Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 09-17-2010, 05:55 PM   #1
MDBlackWRX
Member Sales Rating: (24)
Member#: 93579
... Retired.
Default Nikon D50 and stuff
Upgrading my equipment, so Its time for me to sell one of my cameras... My D50 is an amazing Midlevel DSLR camera that anyone can use with ease, the body is in perfect condition and I've only taken roughly 2000 pictures... Included is:
D50 body with lens cap
Lithium Battery
Charger
18-55 Lens OPTIONAL (See post #8)
ASKING- $230+shipping
Here are the camera Specs...
6MP, same as D70 and D70s. 3,008 x 2,000, also 2,256 x 1,496 and 1,504 x 1,000 pixel settings. Oddly the medium setting is just a few pixels different from the medium setting of the D70 and D70s. Everything else is identical.
AF Sensors: Five, just like D70, D70s, D1X, F5 etc. Same CAM-900 module and -1 EV rating as D70 and D70s.
AF modes: Same as D70 and D70s and adds a new AF-A mode. The AF-A mode automatically selects between AF-S (normal AF) and AF-C (continuous AF). You still have to use the menus to select between AF-S, AF-A and AF-C; the front switch only selects between AF and MF.
Metering: 420 segment color 3D matrix, center-weighted and spot. Rated down to LV 0, same as D70 and D70s. So long as you have at least five segments you're fine, so I wouldn't worry about "only" 420 segments compared to the 1,005 of the more expensive cameras.
Exposure Modes: P, S, A, M and scene modes. Same as D70 and D70s with the one exception of replacing the night landscape mode with a child mode. It does have the night portrait and all the other scene modes of the D70 and D70s. I've never used any of the scene modes anyway.
Pentamirror finder. Same as D70s. D70 had either this or a glass prism depending on where you read it. It looks the same as my D70.
Shutter: Mechanical and electronic like the D70 and D70s. B, 30 - 1/4,000. The manual says 1/2 and 1/3 stops, I forget if the D70 can go in half stops or just thirds. No big deal. Time exposures to 30 minutes with ML-L3 wireless remote.
Frame Rate: 2.5 FPS. Just a little slower than the D70's 3 FPS. It has a buffer, however its depth is unspecified. With the right card it is specified to run for 137 frames continuously till it overflows. The illustration in the manual shows "12," which is the same as the D70 and D70s in the default normal, large JPG setting. I don't know if it's the same or not.
Flash Sync: 1/500, same as D70 and D70s and better than just about every other DSLR regardless of price. It's better than anything from Canon, better than the $5,000 D2X, better than the $3,500 D2H and better than the newest $1,700 D200.
Flash: Built-in, i-TTL, GN 15/49 (m/ft @ ISO 200; 11/36 @ ISO 100), same as D70s. Same numerous and excellent sync modes as D70 and D70s. (Note to Nikon: typo has "TTL" spelt as "TLL" on page 99 of manual, last paragraph.) No ability to use built-in flash as commander for remote control of other flashes.
CCD Sensor: Standard DX size (23.7 x 15.6 mm) and 1.5x mag factor.
ISO: 200 - 1,600, same as D70 and D70s. Adjusts in full stops, not thirds, which I prefer.
White Balance: same fixed settings and white card preset setting as D70 and D70s but lacks direct fine-tuning. The lack of direct WB fine-tuning won't be noticed by 99% of the people who buy these. You can have this through WB bracketing, in which case the camera records three different JPGs as processed from each actual shot. Clever!
Color modes: Three; same as D70 and D70s.
Saturation control: Three settings, same as D70 and D70s.
Histogram: Still the same useless one-channel display (not RGB), just like the D70, D100, D70s, D1x, etc. Nikon's manual even cautions that it's useless and won't agree with what you see in Photoshop (page 53).
Image Rotation: Automatic just like D70 and D70s.
Custom functions: 20 compared to the 25 of the D70s and D70.
File Formats: same as D70: JPEG FINE, NORMAL and BASIC; RAW and RAW + JPEG. Files sizes in the D50 manual are identical to the file sizes I get from my D70.
Memory: SD cards, the little ones, not CF as every other Nikon DSLR has used. Instead of jamming in from the back they slide in from the side. Nikon prints a list of recommended cards, which includes Sandisk, Toshiba and Panasonic. Lexar is prominently absent. Nikon extensively tests every function of the D50 with each of the cards they suggest and guarantees the camera's performance with them. Nikon does not recommend using any other cards and doesn't guarantee anything if you use them. This is great; most camera makers just leave you out on your own here.
LCD (color picture): 2.0;" bigger than D70's 1.8" and identical to the one on the D70s: 130,000 dots.
LCD: (numeric display on top of camera): identical to the one on the D70 and D70s, except no illumination. I work in the dark and use this illumination now and then, so I'd miss this. Most people probably wouldn't.
Battery: EN-EL3, 1,400 mAh, same as D70 and D100. (D70s gets a compatible EN-EL3a of 1,500 mAh) The D50 is rated for 2,000 shots no flash and 400 shots with full power flash every other shot, exactly the same as the D70. Cannot use the MS-D70 holder for three CR2 disposable batteries as the D70 and D70s can.
Size: 5.2 x 4.0 x 3.0" (133 x 102 x 76 mm)
Weight: 19 oz. (540 g) stripped without battery, monitor cover, lens, body cap, strap or memory card.
MDBlackWRX is offline   Reply With Quote
Old 09-17-2010, 10:39 PM   #2
subartender
Member Sales Rating: (22)
Member#: 135652
2004 WRX
JBP
Is that a VR lens?
subartender is offline   Reply With Quote
Old 09-18-2010, 12:49 AM   #3
MDBlackWRX
Member#: 93579
... Retired.
Originally Posted by subartender View Post
Is that a VR lens?
Yes.... Its says "see post 8" only because im also hosting a thread in the member classifieds section and i just copy and pasted it from there, the package price is $250 for everything...(Body, Lens, Battery, Charger, Lens caps, etc.)
Old 09-18-2010, 10:03 PM   #4
AcquaCow
Member Sales Rating: (43)
Member#: 36838
2000 RS Sedan
2004 STi w/RS body swap
Hmm, did you buy that guy's D80? If you did, I might not have a choice but to buy your D50
-- Dave
AcquaCow is offline   Reply With Quote
Old 09-18-2010, 10:10 PM   #5
MDBlackWRX
Member#: 93579
... Retired.
Lol I'm meetin up with him tomorrow (Sunday). I'm tellin ya, both cameras are great.
Old 09-18-2010, 11:06 PM   #6
AcquaCow
Member#: 36838
2000 RS Sedan
Tell him his BBS wheels are doing fine =) I think I'm actually going to pick up a D3000 though... I'm so indecisive
Old 09-19-2010, 06:56 PM   #7
MDBlackWRX
Member#: 93579
... Retired.
Bump bump camera needs a new home!
Old 09-20-2010, 12:27 AM   #8
MDBlackWRX
Member#: 93579
... Retired.
Bump.
Old 09-20-2010, 11:49 PM   #9
MDBlackWRX
Member#: 93579
... Retired.
Bump!
Old 09-23-2010, 12:13 AM   #10
MDBlackWRX
Member#: 93579
... Retired.
Bump!
Old 09-23-2010, 03:47 PM   #11
MDBlackWRX
Member#: 93579
... Retired.
Bump!
Old 09-26-2010, 09:33 AM   #12
MDBlackWRX
Member#: 93579
... Retired.
Bump!
FS Nikon D50 DSLR 18-55mm Lens and 70-300 tico915007 SCIC Private Classifieds 10 05-06-2008 10:53 PM
FS: Nikon D80 and Nikon D50 Firewire VIC Private Classifieds 6 01-01-2008 07:43 PM
FS: Nikon D50 + Nikon KIT Lens + 2GB + Tamron 55-200mm f/4-5.6 Di-II LD team23jordan NWIC Private Classifieds 10 07-25-2007 01:47 PM
Nikon D50 With Two lens 18-55mm and 55-200mm Lens WagonGGA Non-Subaru Stuff 3 06-22-2007 10:54 AM
FS: Nikon D50 camera and lens fivil TXIC Private Classifieds 3 12-08-2006 07:29 PM
Message Board Statistics All times are GMT -4. The time now is 07:10 PM.
