits, and the injectors has an extra extention, I think they will fit, you just have to play with o rings again
DJIMPREZA is offline   Reply With Quote
Old 08-12-2002, 09:34 AM   #23
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
About using the Tallon injectors... Are they high impeadance?
PunKidd is offline   Reply With Quote
Old 08-12-2002, 11:20 AM   #24
STiTuner
Member#: 5778
09 135i
Jet Black
DSM injectors are low impenence.
you have to put resistors in to make it them work right.
the actual injectors that will work depends on yoru year car. the DSM will fit 00-01 and the pre 99 ones use a different style.
Brad
Old 08-12-2002, 02:43 PM   #25
Austin
Member#: 7089
2016 STi
I'd be willing to sell my stock WRX injectors and stock WRX fuel rails/fuel pressure regulator. You'd need new spray end o-rings for an RS. Both rails have some pipe left on the end, but you'd still have to flair the ends and use hoses/hose clamps. Good time to convert to parallel rails!
There's a pic of the WRX oem rails/FP regulator I just took out... sorta hacked all the pipes up to get them out, but the rails/regulator and injectors are all in perfect shape.
Austin is offline   Reply With Quote
Hard to find parts - where to find? eclip5e Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-09-2007 01:25 PM
Gotta figure out who to vote for: Where to find FACTUAL DATA The_Triton Political Playground 26 09-28-2004 07:03 PM
I need to rewire my crank pos sensor plug.... where to find weather pack internals?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-26-2004 04:30 PM
Where to find cracks to copy movies? QfactorRS Off-Topic 1 01-13-2004 12:15 PM
WHere to find how to do 3/16 mod BIG BEN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-02-2002 02:24 AM
